N204-010-BL-DN
N204-010-BL-DN
    TRIPPLITE
    N204-010-BL-DN
N204-010-BL-DN 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Down-Angle Cat6 Gigabit Molded UTP Ethernet Cable (RJ45 Right-Angle Down M to RJ45 M), Blue, 10 ft. (3.05 m) MODEL NUMBER: N204-010-BL-DN Highlights ● Space saving design ● Right Angle Down connector to Straight ● Cat6 Gigabit rated System Requirements ● Use with Cat6, Cat5e, Cat5, or VoIP networks Package Includes ● Features ● 10-ft. (3.05 m) Blue Cat6, Right Angle Down to Straight RJ45 - RJ45 Patch cable ● PVC 4 Pair Stranded Conductors, 24AWG ● Fully Molded Ends ● ETL Verified to TIA/EIA -568-B ● 550Mhz Gigabit Speed Rated Specifications OVERVIEW UPC Code 037332167583 Technology Cat6 PHYSICAL Cable Jacket Color Blue Cable Jacket Material PVC Cable Jacket Rating CM Cable Shielding UTP Cable Outer Diameter (OD) 6.0 mm Number of Conductors 4 Pair Conductor Material Stranded Copper 1/3 10-ft. (3.05 m) Blue Cat6 Right Angle Down to Straight RJ45 RJ45 Patch cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Conductor Gauge 24 AWG Cable Length (ft.) 10 Cable Length (m) 3.05 Cable Length (in.) 120 Cable Length (cm) 304.8 Shipping Dimensions (hwd / in.) 0.20 x 8.00 x 9.00 Shipping Dimensions (hwd / cm) 0.51 x 20.32 x 22.86 Shipping Weight (lbs.) 0.34 Shipping Weight (kg) 0.15 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 250 MHz Maximum Bandwidth as Tested 500 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3an; 802.3at CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) - DOWN ANGLE Crossover Wiring No Contact Plating Gold PoE Type Type 2 PoE+ (30W, IEEE 802.3at) Connector Type Molded Wiring Configuration EIA/TIA 568B Angled Connector Yes FEATURES & SPECIFICATIONS IP68 Rated No Snagless Connector No Antibacterial No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N204-010-BL-DN 价格&库存
很抱歉,暂时无法提供与“N204-010-BL-DN”相匹配的价格&库存,您可以联系我们找货
