1000 Eaton Boulevard
Cleveland, OH 44122
United States
Cat6 Gigabit Molded (UTP) Ethernet Cable (RJ45
M/M), PoE, Green, 15 ft. (4.57 m)
MODEL NUMBER: N200-015-GN
Highlights
Premium cabling for Cat5/5e/6
home/office network
applications
Rated for 550 MHz/1 Gbps
communication
24 AWG 4-pair stranded UTP
with PVC jacket
Gold-plated copper contacts
minimize data loss
Integral strain relief protects
connectors from stress and
cracking
Package Includes
Ideal for connecting high-speed network components, such as computers, printers, video game systems,
Blu-ray™ players, copy machines, routers and modems, in a home or office Cat5/5e/6 application.
Description
The N200-015-GN Cat6 Gigabit Molded Patch Cable (M/M) ensures ultra-fast performance throughout
your Cat5/5e/6 network application. It connects high-speed network components like computers, printers,
video game systems, Blu-ray players, copy machines, routers and modems in a home or office Cat5/5e/6
application.
This 15-ft. (4.57 m) green cable is designed for 1000Base-T (1 Gbps Ethernet), 10/100Base-T (Ethernet),
100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice, Token Ring Type 3 and EIA/TIA applications.
Manufactured from 24 AWG 4-pair stranded UTP with a staggered-pin plug design and male RJ45
connectors, each cable provides high-speed connections up to 550 MHz/1 Gbps and flawless signal
delivery, while keeping near-end crosstalk levels to a minimum.
The N200-015-GN is constructed of top-quality materials for long life and durability. Corrosion-resistant
gold-plated copper contacts provide maximum conductivity and minimize data loss. Integral strain relief
gives the cable extra flexibility, reduces stress, and helps the cable and connectors move freely without
cracking. Meets most current industry standards, including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568,
ISO/IEC 11801 and ETL (category 6 draft 11).
Features
The Ideal Solution for All High-Speed Cat5/5e/6 Networking
● Connects high-speed network components, such as computers, printers, video game systems, Blu-ray
Designed for 1000Base-T, 10/100Base-T (Ethernet), 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice,
Recommended for home or office applications
Provides high-speed connections up to 550 MHz/1 Gbps
Flawless signal delivery with minimal near-end crosstalk levels
Premium Construction Ensures Error-Free Signal Transfer
● Manufactured from 24 AWG 4-pair stranded UTP with staggered-pin plug design
Molded RJ45 connectors and gold-plated copper contacts for maximum conductivity and minimum data
loss
1/3
Molded Patch Cable, Green, 15ft. (4.57 m)
Cleveland, OH 44122
United States
Integral strain relief protects cable and connectors from stress and cracking
Specifications
OVERVIEW
UPC Code
037332201942
Technology
Cat6
POWER
Power Over Cable (PoC) Support
No
PHYSICAL
Cable Jacket Color
Green
Cable Jacket Material
PVC
Cable Jacket Rating
CM
Cable Shielding
UTP
Cable Outer Diameter (OD)
6.0 mm
Number of Conductors
4 Pair
Conductor Material
Stranded Copper
Conductor Gauge
24 AWG
Cable Length (ft.)
15
Cable Length (m)
4.57
Cable Length (in.)
180
Cable Length (cm)
457.2
Shipping Dimensions (hwd / in.)
10.00 x 6.80 x 0.50
Shipping Dimensions (hwd / cm)
25.40 x 17.27 x 1.27
Shipping Weight (lbs.)
0.40
Shipping Weight (kg)
0.18
ENVIRONMENTAL
Operating Temperature Range
14 to 104 F (-10 to 40 C)
Storage Temperature Range
5 to 122 F (-15 to 50 C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
2/3
Cleveland, OH 44122
United States
COMMUNICATIONS
Bandwidth per TIA Standard
250 MHz
Maximum Bandwidth as Tested
500 MHz
Network Compatibility
1 Gbps (Gigabit)
IEEE Standards Supported
802.3an; 802.3at
CONNECTIONS
Side A - Connector 1
RJ45 (MALE)
Side B - Connector 1
RJ45 (MALE)
Crossover Wiring
No
Contact Plating
Gold
PoE Type
Type 2 PoE+ (30W, IEEE 802.3at)
Connector Type
Molded
Wiring Configuration
EIA/TIA 568B
Angled Connector
No
FEATURES & SPECIFICATIONS
IP68 Rated
No
Snagless Connector
No
Antibacterial
No
IP20 Rated
No
STANDARDS & COMPLIANCE
Product Certifications
UL Listed; cUL Listed
Product Compliance
CE (Europe); RoHS; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
