1000 Eaton Boulevard
Cleveland, OH 44122
United States
Cat5e 350 MHz Molded Shielded (STP) Ethernet
Cable (RJ45 M/M), PoE, Gray, 10 ft. (3.05 m)
MODEL NUMBER: N105-010-GY
Highlights
Protect your network data from
EMI/RFI interference
Molded boot provides extra
strain-relief and durability
Package Includes
Description
Protect your high-speed network from noise and electromagnetic interference with Tripp Lite's 10-ft. (3.05
m) gray, Category 5e (Cat5e) Shielded patch cable. This STP cable features 2 shielded RJ45 gold molded
male connectors with integral strain relief. The cable is manufactured from PVC, 4-pair, stranded shielded
twisted pair, and is rated for 350MHz/1Gbps communication.
Features
Provides EMI/RFI shielding in Ethernet networks
Shielded RJ45 connectors with gold-plated contacts
4-pair 24 AWG Stranded STP with drain wire
Molded boot for extra strain-relief and durability
TSB 568B (AT&T 258A)Wiring
TIA/EIA and UL Certified
Specifications
OVERVIEW
UPC Code
037332124319
Technology
Cat5/5e
POWER
Power Over Cable (PoC) Support
No
PHYSICAL
Cable Jacket Color
Gray
1/3
10-ft. (3.05 m) Gray Cat5e
Shielded STP Patch Cable
Cleveland, OH 44122
United States
Cable Jacket Material
PVC
Cable Jacket Rating
CM
Cable Shielding
STP
Cable Outer Diameter (OD)
5.9 mm
Number of Conductors
4 Pair
Conductor Material
Stranded Copper
Conductor Gauge
24 AWG
Cable Length (ft.)
10
Cable Length (m)
3.05
Cable Length (in.)
120
Cable Length (cm)
304.8
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 1.27
Shipping Weight (lbs.)
0.30
Shipping Weight (kg)
0.14
ENVIRONMENTAL
Operating Temperature Range
14 to 104 F (-10 to 40 C)
Storage Temperature Range
5 to 122 F (-15 to 50 C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
Bandwidth per TIA Standard
100 MHz
Maximum Bandwidth as Tested
350 MHz
Network Compatibility
1 Gbps (Gigabit)
IEEE Standards Supported
802.3ab; 802.3at
CONNECTIONS
Side A - Connector 1
RJ45 (MALE)
Side B - Connector 1
RJ45 (MALE)
Crossover Wiring
No
Contact Plating
Gold
PoE Type
Type 2 PoE+ (30W, IEEE 802.3at)
Connector Type
Molded
Wiring Configuration
EIA/TIA 568B
2/3
Cleveland, OH 44122
United States
Angled Connector
No
FEATURES & SPECIFICATIONS
IP68 Rated
No
Snagless Connector
No
Antibacterial
No
IP20 Rated
No
STANDARDS & COMPLIANCE
Product Certifications
UL Listed; cUL Listed
Product Compliance
CE (Europe); RoHS; IEEE 802.3ab 1000Base-T; IEEE 802.3at PoE+; REACH; UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N105-010-GY”相匹配的价格&库存,您可以联系我们找货
