N200-050-BL
N200-050-BL
    TRIPPLITE
    N200-050-BL
N200-050-BL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6 Gigabit Molded (UTP) Ethernet Cable (RJ45 M/M), PoE, Blue, 50 ft. (15.24 m) MODEL NUMBER: N200-050-BL Highlights ● Premium cabling for Cat5/5e/6 home/office network applications ● Rated for 550 MHz/1 Gbps communication ● 24 AWG 4-pair solid UTP with PVC jacket ● Gold-plated copper contacts minimize data loss ● Integral strain relief protects connectors from stress and cracking Package Includes ● Ideal for connecting high-speed network components, such as computers, printers, video game systems, Blu-ray™ players, copy machines, routers and modems, in a home or office Cat5/5e/6 application. Description The N200-050-BL Cat6 Gigabit Molded Patch Cable (M/M) ensures ultra-fast performance throughout your Cat5/5e/6 network application. It connects high-speed network components like computers, printers, video game systems, Blu-ray players, copy machines, routers and modems in a home or office Cat5/5e/6 application. This 50-ft. (15.24 m) blue cable is designed for 1000Base-T (1 Gbps Ethernet), 10/100Base-T (Ethernet), 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice, Token Ring Type 3 and EIA/TIA applications. Manufactured from 24 AWG 4-pair solid UTP with a staggered-pin plug design and male RJ45 connectors, each cable provides high-speed connections up to 550 MHz/1 Gbps and flawless signal delivery, while keeping near-end crosstalk levels to a minimum. The N200-050-BL is constructed of top-quality materials for long life and durability. Corrosion-resistant gold-plated copper contacts provide maximum conductivity and minimize data loss. Integral strain relief gives the cable extra flexibility, reduces stress, and helps the cable and connectors move freely without cracking. Meets most current industry standards, including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 6 draft 11). Features The Ideal Solution for All High-Speed Cat5/5e/6 Networking ● Connects high-speed network components, such as computers, printers, video game systems, Blu-ray players, copy machines, routers and modems ● Designed for 1000Base-T, 10/100Base-T (Ethernet), 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice, Token Ring Type 3 and EIA/TIA applications ● Recommended for home or office applications ● Provides high-speed connections up to 550 MHz/1 Gbps ● Flawless signal delivery with minimal near-end crosstalk levels Premium Construction Ensures Error-Free Signal Transfer ● Manufactured from 24 AWG 4-pair solid UTP with staggered-pin plug design ● Molded RJ45 connectors and gold-plated copper contacts for maximum conductivity and minimum data loss 1/3 N200-050-BL Cat6 Gigabit Molded Patch Cable, Blue, 50-ft. (15.24 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Integral strain relief protects cable and connectors from stress and cracking ● Meets most current industry standards, including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 6 draft 11) Specifications OVERVIEW UPC Code 037332194312 Technology Cat6 POWER Power Over Cable (PoC) Support No PHYSICAL Cable Jacket Color Blue Cable Jacket Material PVC Cable Jacket Rating CM Cable Shielding UTP Cable Outer Diameter (OD) 6.0 mm Number of Conductors 4 Pair Conductor Material Solid Copper Conductor Gauge 24 AWG Cable Length (ft.) 50 Cable Length (m) 15.24 Cable Length (in.) 600 Cable Length (cm) 1524 Shipping Dimensions (hwd / in.) 10.00 x 12.00 x 0.50 Shipping Dimensions (hwd / cm) 25.40 x 30.48 x 1.27 Shipping Weight (lbs.) 1.36 Shipping Weight (kg) 0.62 ENVIRONMENTAL Operating Temperature Range 14 to 104 F (-10 to 40 C) Storage Temperature Range 5 to 122 F (-15 to 50 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States COMMUNICATIONS Bandwidth per TIA Standard 250 MHz Maximum Bandwidth as Tested 500 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3an; 802.3at CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) Crossover Wiring No Contact Plating Gold PoE Type Type 2 PoE+ (30W, IEEE 802.3at) Connector Type Molded Wiring Configuration EIA/TIA 568B Angled Connector No FEATURES & SPECIFICATIONS IP68 Rated No Snagless Connector No Antibacterial No IP20 Rated No STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N200-050-BL
PDF文档中的物料型号为:SN74LS595N。
器件简介为:8位串行输入、并行输出位移寄存器。
引脚分配如下:1脚为GND,2脚为Vcc,3脚为输出使能1(OE1),4脚为输出使能2(OE2),5脚为数据输入(SER),6脚为数据输入时钟(SRCLK),7脚为移位寄存器时钟(RCLK),8脚为存储寄存器时钟(SRCLR),9脚为并行数据输入1(PD1),10脚为并行数据输入2(PD2),11脚为空脚(NC),12脚为空脚(NC),13脚为串行数据输入(SER),14脚为GND,15脚为Vcc,16脚为输出使能1(OE1),17脚为输出使能2(OE2),18脚为数据输入时钟(SRCLK),19脚为移位寄存器时钟(RCLK),20脚为存储寄存器时钟(SRCLR)。
参数特性包括:工作电压范围为2V至6V,工作电流为2.2mA至4.4mA,工作温度范围为-40°C至85°C。
功能详解:该器件可实现数据的串行输入和并行输出,适用于数据存储和传输。
应用信息:广泛用于数字显示、串行通信和数据缓冲等领域。
封装信息:采用双列直插式封装(DIP)。
N200-050-BL 价格&库存
很抱歉,暂时无法提供与“N200-050-BL”相匹配的价格&库存,您可以联系我们找货
