N001-S01-BL
N001-S01-BL
    TRIPPLITE
    N001-S01-BL
N001-S01-BL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat5e 350 MHz Snagless Molded Slim (UTP) Ethernet Cable (RJ45 M/M) - Blue, 1 ft. (0.31 m) MODEL NUMBER: N001-S01-BL Highlights ● Over 25% slimmer than standard Cat5e cables ● Rated for 350 MHz/1 Gbps communications ● Snagless RJ45 male connectors ● Easy to route through cable management panels ● High-quality 28 AWG stranded copper wire Package Includes ● Connects network components like printers, computers, copiers, routers, servers, modems and switches. Ideal for high-density data centers. Slim design increases airflow in tight spaces. Features Perfect Solution for Your Networking Needs ● Ideal for connecting components like printers, computers, copiers, routers, servers, modems and switches in high-density data centers ● Designed for fast transmission and excellent signal quality ● Ensures peak performance throughout your LAN ● Delivers speeds up to 350 MHz/1 Gbps Special Slim Design ● More than 25% smaller in diameter than standard Cat5e cable ● Increases airflow in tight spaces ● Increased flexibility for installing around corners and through cable management panels Premium Construction for Superior Performance ● Made from 28 AWG copper wire ● PVC 4-pair stranded UTP ● RJ45 male connectors ● Integral strain relief for long life Snagless Connectors ● Molded snagless boots prevent locking tabs from damage Specifications 1/3 N001-S01-BL Cat5e 350 MHz Snagless Molded Slim UTP Patch Cable (M/M), 1 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332192912 Technology Cat5/5e POWER Power Over Cable (PoC) Support No PHYSICAL Cable Jacket Color Blue Cable Jacket Material PVC Cable Shielding UTP Cable Outer Diameter (OD) 3.5 mm Number of Conductors 4 Pair Conductor Material Stranded Copper Conductor Gauge 28 AWG Cable Length (ft.) 1 Cable Length (m) 0.30 Cable Length (in.) 12 Cable Length (cm) 30.5 Shipping Dimensions (hwd / in.) 7.00 x 9.00 x 0.50 Shipping Dimensions (hwd / cm) 17.78 x 22.86 x 1.27 Shipping Weight (lbs.) 0.04 Shipping Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range 14 to 104 F (-10 to 40 C) Storage Temperature Range 5 to 122 F (-15 to 50 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 100 MHz Maximum Bandwidth as Tested 350 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3ab 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) Crossover Wiring No Contact Plating Gold Connector Type Molded; Snagless Wiring Configuration EIA/TIA 568B Angled Connector No FEATURES & SPECIFICATIONS IP68 Rated No Snagless Connector No Antibacterial No IP20 Rated No STANDARDS & COMPLIANCE Product Compliance CE (Europe); RoHS; IEEE 802.3ab 1000Base-T; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N001-S01-BL 价格&库存
很抱歉,暂时无法提供与“N001-S01-BL”相匹配的价格&库存,您可以联系我们找货
