N261-025-AQ
N261-025-AQ
    TRIPPLITE
    N261-025-AQ
N261-025-AQ 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6a 10G Snagless UTP Ethernet Cable (RJ45 M/M), Aqua, 25 ft. (7.62 m) MODEL NUMBER: N261-025-AQ Highlights ● Next Generation Cat6 - CAT6a ( Augmented ) ● 10Gbps Over Copper to 100mtr ● Each cable Fluke® Tested and Verified ● 25-ft. (7.62 m) cable Package Includes ● Features ● 25-ft. (7.62 m) 10Gig over copper patch cable ● 100% FLUKE® tested and certified ● ETL/UL Verified ● Supports IEEE 802.3af and is DTE power compliant ● Backward compatible with all previous 10BaseT generations ● New Cat6 RJ45 plug improves NEXT performance to 500Mhz ● 24ga, 4pr, Stranded PVC cable ● Compatible with T568A and T568B wiring ● Easy disconnect snagless hood ● PoE rated to four times the standard Specifications OVERVIEW UPC Code 037332131737 Technology Cat6a PHYSICAL Cable Jacket Color Aqua Cable Jacket Material PVC Cable Jacket Rating FT4 Cable Shielding UTP 1/3 25-ft. (7.62 m) Cat6a Aqua Patch Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Outer Diameter (OD) 6.2 mm Number of Conductors 4 Pair Conductor Material Stranded Copper Conductor Gauge 24 AWG Cable Length (ft.) 25 Cable Length (m) 7.62 Cable Length (in.) 300 Cable Length (cm) 762 Shipping Dimensions (hwd / in.) 0.50 x 5.80 x 8.40 Shipping Dimensions (hwd / cm) 1.27 x 14.73 x 21.34 Shipping Weight (lbs.) 0.50 Shipping Weight (kg) 0.23 ENVIRONMENTAL Operating Temperature Range 14 to 104 F (-10 to 40 C) Storage Temperature Range 5 to 122 F (-15 to 50 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 500 MHZ Maximum Bandwidth as Tested 600 MHz Network Compatibility 10 Gbps IEEE Standards Supported 802.3an; 802.3at CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) Crossover Wiring No Contact Plating Gold PoE Type Type 2 PoE+ (30W, IEEE 802.3at) Connector Type Snagless Wiring Configuration EIA/TIA 568B Angled Connector No FEATURES & SPECIFICATIONS IP68 Rated No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Snagless Connector Yes Antibacterial No STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N261-025-AQ 价格&库存
很抱歉,暂时无法提供与“N261-025-AQ”相匹配的价格&库存,您可以联系我们找货
