1000 Eaton Boulevard
Cleveland, OH 44122
United States
Cat6a 10G Snagless UTP Ethernet Cable (RJ45
M/M), Black, 14 ft. (4.27 m)
MODEL NUMBER: N261-014-BK
Highlights
14-ft. (4.27 m) Augmented Cat6
(CAT6a) Unshielded (UTP)
Snagless Patch Cable, Black
10Gbps Over Copper
Each cable Fluke® Tested and
Verified
Package Includes
Description
Tripp Lite's N261-014-BK 14-ft. (4.27 m) Black Augmented Cat6 (Cat6a) Unshielded (UTP) Snagless
patch cable allows 10Gbps data transmission over 4-pair copper. Each Cat6a cable is individually tested
and certified on Fluke® test equipment. Snag-free strain relief boot provides the most secure and accurate
connections.
Features
14-ft. (4.27 m) Black Cat6a Unshielded (UTP) Snagless Patch Cable - 10Gbps
100% FLUKE® tested and certified
ETL/UL Verified
Supports IEEE 802.3af and is DTE power compliant
Backward compatible with all previous 10BaseT generations
RJ45 plug improves NEXT performance to 500Mhz
24AWG, 4-Pair, Stranded PVC cable
Compatible with T568A and T568B wiring
Easy disconnect snagless hood
PoE rated to four times the standard
Specifications
OVERVIEW
UPC Code
037332187697
Technology
Cat6a
PHYSICAL
1/3
14-ft. (4.27 m) Cat6a Black
Patch Cable
Cleveland, OH 44122
United States
Cable Jacket Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
FT4
Cable Shielding
UTP
Cable Outer Diameter (OD)
6.2 mm
Number of Conductors
4 Pair
Conductor Material
Stranded Copper
Conductor Gauge
24 AWG
Cable Length (ft.)
14
Cable Length (m)
4.27
Cable Length (in.)
168
Cable Length (cm)
426.7
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 1.27
Shipping Weight (lbs.)
0.44
Shipping Weight (kg)
0.20
ENVIRONMENTAL
Operating Temperature Range
14 to 104 F (-10 to 40 C)
Storage Temperature Range
5 to 122 F (-15 to 50 C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
Bandwidth per TIA Standard
500 MHZ
Maximum Bandwidth as Tested
600 MHz
Network Compatibility
10 Gbps
IEEE Standards Supported
802.3an; 802.3at
CONNECTIONS
Side A - Connector 1
RJ45 (MALE)
Side B - Connector 1
RJ45 (MALE)
Crossover Wiring
No
Contact Plating
Gold
PoE Type
Type 2 PoE+ (30W, IEEE 802.3at)
Connector Type
Snagless
2/3
Cleveland, OH 44122
United States
Wiring Configuration
EIA/TIA 568B
Angled Connector
No
FEATURES & SPECIFICATIONS
IP68 Rated
No
Snagless Connector
Yes
Antibacterial
No
STANDARDS & COMPLIANCE
Product Certifications
UL Listed; cUL Listed
Product Compliance
CE (Europe); RoHS; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N261-014-BK”相匹配的价格&库存,您可以联系我们找货
