N261-010-BK
N261-010-BK
    TRIPPLITE
    PATCHCABLE
N261-010-BK 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6a 10G Snagless UTP Ethernet Cable (RJ45 M/M), Black, 10 ft. (3.05 m) MODEL NUMBER: N261-010-BK Highlights ● 10-ft. (3.05 m) Augmented Cat6 (CAT6a) Unshielded (UTP) Snagless Patch Cable, Black ● 10Gbps Over Copper ● Each cable Fluke® Tested and Verified Package Includes ● Description Tripp Lite's N261-010-BK 10-ft. (3.05 m) Black Augmented Cat6 (Cat6a) Unshielded (UTP) Snagless patch cable allows 10Gbps data transmission over 4-pair copper. Each Cat6a cable is individually tested and certified on Fluke® test equipment. Snag-free strain relief boot provides the most secure and accurate connections. Features ● 10-ft. (3.05 m) Black Cat6a Unshielded (UTP) Snagless Patch Cable - 10Gbps ● 100% FLUKE® tested and certified ● ETL/UL Verified ● Supports IEEE 802.3af and is DTE power compliant ● Backward compatible with all previous 10BaseT generations ● RJ45 plug improves NEXT performance to 500Mhz ● 24AWG, 4-Pair, Stranded PVC cable ● Compatible with T568A and T568B wiring ● Easy disconnect snagless hood ● PoE rated to four times the standard Specifications OVERVIEW UPC Code 037332187673 Technology Cat6a PHYSICAL 1/3 10-ft. (3.05 m) Cat6a Black Patch Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating FT4 Cable Shielding UTP Cable Outer Diameter (OD) 6.2 mm Number of Conductors 4 Pair Conductor Material Stranded Copper Conductor Gauge 24 AWG Cable Length (ft.) 10 Cable Length (m) 3.05 Cable Length (in.) 120 Cable Length (cm) 304.8 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.27 Shipping Weight (kg) 0.12 ENVIRONMENTAL Operating Temperature Range 14 to 104 F (-10 to 40 C) Storage Temperature Range 5 to 122 F (-15 to 50 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 500 MHZ Maximum Bandwidth as Tested 600 MHz Network Compatibility 10 Gbps IEEE Standards Supported 802.3an; 802.3at CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) Crossover Wiring No Contact Plating Gold PoE Type Type 2 PoE+ (30W, IEEE 802.3at) Connector Type Snagless 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Wiring Configuration EIA/TIA 568B Angled Connector No FEATURES & SPECIFICATIONS IP68 Rated No Snagless Connector Yes Antibacterial No STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N261-010-BK 价格&库存
很抱歉,暂时无法提供与“N261-010-BK”相匹配的价格&库存,您可以联系我们找货
