N010-010-RD
N010-010-RD
    TRIPPLITE
    N010-010-RD
N010-010-RD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat5e 350 MHz Crossover Molded (UTP) Ethernet Cable (RJ45 M/M), PoE - Red, 10 ft. (3.05 m) MODEL NUMBER: N010-010-RD Highlights ● 10-ft. (3.05 m) Red Cat5e Cross Over Cable w/Green Molded Strain Relief ● Premium cabling for Category 5 and 5e applications—rated for 350 MHz/1 Gbps communications ● PVC 4-pair stranded UTP Package Includes ● Description Tripp Lite's 10-ft. (3.05 m) Red Category 5e (Cat5e) Cross-over cable has 2 standard RJ45 male connectors featuring integral, Green, molded strain relief. The cable is designed to connect switch-toswitch, PC-to-PC or Mac-to-Mac, and is perfect in conjunction with 10 and 100 base-t networks. Molded connectors are a different color to help identify this cable as a cross-over cable, as well as a label stating Cross Over, and not a standard patch cable. Manufactured from PVC 4-pair stranded UTP and rated for 350MHz/1Gbps communication. Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 5e draft 11). Features ● Cabling for category 5 (Cat5) and 5e (Cat5e) applications ● Length: 10-ft. (3.05 m) / Color: Red with Green connectors / Connectors: RJ45 male ● Cross-over wiring designed to connect Switch-to-Switch or PC-to-PC ● Feature molded connectors with integral strain relief ● PVC 4-pair stranded UTP ● Rated for 350MHz/ 1Gbps communication ● Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 5e draft 11) ● Available in other lengths / colors Specifications OVERVIEW UPC Code 037332187581 Technology Cat5/5e POWER 1/3 10-ft. (3.05 m) Cat5e Red Crossover Molded Patch Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Power Over Cable (PoC) Support No PHYSICAL Cable Jacket Color Red Cable Jacket Material PVC Cable Jacket Rating CM Cable Shielding UTP Cable Outer Diameter (OD) 5.0 mm Number of Conductors 4 Pair Conductor Material Stranded Copper Conductor Gauge 26 AWG Cable Length (ft.) 10 Cable Length (m) 3.05 Cable Length (in.) 120 Cable Length (cm) 304.8 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.21 Shipping Weight (kg) 0.10 ENVIRONMENTAL Operating Temperature Range 14 to 104 F (-10 to 40 C) Storage Temperature Range 5 to 122 F (-15 to 50 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 100 MHz Maximum Bandwidth as Tested 350 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3ab; 802.3at CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) Crossover Wiring Yes Contact Plating Gold 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States PoE Type Type 2 PoE+ (30W, IEEE 802.3at) Connector Type Molded; Crossover Wiring Configuration EIA/TIA 568B to EIA/TIA 568A Angled Connector No FEATURES & SPECIFICATIONS IP68 Rated No Snagless Connector No Antibacterial No IP20 Rated No STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3ab 1000Base-T; IEEE 802.3at PoE+; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N010-010-RD 价格&库存
很抱歉,暂时无法提供与“N010-010-RD”相匹配的价格&库存,您可以联系我们找货
