N001-100-BL
N001-100-BL
    TRIPPLITE
    MOLDEDCABLERJ45M/MBLUE100'
N001-100-BL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat5e 350 MHz Snagless Molded (UTP) Ethernet Cable (RJ45 M/M), PoE - Blue, 100 ft. (30.5 m) Highlights ● Premium cabling for Category 5 and 5e applications—rated for 350 MHz/1 Gbps communications ● IEEE 802.3ab ● PVC 4-pair stranded UTP ● All cables feature boots with integral strain-relief and RJ45 (Male) connectors MODEL NUMBER: N001-100-BL System Requirements ● For 1000Base-T (1Gbps Ethernet), 10/100Base-T (Ethernet), 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice and Token Ring Type3 applications. Package Includes ● Description Tripp Lite's 100-ft. (30.5 m) Blue snagless category 5e (Cat5e) patch cable has 2 snagless RJ45 molded male connectors featuring integral strain relief. The cable is manufactured from PVC 4-pair stranded UTP and is rated for 350MHz/1Gbps communication. All cables are offered in a variety of lengths and colors for all category 5 (Cat5) and 5e cabling needs. Standard, non-snagless category 5e patch cables are also available (N002-Series). Features ● Cabling for category 5 (Cat5) and 5e (Cat5e) applications ● Length: 100-ft. (30.5 m) color: Blue connectors: RJ45 male ● Feature molded connectors with integral strain relief ● Snagless design protects the locking tabs on the RJ45 connectors from being damaged or snapped off during installation ● PVC 4-pair stranded UTP ● Rated for 350MHz/ 1Gbps communication ● Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 5e draft 11) ● Available in other colors and lengths ● Also available without the snagless feature (N002-Series) ● Also available - Cat6 cables (N201-Series) Specifications OVERVIEW UPC Code 037332176516 Technology Cat5/5e 1/3 100-ft. (30.5 m) Blue Snagless Cat5e Patch Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States POWER Power Over Cable (PoC) Support No PHYSICAL Cable Jacket Color Blue Cable Jacket Material PVC Cable Jacket Rating CM Cable Shielding UTP Cable Outer Diameter (OD) 5.0 mm Number of Conductors 4 Pair Conductor Material Solid Copper Conductor Gauge 26 AWG Cable Length (ft.) 100 Cable Length (m) 30.49 Cable Length (in.) 1200 Cable Length (cm) 3048 Shipping Dimensions (hwd / in.) 14.00 x 17.00 x 0.50 Shipping Dimensions (hwd / cm) 35.56 x 43.18 x 1.27 Shipping Weight (lbs.) 2.00 Shipping Weight (kg) 0.91 ENVIRONMENTAL Operating Temperature Range 14 to 104 F (-10 to 40 C) Storage Temperature Range 5 to 122 F (-15 to 50 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 100 MHz Maximum Bandwidth as Tested 350 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3ab; 802.3at CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Crossover Wiring No Contact Plating Gold PoE Type Type 2 PoE+ (30W, IEEE 802.3at) Connector Type Molded; Snagless Wiring Configuration EIA/TIA 568B Angled Connector No FEATURES & SPECIFICATIONS IP68 Rated No Snagless Connector No Antibacterial No IP20 Rated No STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3ab 1000Base-T; IEEE 802.3at PoE+; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N001-100-BL 价格&库存
很抱歉,暂时无法提供与“N001-100-BL”相匹配的价格&库存,您可以联系我们找货
