N201-S03-BL
N201-S03-BL
    TRIPPLITE
    N201-S03-BL
N201-S03-BL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6 Gigabit Snagless Slim UTP Ethernet Cable (RJ45 M/M), PoE, Blue, 3 ft. (0.91 m) MODEL NUMBER: N201-S03-BL Highlights ● Over 38% slimmer than standard Cat6 cables ● Rated for Cat6 Gigabit/1 Gbps communications ● Snagless RJ45 male connectors ● Easy to route through cable management panels ● High-quality 28 AWG copper wire Package Includes ● Connects network components like printers, computers, copiers, routers, servers, modems and switches. Ideal for high-density data centers. Slim design increases airflow in tight spaces. Features Perfect Solution for Your Networking Needs ● Ideal for connecting components like printers, computers, copiers, routers, servers, modems and switches in high-density data centers ● Designed for fast transmission and excellent signal quality ● Ensures peak performance throughout your LAN ● Delivers speeds up to Cat6 Gigabit Special Slim Design ● More than 38% smaller in diameter than standard Cat6 cable ● Increases airflow in tight spaces ● Extra flexible for installing around corners and through cable management panels Premium Construction for Superior Performance ● Made from 28 AWG copper wire ● PVC 4-pair stranded UTP ● RJ45 male connectors ● Integral strain relief for long life Snagless Connectors ● snagless boots prevent locking tabs from damage Specifications 1/3 N201-S03-BL Cat6 Gigabit Snagless Slim UTP Patch Cable (RJ45 M/M), 3 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332193056 Technology Cat6 PHYSICAL Cable Jacket Color Blue Cable Jacket Material PVC Cable Jacket Rating CM Cable Shielding UTP Cable Outer Diameter (OD) 3.8 mm Number of Conductors 4 Pair Conductor Material Stranded Copper Conductor Gauge 28 AWG Cable Length (ft.) 3 Cable Length (m) 0.91 Cable Length (in.) 36 Cable Length (cm) 91.4 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.06 Shipping Weight (kg) 0.03 ENVIRONMENTAL Operating Temperature Range -4 to 140 F (-20 to 60 C) Storage Temperature Range -4 to 140 F (-20 to 60 C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 5% to 85% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 250 MHz Maximum Bandwidth as Tested 550 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3ab; 802.3af; 802.3at CONNECTIONS Side A - Connector 1 RJ45 (MALE) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Side B - Connector 1 RJ45 (MALE) Crossover Wiring No Contact Plating Gold PoE Type Type 1 PoE (15.4W, IEEE 802.3af); Type 2 PoE+ (30W, IEEE 802.3at) Connector Type Snagless Wiring Configuration EIA/TIA 568B Angled Connector No FEATURES & SPECIFICATIONS IP68 Rated No Snagless Connector Yes Antibacterial No STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3ab 1000Base-T; IEEE 802.3af PoE; IEEE 802.3at PoE+; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N201-S03-BL 价格&库存
很抱歉,暂时无法提供与“N201-S03-BL”相匹配的价格&库存,您可以联系我们找货
