N202-025-BL
N202-025-BL
    TRIPPLITE
    N202-025-BL
N202-025-BL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6 Gigabit Solid Conductor Snagless UTP Ethernet Cable (RJ45 M/M), PoE, Blue, 25 ft. (7.62 m) MODEL NUMBER: N202-025-BL Highlights ● Meets Category 6 cabling standards ● Solid Conductor 4 Pair Cable for long distance patch runs ● Drastically reduce impedance and structural return loss compared to Stranded Conductor patch cables ● High-quality copper wire and a shortened body plug design ● Snagless boots protect the locking tabs on the RJ45 connectors from being damaged during installation Package Includes ● Features ● 25-ft. (7.62 m) Blue Cat6 Solid Conductor patch cable ● Meets Category 6 cabling standards ● Solid Conductor 4 Pair Cable for long distance patch runs ● Drastically reduce impedance and structural return loss compared to Stranded Conductor patch cables ● High-quality copper wire and a shortened body plug design ● Snagless boots protect the locking tabs on the RJ45 connectors from being damaged during installation Specifications OVERVIEW UPC Code 037332157331 Technology Cat6 PHYSICAL Cable Jacket Color Blue Cable Jacket Material PVC Cable Jacket Rating CM Cable Shielding UTP Cable Outer Diameter (OD) 6.0 mm Number of Conductors 4 Pair 1/3 N202-025-BL, 25-ft. (7.62 m) Blue Cat6 Solid Conductor Patch cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Conductor Material Solid Copper Conductor Gauge 24 AWG Cable Length (ft.) 25 Cable Length (m) 7.62 Cable Length (in.) 300 Cable Length (cm) 762 Shipping Dimensions (hwd / in.) 10.00 x 8.00 x 0.50 Shipping Dimensions (hwd / cm) 25.40 x 20.32 x 1.27 Shipping Weight (lbs.) 0.70 Shipping Weight (kg) 0.32 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 250 MHz Maximum Bandwidth as Tested 500 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3an; 802.3at CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) Crossover Wiring No Contact Plating Gold PoE Type Type 2 PoE+ (30W, IEEE 802.3at) Connector Type Snagless Wiring Configuration EIA/TIA 568B Angled Connector No FEATURES & SPECIFICATIONS IP68 Rated No Snagless Connector Yes Antibacterial No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N202-025-BL 价格&库存
很抱歉,暂时无法提供与“N202-025-BL”相匹配的价格&库存,您可以联系我们找货
