N125-010-GY
N125-010-GY
    TRIPPLITE
    N125-010-GY
N125-010-GY 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6 Gigabit Molded Shielded (FTP) Ethernet Cable (RJ45 M/M), PoE, Gray, 10 ft. (3.05 m) MODEL NUMBER: N125-010-GY Highlights ● Protect your network data from EMI/RFI interference ● Molded boot provides extra strain-relief and durability Package Includes ● Description Protect your high-speed network from noise and electromagnetic interference with Tripp Lite's 10-ft. (3.05 m) gray, Category 6 (Cat6) Shielded patch cable. This FTP cable features 2, shielded RJ45 50micron Gold molded male connectors with integral strain relief. The cable is manufactured from PVC, 4-pair, stranded shielded twisted pair, and is rated for 550MHz/1Gbps communication. Features ● Gigabit rated Cat6 Shielded Patch Cables ● Provides EMI/RFI shielding in Ethernet networks ● 4-pair 26 AWG Stranded FTP with drain wire ● Shielded RJ45, w/50-micron gold plated contacts ● Molded boot for extra strain-relief and durability ● TSB 568B (AT&T 258A)Wiring ● TIA/EIA and UL Certified Specifications OVERVIEW UPC Code 037332135421 Technology Cat6 POWER Power Over Cable (PoC) Support No PHYSICAL 1/3 10-ft. (3.05 m) Gray Cat6 Shielded FTP Patch Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Color Gray Cable Jacket Material PVC Cable Jacket Rating CMG Cable Shielding FTP Cable Outer Diameter (OD) 5.8 mm Number of Conductors 4 Pair Conductor Material Stranded Copper Conductor Gauge 26 AWG Cable Length (ft.) 10 Cable Length (m) 3.05 Cable Length (in.) 120 Cable Length (cm) 304.8 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.54 Shipping Weight (kg) 0.24 ENVIRONMENTAL Operating Temperature Range 14 to 104 F (-10 to 40 C) Storage Temperature Range 5 to 122 F (-15 to 50 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 250 MHz Maximum Bandwidth as Tested 500 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3an; 802.3at CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) Crossover Wiring No Contact Plating Gold PoE Type Type 2 PoE+ (30W, IEEE 802.3at) Connector Type Molded 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Wiring Configuration EIA/TIA 568B Angled Connector No FEATURES & SPECIFICATIONS IP68 Rated No Snagless Connector No Antibacterial No IP20 Rated No STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N125-010-GY 价格&库存
很抱歉,暂时无法提供与“N125-010-GY”相匹配的价格&库存,您可以联系我们找货
