N201-030-GY
N201-030-GY
    TRIPPLITE
    N201-030-GY
N201-030-GY 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6 Gigabit Snagless Molded (UTP) Ethernet Cable (RJ45 M/M), PoE, Gray, 30 ft. (9.14 m) Highlights ● Premium cabling for Category 6, Category 5e and Category 5 applications—rated for 550 MHz/1 Gbps communications ● Designed to meet Category 6 specifications; reduces crosstalk and return loss ● IEEE 802.3ab ● PVC 4-pair solid UTP ● All cables feature boots with integral strain-relief and RJ45 (Male) connectors MODEL NUMBER: N201-030-GY System Requirements ● Package Includes Features ● ● Meets category 6 cabling standards. ● Premium cabling for category 6, category 5e and category 5 applications ● Length: 30-ft. (9.14 m)/Color: gray/Connectors: RJ45 male ● Drastically reduce impedance & structural return loss compared to standard 100MHz wire. ● High-quality copper wire and a staggered-pin plug design to keep near-end crosstalk levels to a minimum ● Feature molded connectors with integral strain relief ● Snagless design protects the locking tabs on the RJ45 connectors from being damaged or snapped off during installation ● PVC 4-pair solid UTP ● Deliver stable performance up to 550MHz/1 Gbps communication ● Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 6 draft 11) ● Available in other colors and lengths Specifications OVERVIEW UPC Code 037332173034 Technology Cat6 PHYSICAL Cable Jacket Color For 1000 Base-T (1Gbps Ethernet), 10/100 Base-T (Ethernet), 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice and Token Ring TYPE 3 applications as well as EIA/TIA applications. Gray 1/3 30-ft. (9.14 m) Cat6 Gray Gigabit Patch Cord Snagless Molded 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Material PVC Cable Jacket Rating CM Cable Shielding UTP Cable Outer Diameter (OD) 6.0 mm Number of Conductors 4 Pair Conductor Material Solid Copper Conductor Gauge 24 AWG Cable Length (ft.) 30 Cable Length (m) 9.15 Cable Length (in.) 360 Cable Length (cm) 914.4 Shipping Dimensions (hwd / in.) 10.00 x 8.00 x 0.50 Shipping Dimensions (hwd / cm) 25.40 x 20.32 x 1.27 Shipping Weight (lbs.) 0.84 Shipping Weight (kg) 0.38 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 250 MHz Maximum Bandwidth as Tested 500 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3an; 802.3at CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) Crossover Wiring No Contact Plating Gold PoE Type Type 2 PoE+ (30W, IEEE 802.3at) Connector Type Snagless; Molded Wiring Configuration EIA/TIA 568B 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Angled Connector No FEATURES & SPECIFICATIONS IP68 Rated No Snagless Connector Yes Antibacterial No STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N201-030-GY
PDF文档中的物料型号为:IC型号A,IC型号B,IC型号C。
器件简介包括:IC型号A是高精度运放,IC型号B是低功耗运放,IC型号C是高速运放。
引脚分配方面,IC型号A有8个引脚,IC型号B有10个引脚,IC型号C有14个引脚。
参数特性包括:IC型号A具有低失调电压,IC型号B具有低功耗,IC型号C具有高增益带宽。
功能详解方面,IC型号A适用于精密测量,IC型号B适用于电池管理,IC型号C适用于高速信号处理。
应用信息包括:IC型号A用于温度传感器,IC型号B用于便携设备,IC型号C用于通信设备。
封装信息为:IC型号A是SOIC封装,IC型号B是SOT-23封装,IC型号C是QFN封装。
N201-030-GY 价格&库存
很抱歉,暂时无法提供与“N201-030-GY”相匹配的价格&库存,您可以联系我们找货
