1000 Eaton Boulevard
Cleveland, OH 44122
United States
Cat5e 350 MHz Snagless Molded Slim (UTP)
Ethernet Cable (RJ45 M/M) - Blue, 6 ft. (1.83 m)
MODEL NUMBER: N001-S06-BL
Highlights
Over 25% slimmer than
standard Cat5e cables
Rated for 350 MHz/1 Gbps
communications
Snagless RJ45 male connectors
Easy to route through cable
management panels
High-quality 28 AWG copper
wire
Package Includes
Connects network components like printers, computers, copiers, routers, servers, modems and switches.
Ideal for high-density data centers. Slim design increases airflow in tight spaces.
Features
Perfect Solution for Your Networking Needs
● Ideal for connecting components like printers, computers, copiers, routers, servers, modems and
switches in high-density data centers
Designed for fast transmission and excellent signal quality
Ensures peak performance throughout your LAN
Delivers speeds up to 350 MHz/1 Gbps
Special Slim Design
● More than 25% smaller in diameter than standard Cat5e cable
Increases airflow in tight spaces
Extra flexible for installing around corners and through cable management panels
Premium Construction for Superior Performance
● Made from 28 AWG copper wire
PVC 4-pair stranded UTP
Nickel-plated RJ45 male connectors
Integral strain relief for long life
Snagless Connectors
● Molded snagless boots prevent locking tabs from damage
Specifications
1/3
N001-S06-BL Cat5e 350 MHz
Snagless Molded Slim UTP
Patch Cable (RJ45 M/M), 6 ft.
Cleveland, OH 44122
United States
OVERVIEW
UPC Code
037332193025
Technology
Cat5/5e
POWER
Power Over Cable (PoC) Support
No
PHYSICAL
Cable Jacket Color
Blue
Cable Jacket Material
PVC
Cable Shielding
UTP
Cable Outer Diameter (OD)
3.5 mm
Number of Conductors
4 Pair
Conductor Material
Stranded Copper
Conductor Gauge
28 AWG
Cable Length (ft.)
6
Cable Length (m)
1.83
Cable Length (in.)
72
Cable Length (cm)
182.9
Shipping Dimensions (hwd / in.)
7.00 x 9.00 x 0.50
Shipping Dimensions (hwd / cm)
17.78 x 22.86 x 1.27
Shipping Weight (lbs.)
0.14
Shipping Weight (kg)
0.06
ENVIRONMENTAL
Operating Temperature Range
14 to 104 F (-10 to 40 C)
Storage Temperature Range
5 to 122 F (-15 to 50 C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
Bandwidth per TIA Standard
100 MHz
Maximum Bandwidth as Tested
350 MHz
Network Compatibility
1 Gbps (Gigabit)
IEEE Standards Supported
802.3ab
2/3
Cleveland, OH 44122
United States
CONNECTIONS
Side A - Connector 1
RJ45 (MALE)
Side B - Connector 1
RJ45 (MALE)
Crossover Wiring
No
Contact Plating
Gold
Connector Type
Molded; Snagless
Wiring Configuration
EIA/TIA 568B
Angled Connector
No
FEATURES & SPECIFICATIONS
IP68 Rated
No
Snagless Connector
No
Antibacterial
No
IP20 Rated
No
STANDARDS & COMPLIANCE
Product Compliance
CE (Europe); RoHS; IEEE 802.3ab 1000Base-T; REACH; UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N001-S06-BL”相匹配的价格&库存,您可以联系我们找货
