N200-005-WH
N200-005-WH
    TRIPPLITE
    N200-005-WH
N200-005-WH 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6 Gigabit Molded (UTP) Ethernet Cable (RJ45 M/M), PoE, White, 5 ft. (1.52 m) MODEL NUMBER: N200-005-WH Highlights ● Premium cabling for Cat5/5e/6 home/office network applications ● Rated for 550 MHz/1 Gbps communication ● 24 AWG 4-pair stranded UTP with PVC jacket ● Gold-plated copper contacts minimize data loss ● Integral strain relief protects connectors from stress and cracking Package Includes ● Ideal for connecting high-speed network components, such as computers, printers, video game systems, Blu-ray™ players, copy machines, routers and modems, in a home or office Cat5/5e/6 application. Features The Ideal Solution for All High-Speed Cat5/5e/6 Networking ● Connects high-speed network components, such as computers, printers, video game systems, Blu-ray players, copy machines, routers and modems ● Designed for 1000Base-T, 10/100Base-T (Ethernet), 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice, Token Ring Type 3 and EIA/TIA applications ● Recommended for home or office applications ● Provides high-speed connections up to 550 MHz/1 Gbps ● Flawless signal delivery with minimal near-end crosstalk levels Premium Construction Ensures Error-Free Signal Transfer ● Manufactured from 24 AWG 4-pair stranded UTP with staggered-pin plug design ● Molded RJ45 connectors and gold-plated copper contacts for maximum conductivity and minimum data loss ● Integral strain relief protects cable and connectors from stress and cracking ● Meets most current industry standards, including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 6 draft 11) Specifications OVERVIEW UPC Code 037332201867 Technology Cat6 1/3 N200-005-WH Cat6 Gigabit Molded Patch Cable, White, 5 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States POWER Power Over Cable (PoC) Support No PHYSICAL Cable Jacket Color White Cable Jacket Material PVC Cable Jacket Rating CM Cable Shielding UTP Cable Outer Diameter (OD) 6.0 mm Number of Conductors 4 Pair Conductor Material Stranded Copper Conductor Gauge 24 AWG Cable Length (ft.) 5 Cable Length (m) 1.52 Cable Length (in.) 60 Cable Length (cm) 152.4 Shipping Dimensions (hwd / in.) 7.00 x 9.00 x 0.50 Shipping Dimensions (hwd / cm) 17.78 x 22.86 x 1.27 Shipping Weight (lbs.) 0.16 Shipping Weight (kg) 0.07 ENVIRONMENTAL Operating Temperature Range 14 to 104 F (-10 to 40 C) Storage Temperature Range 5 to 122 F (-15 to 50 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 250 MHz Maximum Bandwidth as Tested 500 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3an; 802.3at CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Crossover Wiring No Contact Plating Gold PoE Type Type 2 PoE+ (30W, IEEE 802.3at) Connector Type Molded Wiring Configuration EIA/TIA 568B Angled Connector No FEATURES & SPECIFICATIONS IP68 Rated No Snagless Connector No Antibacterial No IP20 Rated No STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N200-005-WH
物料型号:N200-005-WH
器件简介:这是一条Cat6 Gigabit Molded Patch Cable,支持PoE,白色,长度为5英尺(1.52米),适用于高速网络组件的连接。
引脚分配:RJ45(MALE)连接器,EIA/TIA 568B线序。
参数特性: - 技术:Cat6 - 支持的PoE类型:Type2PoE+(30W, IEEE802.3at) - 带宽:最大测试带宽为500MHz,TIA标准带宽为250MHz - 网络兼容性:1 Gbps(Gigabit) - IEEE标准支持:802.3an, 802.3at
功能详解: - 适用于连接高速网络组件,如计算机、打印机、游戏机、蓝光播放器、复印机、路由器和调制解调器。 - 设计用于1000Base-T, 10/100Base-T (以太网), 100 Mbps TPDDI, 155 Mbps ATM, ISDN, 语音,令牌环类型3和EIA/TIA应用。 - 提供高达550 MHz/1 Gbps的高速连接,信号传输无误,近端串扰水平最小。
应用信息: - 适用于家庭或办公室的Cat5/5e/6应用,连接高速网络组件。
封装信息: - 电缆颜色:白色 - 电缆材料:PVC - 电缆外径:6.0mm - 导体材料:铜绞合 - 导体规格:24AWG - 电缆长度:5英尺(1.52米) - 发货尺寸:7.00x9.00x0.50英寸 - 发货重量:0.16磅(0.07千克)
环境规格: - 工作温度范围:14°F至104°F(-10°C至40°C) - 存储温度范围:5°F至122°F(-15°C至50°C) - 工作湿度范围:0%至90%RH,非凝结 - 存储湿度范围:0%至90%RH,非凝结
通信规格: - 支持的IEEE标准:802.3an, 802.3at
连接信息: - 端A和端B的连接器均为RJ45(MALE)。
标准和合规性: - 产品认证:UL Listed, cUL Listed - 产品合规性:CE(欧洲); RoHS; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA - 产品保修期(全球):有限终身保修
N200-005-WH 价格&库存
很抱歉,暂时无法提供与“N200-005-WH”相匹配的价格&库存,您可以联系我们找货
