09473434204
09473434204
    HARTING(浩亭)
09473434204 数据手册
HARTING Generic Cabling List of contents Page Distribution modules and Outlets HARTING Cabinet Outlet RJ45 . .......................................................... C·G   3 HARTING PushPull Outlet RJ45 . ........................................................ C·G   4 Generic Cabling Introduction ...................................................................................................... C·G   2 Panel feed-throughs HARTING PushPull Panel feed-through RJ45 . .................................. C·G   6 System cables Industrial Ethernet Patch cable RJ45, 8-wire ....................................... HARTING RJ Industrial® System cable RJ45, 8-wire .......................... HARTING PushPull System cable RJ45, 8-wire .................................. Han® 3 A System cable RJ45, 8-wire . ................................................. C·G   8 C·G   9 C·G 10 C·G 11 Connector sets HARTING RJ Industrial® Connector set RJ45, 8-pole ......................... C·G 12 HARTING PushPull Connector set RJ45, 8-pole ................................. C·G 14 Han® 3 A Connector set RJ45, 8-pole . ................................................ C·G 16 Cables Industrial Cat. 6 cable, stranded, 8-wire, PVC .................................... Industrial Cat. 6 cable, stranded, 8-wire, PUR .................................... Industrial Cat. 5 outdoor cable, 8-wire ................................................. Industrial Cat. 5 cable, stranded, 8-wire .............................................. C·G 18 C·G 19 C·G 20 C·G 21 C·G  HARTING Generic Cabling Generic Cabling Introduction The chapter “Generic Cabling” shows HARTING‘s complete cabling portfolio, which simply and efficiently networks machinery, equipment and controllers. “Generic” here stands for profile independent, which means that the cabling infrastructure is laid out with IEEE 802.3 as the fundamental transfer protocol and consequently all cables and connectors are 8-wire. With this every Ethernet based protocol and / or profile can be carried over the cabling infrastructure. In order to guarantee that the cabling system is ­future-proof, the portfolio is oriented towards the current European and International cabling standards, for example ISO/IEC 24 702 and the draft European standard prEN 50 173-1: 2006. The use of connector types specified in the above standards in all components, for example the HARTING PushPull RJ45, offers the user a high degree of compatibility, reduces equipment maintenance and handling, decreases stock of replacement parts and thereby substantially reduces costs. The generic cabling system‘s product portfolio covers: Distributors and Connector boxes: ­Termina­tion and distribution of cables in harsh IP 65 / IP 67 environments, but also within control or distribution cabinets. l Panel feed-throughs: To ensure cable introduction from IP 65 / IP 67 environments into control or distribution cabinets. l System cables: Made-up system cables for quick connection of terminal boxes, distributors or active devices with machines, equipment and controllers. l Connectors: Connector sets to make up specific system cables onsite. l Cables: A comprehensive cable portfolio for the laying out / manufacture of system cables onsite. l The advantages of the HARTING generic cabling system at-a-glance: Profile independent cabling structure, usable for all Ethernet applications l Supports all safety features and real-time requirements of the diverse applications l Can be expanded and integrated into existing IT infrastructures without problems l HARTING‘s generic cabling system also allows the seamless integration of machinery, equipment and controller networks into the customer‘s existing IT network. A large variety of process control functions can now be initiated or monitored from supervisory computers without modification or other efforts. System resources such as databases can be made available to or fed by all network connected devices. Operator workflows and processes can be made continuously simpler, faster and more efficient. This generic cabling system is part of HARTING‘s comprehensive Automation IT network solution, which brings together active network technology, cabling and solutions for device and equipment power supply. C·G  Conformance to ISO/IEC 24 702 makes roll-outs easier in international firms l Use of standardised connectors reduces the variety of parts and makes purchasing and stocking of components easier l Future-proof cabling and connectors allow the problem-free deployment of new technology such as Gigabit Ethernet or PoE l The high quality of the cabling system guarantees a long useful life and reliable operations l Simple planning, installation and reliable operation saves costs and delivers a high ROI l The generic cabling system is part of HARTING‘s one-stop Automation IT network solution l HARTING Generic Cabling HARTING Cabinet Outlet RJ45 RJ45 distribution module for IP 20 environments (top-hat rail mounting) IP 20 X IP 65 / IP 67 to IP 20 IP 65 / IP 67 Cat. 5 Cat. 6 Number of ports, Copper / Termination Transmission performance Transmission rate Termination 2 / RJ45 (Twisted Pair) Category 6 / Class E up to 250 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s LSA-PLUS module, terminated without special tools Strand diameter Strand isolation Cable diameter Shielding AWG 24 - 22 (0.5 mm - 0.65 mm) solid and stranded 0.7 mm - 1.6 mm 6 mm - 9 mm fully shielded, 360° shielding contact Mounting Dimensions (H x W x D) Degree of protection Operating temperature range Housing material Colour mounting onto 35 mm top-hat mounting rail acc. to DIN EN 60 715, alignable 82 x 28.4 x 74 mm IP 20 – 20 °C to + 70 °C Polycarbonate, V0 light grey RAL 7035 Advantages Simple mounting Cable entering ether from bottom or from top Dust protection covers Port identification Angled outputs Identification Part number Drawing X Generic Cabling Distribution modules and Outlets Dimensions in mm HARTING Cabinet Outlet RJ45 consisting of: 2 port-housing including dust protection cover and labels 2x RJ45 female modules, Category 6 Assembly instructions 20 76 102 8000 C·G  HARTING Generic Cabling Generic Cabling Distribution modules and Outlets HARTING PushPull Outlet RJ45 RJ45 Industrial Outlet for IP 65 / IP 67 environments IP 20 IP 65 / IP 67 X IP 65 / IP 67 to IP 20 2 / RJ45 PushPull (IP 65 / IP 67) Category 6 / Class E up to 250 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s LSA-PLUS module, terminated without special tools Strand diameter Strand isolation Cable diameter Shielding AWG 24 - 22 (0.5 mm - 0.65 mm) solid and stranded 0.7 mm - 1.6 mm 6 mm - 9 mm fully shielded, 360° shielding contact Mounting Dimensions (H x W x D) Degree of protection Operating temperature range Housing material Colour Wall mounting 152 x 90 x 69 mm IP 65 / IP 67 – 20 °C to + 70 °C Polycarbonate, V0, UL 94-0 Black (similar RAL 9011) or White (similar RAL 9010) Advantages Simple mounting Cable entering ether from bottom or from top Self-close protection covers in IP 65 / IP 67 IP 65 / IP 67 label Part number HARTING PushPull Outlet RJ45 Black white  Cat. 6 Number of ports, Copper / Termination Transmission performance Transmission rate Termination Identification C·G Cat. 5 consisting of: 2 port-outlet housing with protection covers, cable management, cable glands and label 2x RJ45 female modules, Category 6 1x blind plug (if only only 1 cable is used) Assembly instructions 09 45 845 1500 09 45 845 1501 Drawing X Dimensions in mm Generic Cabling Notes C·G  HARTING Generic Cabling Generic Cabling Panel feed-throughs HARTING PushPull Panel feed-through RJ45 RJ45 panel feed-through for control or distributor cabinets IP 20 IP 65 / IP 67 Number of ports, Copper / Termination C·G  IP 65 / IP 67 to IP 20 X Cat. 5 X Cat. 6 Transmission performance Transmission rate 2 / 1x RJ45 (Twisted Pair) (IP 20) 1x RJ45 PushPull (IP 65 / IP 67) Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s Shielding fully shielded, 360° shielding contact Mounting Dimensions Panel cut-out Mounting hole Degree of protection Operating temperature range Housing material Colour screw-on type on steel plate walls see drawing 21 mm x 27 mm M2.5 IP 65 / IP 67 – 40 °C to + 70 °C Polyamide, UL 94-V0 Black Advantages Small, space-saving PushPull interface with IP 65 / IP 67 Easy handling of RJ45 system cables in the control cabinet HARTING Generic Cabling Identification Part number Drawing Dimensions in mm HARTING PushPull Panel feed-through RJ45 09 45 245 1102 Generic Cabling consisting of: Housing bulkhead mounting including flat gasket RJ45 female module mounted on PCB Assembly instructions IEC 60603.7 modular jack Protection cover for panel feed-through 09 45 845 0004 C·G  HARTING Generic Cabling Generic Cabling System cables HARTING Industrial Ethernet Patch cable RJ45, 8-wire RJ45 connection cable for control or distributor cabinets or within controllers IP 20 X IP 65 / IP 67 IP 65 / IP 67 to IP 20 Cat. 6 RJ45, overmoulded 4 x 2, Twisted Pair, shielded PUR, halogen-free LSZH 8-pole, 1:1 Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s fully shielded, 360° shielding contact – 20 °C to + 60 °C Standard lengths Colour 0.5 m / 1 m / 2 m / 3 m / 5 m / 7.5 m other lengths on request Black or Green Advantages Robust design Easy handling for all applications Part number HARTING Industrial Ethernet Patch cable RJ45, 8-wire  X Connector types Cable types Sheath material Wiring Transmission performance Transmission rate Shielding Operating temperature range Identification C·G Cat. 5 Length 0.5 m Length 1.0 m Length 2.0 m Length 3.0 m Length 5.0 m Length 7.0 m Black Green 09 45 971 1121 09 45 971 1122 09 45 971 1123 09 45 971 1124 09 45 971 1126 09 45 971 1129 09 45 971 1101 09 45 971 1102 09 45 971 1103 09 45 971 1104 09 45 971 1106 09 45 971 1109 HARTING Generic Cabling HARTING RJ Industrial® System cable RJ45, 8-wire RJ45 connection cable for control or distributor cabinets or within controllers IP 20 X IP 65 / IP 67 IP 65 / IP 67 to IP 20 Cat. 5 Cat. 6 Connector types Cable types Sheath material Wiring Transmission performance Transmission rate Shielding Operating temperature range RJ45 4 x 2, Twisted Pair, shielded, PIMF PVC 8-pole, 1:1 Category 6 / Class E up to 250 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s fully shielded, 360° shielding contact – 10 °C to + 70 °C Standard lengths Colour 1.5 m / 3 m / 5 m / 10 m / 20 m other lengths on request Green Advantages Robust industrial design High operation reliability in case of vibrations too Identification Part number Drawing X Generic Cabling System cables Dimensions in mm HARTING RJ Industrial System cable RJ45, 8-wire Green Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m 09 45 751 1523 09 45 751 1525 09 45 751 1527 09 45 751 1551 09 45 751 1553 C·G  HARTING Generic Cabling Generic Cabling System cables HARTING PushPull System cable RJ45, 8-wire RJ45 connection cable PushPull for IP 65 / IP 67 applications IP 20 IP 65 / IP 67 Cat. 5 Cat. 6 RJ45 PushPull 4 x 2, Twisted Pair, shielded, PIMF PVC 8-pole, 1:1 Category 6 / Class E up to 250 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s fully shielded, 360° shielding contact – 10 °C to + 70 °C Standard lengths Colour 1.5 m / 3 m / 5 m / 10 m / 20 m other lengths on request Green Advantages Standardised PushPull interface for IP 65 / IP 67 Easy and safe operation Especially space-saving Part number HARTING PushPull System cable RJ45, 8-wire Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m 10 IP 65 / IP 67 to IP 20 Connector types Cable types Sheath material Wiring Transmission performance Transmission rate Shielding Operating temperature range Identification C·G X Green 09 45 745 1523 09 45 745 1525 09 45 745 1527 09 45 745 1551 09 45 745 1553 Drawing X Dimensions in mm HARTING Generic Cabling Han® 3 A System cable RJ45, 8-wire RJ45 connector cable Han® 3 A for IP 65 / IP 67 applications IP 20 IP 65 / IP 67 X IP 65 / IP 67 to IP 20 Cat. 5 Cat. 6 Connector types Han® 3 A RJ45 Cable types Sheath material Wiring Transmission performance Transmission rate Shielding Operating temperature range 4 x 2, Twisted Pair, shielded, PIMF PVC 8-pole, 1:1 Category 6 / Class E up to 250 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s fully shielded, 360° shielding contact – 10 °C to + 70 °C Standard lengths Colour 1.5 m / 3 m / 5 m / 10 m / 20 m other lengths on request Green Advantages Very robust metal housing Han® 3 A for IP 65 / IP 67 Additional locking Identification Part number Han® 3 A System cable RJ45, 8-wire Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m Drawing X Generic Cabling System cables Dimensions in mm Green 09 45 715 1523 09 45 715 1525 09 45 715 1527 09 45 715 1551 09 45 715 1553 C·G 11 HARTING Generic Cabling Generic Cabling Connector sets HARTING RJ Industrial® Connector set RJ45, 8-pole to make up RJ45 system cables IP 20 X IP 65 / IP 67 IP 65 / IP 67 to IP 20 Cat. 5 Cat. 6 Connector type Number of contacts Transmission performance Transmission rate RJ45 connector acc. to IEC 60 603-7 8 Category 6 / Class E up to 250 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s Shielding fully shielded, 360° shielding contact Mounting Wire termination Field-assembly possible via piercing contacts Cable options – Strand diameter – Cable sheath diameter Degree of protection Operating temperature range Housing material Colour AWG 42/7 - AWG 27/7 6.5 mm - 6.9 mm IP 20 – 40 °C to + 70 °C Polycarbonate, UL 94-V0 Black Advantages Field-assembly connector, Cat. 6 X Mounting information If the cable is assembled on both sides, please use one connector set with white and one connector set with blue cable manager (delivers optimal transmission behavior) C·G 12 HARTING Generic Cabling Part number HARTING RJ Industrial® Connector set RJ45, 8-pole with cable manager White cable manager Blue Drawing Dimensions in mm mating face according to IEC 60 603-7 Generic Cabling Identification 09 45 151 1500 09 45 151 1510 Set consists of: Housing including shielding Cable gland Assembly instructions contact no. 8 contact no. 1 Mounting tools for RJ45 connector set 09 45 800 0500 C·G 13 HARTING Generic Cabling Generic Cabling Connector sets HARTING PushPull Connector set RJ45, 8-pole to make up PushPull system cables RJ45 IP 20 IP 65 / IP 67 X IP 65 / IP 67 to IP 20 Cat. 5 Cat. 6 X Connector type PushPull connector RJ45 acc. to IEC 24 702 Number of contacts 8 Transmission performance Category 6 / Class E up to 250 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 Transmission rate 10/100/1000 Mbit/s Shielding fully shielded, 360° shielding contact Mounting Wire termination Field-assembly possible via piercing contacts Cable options – Strand diameter – Cable sheath diameter Degree of protection Operating temperature range Housing material Colour AWG 42/7 - AWG 27/7 6.5 mm - 8.6 mm IP 65 / IP 67 – 40 °C to + 70 °C Polyamide, UL 94-V0 Black Advantages Space-saving connector assembly via PushPull interface Field-assembly connector, Cat. 6, in IP 65 / IP 67 Mounting information If the cable is assembled on both sides, please use one connector set with white and one connector set with blue cable manager (delivers optimal transmission behavior) C·G 14 HARTING Generic Cabling Part number HARTING PushPull Connector set RJ45, 8-pole with cable manager White cable manager Blue Drawing Dimensions in mm mating face according to IEC 60 603-7 Generic Cabling Identification 09 45 145 1500 09 45 145 1510 Set consists of: PushPull housing including RJ45 connector and shielding Cable gland Assembly instructions contact no. 8 contact no. 1 Protection cover for PushPull connectors 09 45 845 0001 Mounting tools for RJ45 connector set 09 45 800 0500 C·G 15 HARTING Generic Cabling Generic Cabling Connector sets Han® 3 A Connector set RJ45, 8-pole to make up Han® 3 A system cables RJ45 IP 20 IP 65 / IP 67 X IP 65 / IP 67 to IP 20 Cat. 5 Cat. 6 Connector type Han® 3 A connector RJ45 Number of contacts Transmission performance Transmission rate 8 Category 6 / Class E up to 250 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s Shielding fully shielded, 360° shielding contact Mounting Wire termination Field-assembly possible via piercing contacts Cable options – Strand diameter – Cable sheath diameter Degree of protection Operating temperature range AWG 42/7 - AWG 27/7 6.5 mm - 6.9 mm IP 65 / IP 67 – 40 °C to + 70 °C Plastic version Housing material Colour Polyamide, UL 94-V0 Black Metal version Standard Housing material Colour Zinc, die-cast Grey Metal version M Housing material Colour Zinc, die-cast, chromatised, powder coated Black Advantages Very robust metal housing Field-assembly connector, Cat. 6, IP 65 / IP 67 X Mounting information If the cable is assembled on both sides, please use one connector set with white and one connector set with blue cable manager (delivers optimal transmission behavior) C·G 16 HARTING Generic Cabling Part number Han® 3 A Connector set RJ45, 8-pole Drawing Dimensions in mm mating face according to IEC 60 603-7 Plastic version with cable manager White cable manager Blue 09 45 125 1500 09 45 125 1510 Metal version Standard with cable manager White cable manager Blue 09 45 115 1500 09 45 115 1510 Metal version M with cable manager White cable manager Blue 09 45 115 1502 09 45 115 1512 Generic Cabling Identification Dimensions valid for Metal version Standard Set consists of: Han® 3 A housing including RJ45 connector and shielding Cable gland Assembly instructions Protection cover for Han® 3 A connector Plastic version Metal version Standard Metal version M 09 20 003 5442 09 20 003 5422 09 37 003 5402 Dimensions valid for Plastic version Mounting tools for RJ45 connector set 09 45 800 0500 C·G 17 HARTING Generic Cabling Generic Cabling Cables Industrial Cat. 6 cable, stranded, 8-wire, PVC to make up flexible connections (one- or two-sided assembled system cables) IP 20 X IP 65 / IP 67 X PVC 4 x 2, Twisted Pair, shielded, PIMF Cord, 4 x 2 x AWG 27/7 PVC 6.8 mm Category 6 / Class E up to 250 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s each pair shielded and additional shield for the whole cable – 10 °C to + 70 °C Standard lengths Colour 20 m / 50 m / 100 m / 500 m Green Advantages Robust industrial-compatible design Optimal power reserves Part number Industrial Cat. 6 cable, stranded, 8-wire PVC   20 m ring   50 m ring 100 m ring 500 m drum 18 Cat. 6 Cable structure Core structure Sheath material Cable sheath diameter Transmission performance Transmission rate Shielding Operating temperature range Identification C·G Cat. 5 09 45 600 0530 09 45 600 0540 09 45 600 0500 09 45 600 0520 Drawing X Dimensions in mm HARTING Generic Cabling Industrial Cat. 6 cable, stranded, 8-wire, PUR to make up flexible connections (one- or two-sided assembled system cables) IP 20 X IP 65 / IP 67 X PUR, halogen-free Cat. 5 Cat. 6 Cable structure Core structure Sheath material Cable sheath diameter Transmission performance Transmission rate Shielding Operating temperature range 4 x 2, Twisted Pair, shielded, PIMF Cord, 4 x 2 x AWG 27/7 PUR, halogen-free 6.8 mm Category 6 / Class E up to 250 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s each pair shielded and additional shield for the whole cable – 40 °C to + 70 °C Standard lengths Colour 20 m / 50 m / 100 m / 500 m Green Advantages Robust industrial-compatible design Halogen-free Identification Part number Drawing X Generic Cabling Cables Dimensions in mm Industrial Cat. 6 cable, stranded, 8-wire PUR   20 m ring   50 m ring 100 m ring 500 m drum 09 45 600 0630 09 45 600 0640 09 45 600 0600 09 45 600 0620 C·G 19 HARTING Generic Cabling Generic Cabling Cables Industrial Cat. 5 outdoor cable, 8-wire to make up flexible connections (one- or two-sided assembled system cables) IP 20 X IP 65 / IP 67 X PVC Cat. 6 4 x 2, Twisted Pair, shielded, PIMF Cord, 4 x 2 x AWG 26/7 PVC 6.7 mm Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s each pair shielded and additional shield for the whole cable – 45 °C to + 60 °C Standard lengths Colour 20 m / 50 m / 100 m / 500 m Black Advantages Robust industrial-compatible design Applicable also for outside applications Part number Industrial Cat. 5 outdoor cable, 8-wire   20 m ring   50 m ring 100 m ring 500 m drum 20 X Cable structure Core structure Sheath material Cable sheath diameter Transmission performance Transmission rate Shielding Operating temperature range Identification C·G Cat. 5 09 45 600 0230 09 45 600 0240 09 45 600 0200 09 45 600 0220 Drawing Dimensions in mm HARTING Generic Cabling Industrial Cat. 5 cable, stranded, 8-wire, PUR to make up flexible connections (one- or two-sided assembled system cables) IP 20 X IP 65 / IP 67 X PUR Cat. 5 X Cat. 6 Cable structure Core structure Sheath material Cable sheath diameter Transmission performance Transmission rate Shielding Operating temperature range 4 x 2, Twisted Pair, shielded, PIMF Cord, 4 x 2 x AWG 26/7 PUR 6.7 mm Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s each pair shielded and additional shield for the whole cable – 45 °C to + 60 °C Standard lengths Colour 20 m / 50 m / 100 m / 500 m Green Advantages Robust industrial-compatible design Halogen-free Identification Part number Drawing Generic Cabling Cables Dimensions in mm Industrial Cat. 5 stranded cable, 8-wire PUR   20 m ring   50 m ring 100 m ring 500 m drum 09 45 600 0430 09 45 600 0440 09 45 600 0400 09 45 600 0420 C·G 21 Generic Cabling Notes C·G 22 HARTING Profile-specific Cabling – PROFINET List of contents Page Introduction ...................................................................................................... C·P   3 Distribution modules and Outlets HARTING Cabinet Outlet RJ45 . .......................................................... C·P   4 Han® 3 A Metal Outlet RJ45, Cat. 6 ..................................................... C·P   5 Han® 3 A Metal Outlet RJ45, Cat. 5 ..................................................... C·P   6 Panel feed-throughs Han® 3 A Panel feed-through RJ45 . ................................................... C·P   8 Han® 3 A Hybrid Panel feed-through RJ45 .......................................... C·P 12 Han® 3 A Hybrid Double-coupling RJ45 . ............................................ C·P 14 Han® M12 Panel feed-through D-coding . ............................................ C·P 16 System cables HARTING Industrial Ethernet Patch cable RJ45, 8-wire . .................... C·P 19 Profile-specific Cabling – PROFINET Han® 3 A Hybrid Double-coupling RJ45 . ............................................. C·P 10 HARTING RJ Industrial® System cable RJ45, 4-wire .......................... C·P 20 HARTING RJ Industrial® System cable RJ45, angled, 4-wire ............. C·P 22 HARTING RJ Industrial® System cable RJ45, angled, 4-wire ............. C·P 24 HARTING RJ Industrial® System cable RJ45, angled, 4-wire ............. C·P 26 Han® 3 A System cable RJ45, 4-wire . ................................................. C·P 28 Han® 3 A System cable RJ45, 4-wire . ................................................. C·P 30 Han® 3 A Hybrid System cable RJ45, 4-wire ....................................... C·P 32 HARTING PushPull System cable RJ45, 4-wire .................................. C·P 34 HARTING PushPull System cable RJ45, 4-wire .................................. C·P 36 HARTING PushPull System cable RJ45, angled, 4-wire ..................... C·P 38 HARTING PushPull System cable RJ45, 4-wire .................................. C·P 40 Han® M12 System cable, 4-wire .......................................................... C·P 42 Additional technical information about overmoulded System cables ... C·P 43 C·P  HARTING Profile-specific Cabling – PROFINET List of contents Page Connector sets HARTING RJ Industrial® Connector set RJ45, 4-pole ......................... C·P 44 HARTING PushPull Connector set RJ45, 4-pole ................................. C·P 46 Han® PushPull Connector set RJ45, 4-pole . ....................................... C·P 48 Han® PushPull Connector set SCRJ . .................................................. C·P 50 Han® 3 A Connector set RJ45, 4-pole . ................................................ C·P 52 Han® 3 A Hybrid Connector set RJ45, 4-pole ...................................... C·P 54 HARAX ® M12 Connector D-coding, 4-pole ......................................... C·P 56 Cables Profile-specific Cabling – PROFINET PROFINET Type A cable Industrial Cat. 5 Standard cable, 4-wire ...... C·P 58 C·P  PROFINET Type B cable Industrial Cat. 5 stranded cable, 4-wire . ..... C·P 59 PROFINET Type C cable Industrial Cat. 5 stranded cable, 4-wire useable as trailing cables . ................................................................... C·P 60 PROFINET Type B cable, outdoor Industrial Cat. 5 stranded cable, 4-wire, useable as trailing cables ..... C·P 61 PROFINET Type B cable, Hybrid Industrial Cat. 5 Hybrid cable, 4-wire + 4 x power ............................... C·P 62 HARTING Profile-specific Cabling – PROFINET Introduction Cabling – PROFINET” shows HARTING‘s complete cabling portfolio, which simply and efficiently networks PROFINET-conformant machines, equipment and controllers. PROFINET is the continuation of PROFIBUS technology, based on Ethernet TCP/IP. There are in principle two different functional classes: The PROFINET cabling system‘s product portfolio covers: Distributors and Connector boxes: Termination and distribution of cables in harsh IP 65 / IP 67 environments, but also within control or distribution cabinets. l Panel feed-throughs: To ensure reliable cable introduction from IP 65 / IP 67 environments into control or distribution cabinets. PROFINET CBA (Component-based Automation) for communications between intelligent automation devices l PROFINET IO for communications between a controller and decentralised field devices l l l Three performance classes are implemented: System cables: Made-up system cables for quick connection of terminal boxes, distributors or active devices with machines, equipment and controllers. TCP/IP – ethernet communications without realtime requirements l RT – real-time communication for I/O data traffic, in particular in automation technology l l l IRT – isosynchronous real-time communication, especially for all motion control applications Connectors: Connector sets to make up specific system cables onsite. Cables: A comprehensive cable portfolio for the laying out / manufacture of system cables onsite. l Essentially, all PROFINET applications can transmit over a future-proof generic cabling system. However the PNO (PROFINET User Organisation) has developed special guidelines for cabling components and installation practices and so all PROFINET cables and connectors are implemented with 4 wires. In contrast to generic cabling, PROFINET defines interfaces for power supply and/or the general transmission of data and power (so-called hybrid solutions). The HARTING PROFINET cabling portfolio includes these connector types, for example the Han® 3 A Hybrid. The use of connector types defined in the PROFINET guidelines, for example the Han® PushPull RJ45, that are also recommended by AIDA ­ (Automation Initiative German Domestic ­Automobile Manufacturers), offers customers a high level of compatibility within PROFINET conformant cabling. HARTING‘s PROFINET cabling system consequently allows an easy machine-, equipment- and controller-network enhancement within a customer‘s existing PROFINET structure. This PROFINET cabling system is part of HARTING‘s comprehensive Automation IT network solution, which brings together active network technology, cabling and solutions for device and equipment power supply. The advantages of the HARTING PROFINET cabling system at-a-glance PROFINET conformant cabling infrastructure, usable for all PROFINET functional and performance classes l Supports all PROFINET safety features and real-time requirements l Profile-specific Cabling – PROFINET “Profile-specific Can be expanded and integrated into existing PROFINET infrastructures without problems l Conformance with AIDA guidelines makes rollouts in the auto industry easier l Use of PROFINET conformant connectors reduces the variety of parts and makes purchasing and stocking of components easier l Special solutions for simultaneous (Hybrid) and/or separate power transmission enhances network functionality l The high quality of the cabling system guarantees a long useful life and reliable operations l Simple planning, installation and reliable operation saves costs and delivers a high ROI l The PROFINET cabling system is part of HARTING‘s one-stop Automation IT network solution l C·P  HARTING Profile-specific Cabling – PROFINET Distribution modules and Outlets HARTING Cabinet Outlet RJ45 RJ45 distribution module for IP 20 environments (top-hat rail mounting) Profile-specific Cabling – PROFINET IP 20 X IP 65 / IP 67 to IP 20 IP 65 / IP 67 2 / RJ45 (Twisted Pair) Category 6 / Class E up to 250 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s LSA-PLUS module, terminated without special tools Strand diameter Strand isolation Cable diameter Shielding AWG 24 - 22 (0.5 mm - 0.65 mm) solid and stranded 0.7 mm - 1.6 mm 6 mm - 9 mm fully shielded, 360° shielding contact Mounting Dimensions (H x W x D) Degree of protection Operating temperature range Housing material Colour mounting onto 35 mm top-hat mounting rail acc. to DIN EN 60 715, alignable 82 x 28.4 x 74 mm IP 20 – 20 °C to + 70 °C Polycarbonate, V0 Grey Advantages Simple mounting Cable entering ether from bottom or from top Dust protection covers Port identification Angled outputs Part number HARTING Cabinet Outlet RJ45 consisting of: 2 port-housing with dust protection covers and labels 2x RJ45 female module, Cat. 6 Assembly instructions  Cat. 6 Number of ports, Copper / Termination Transmission performance Transmission rate Termination Identification C·P Cat. 5 20 76 102 8000 Drawing X Dimensions in mm HARTING Profile-specific Cabling – PROFINET Distribution modules and Outlets Han® 3 A Metal Outlet RJ45, Cat. 6 RJ45 Industrial Outlet for IP 65 / IP 67 environments IP 65 / IP 67 X IP 65 / IP 67 to IP 20 Cat. 5 Cat. 6 Number of ports, Copper / Termination Transmission performance Transmission rate Termination 2 / Han® 3 A RJ45 (IP 65 / IP 67) Category 6 / Class E up to 250 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s LSA-PLUS module, terminated without special tools Strand diameter Strand isolation Cable diameter Shielding AWG 24 - 22 (0.5 mm - 0.65 mm) solid and stranded 0.7 mm - 1.6 mm 6 mm - 9 mm fully shielded, 360° shielding contact Mounting Dimensions (H x W x D) Degree of protection Operating temperature range Housing material Colour Wall mounting 125 x 80 x 57.5 mm IP 65 / IP 67 – 20 °C to + 70 °C Aluminium, die-cast Grey RAL 7037 X Profile-specific Cabling – PROFINET IP 20 Advantages Robust metal housing for use in harsh industrial environments Simple mounting Lockable connector ports Han® 3 A Identification Part number Drawing Dimensions in mm Han® 3 A Metal Outlet RJ45, Cat. 6 consisting of: 2 port-metal housing with protection covers and cable glands 2x RJ45 female module, Cat. 6 Assembly instructions 20 79 302 0922 C·P  HARTING Profile-specific Cabling – PROFINET Distribution modules and Outlets Han® 3 A Metal Outlet RJ45, Cat. 5 RJ45 Industrial Outlet for IP 65 / IP 67 environments Profile-specific Cabling – PROFINET IP 20 IP 65 / IP 67 X IP 65 / IP 67 to IP 20 Cat. 5 X Cat. 6 Number of ports, Copper / Termination 2 / Han® 3 A RJ45 (IP 65 / IP 67) Transmission performance Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 Transmission rate 10/100/1000 Mbit/s Termination LSA-PLUS module, terminating via LSA-PLUS tool Strand diameter AWG 26 - 22 (0.35 mm - 0.65 mm) solid and stranded Strand isolation 0.7 mm - 1.6 mm Cable diameter 5 mm - 9 mm Shielding fully shielded, 360° shielding contact Mounting Dimensions (H x W x D) Degree of protection Operating temperature range Housing material Colour Wall mounting 105 x 105 x 40.5 mm IP 65 / IP 67 – 40 °C to + 70 °C Aluminium, die-cast Grey RAL 7037 Advantages Robust metal housing for use in harsh industrial environments Simple mounting Cable feeding ether from the left or from the right side Lockable connector ports Han® 3 A Identification Part number Han® 3 A Metal Outlet RJ45, Cat. 5 C·P  consisting of: 2 port-metal housing with protection covers, cable glands and blanking piece PCB module with LSA-PLUS strips Label Assembly instructions 09 45 815 1100 Drawing Dimensions in mm Profile-specific Cabling – PROFINET Notes C·P  HARTING Profile-specific Cabling – PROFINET Panel feed-throughs Han® 3 A Panel feed-through RJ45 RJ45 panel feed-through for control or distributor cabinets IP 20 IP 65 / IP 67 Profile-specific Cabling – PROFINET Number of ports, Copper / Termination C·P  IP 65 / IP 67 to IP 20 X Cat. 5 X Cat. 6 Transmission performance Transmission rate 2 / 1x Han® 3 A RJ45 (IP 65 / IP 67) 1x RJ45 (Twisted Pair) (IP 20) Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s Shielding fully shielded, 360° shielding contact Mounting Dimensions Panel cut-out Mounting hole Degree of protection Operating temperature range screw-on type on steel plate walls see drawing 20 mm x 22 mm Diameter 3.4 mm IP 65 / IP 67 – 40 °C to + 70 °C Plastic version Housing material Colour Polyamide, UL 94-V0 Black Metal version Standard Housing material Colour Zinc, die-cast Grey Metal version M Housing material Colour Zinc, die-cast, chromatised, powder coated Black Advantages Simple mounting RJ45 plug-compatible Different versions cover all operational cases Coding possible HARTING Profile-specific Cabling – PROFINET Identification Part number Drawing Dimensions in mm Han® 3 A Panel feed-through RJ45 Plastic version straight style angled style 09 45 225 1100 09 45 225 1108 IEC 60603-7 SMT modular Jack 12 mm max. height above PCB Accessories Protection cover IP 65 / IP 67 for panel feed-through 09 20 003 5445 Han® 3 A Panel feed-through RJ45 09 45 215 1100 Dimensions valid for straight Plastic version 09 45 215 1103 09 45 215 1108 Profile-specific Cabling – PROFINET Metal version Standard straight style straight style including self-closing protection cover angled style Accessories Protection cover IP 65 / IP 67 for panel feed-through 09 20 003 5425 Han® 3 A Panel feed-through RJ45 Metal version M straight style angled style 09 45 215 1102 09 45 215 1109 Accessories Protection cover IP 65 / IP 67 for panel feed-through 09 37 003 5405 Dimensions valid for Plastic version Accessories Set of coding pins 09 45 820 0000 C·P  HARTING Profile-specific Cabling – PROFINET Panel feed-throughs Han® 3 A double-coupling RJ45 RJ45 double-coupling for control or distributor cabinets IP 20 IP 65 / IP 67 X IP 65 / IP 67 to IP 20 Cat. 5 X Cat. 6 Profile-specific Cabling – PROFINET Number of ports, Copper / Termination 2 / Han® 3 A RJ45 (IP 65 / IP 67) Transmission performance Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 Transmission rate 10/100/1000 Mbit/s Shielding fully shielded, 360° shielding contact C·P 10 Mounting Dimensions Panel cut-out Mounting hole Degree of protection Operating temperature range screw-on type on steel plate walls see drawing 20 mm x 22 mm Diameter 3.4 mm IP 65 / IP 67 – 40 °C to + 70 °C Plastic version Housing material Colour Polyamide, UL 94-V0 Black Metal version Standard Housing material Colour Zinc, die-cast Grey Metal version M Housing material Colour Zinc, die-cast, chromatised, powder coated Black Advantages Simple mounting RJ45 plug-compatible Different versions cover all operational cases Coding possible HARTING Profile-specific Cabling – PROFINET Identification Han® 3 A double-coupling RJ45 Plastic version Part number Drawing Dimensions in mm 09 45 225 1107 Accessories Protection cover IP 65 / IP 67 for panel feed-through 09 20 003 5445 Han® 3 A double-coupling RJ45 09 45 215 1107 Dimensions valid for Plastic version Accessories Protection cover IP 65 / IP 67 for panel feed-through Profile-specific Cabling – PROFINET Metal version Standard 09 20 003 5425 Han® 3 A double-coupling RJ45 Metal version M 09 45 215 1110 Accessories Protection cover IP 65 / IP 67 for panel feed-through 09 37 003 5405 Dimensions valid for Plastic version Accessories Set of coding pins 09 45 820 0000 C·P 11 HARTING Profile-specific Cabling – PROFINET Panel feed-throughs Han® 3 A Hybrid panel feed-through RJ45 Hybrid panel feed-through for control or distributor cabinets IP 20 IP 65 / IP 67 IP 65 / IP 67 to IP 20 X Cat. 5 X Cat. 6 2 / 1x Han® 3 A RJ45 (IP 65 / IP 67) 1x RJ45 (Twisted Pair) (IP 20) Termination Hybrid supply 4 contacts in the Han® 3 A connector (IP 65 / IP 67) 4 contacts for power supply via cage-clamp terminal to 48 V, 16 A (IP 20) Profile-specific Cabling – PROFINET Number of ports, Copper / Termination C·P 12 Transmission performance Transmission rate Shielding Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s fully shielded, 360° shielding contact Mounting Dimensions Panel cut-out Mounting hole Degree of protection Operating temperature range screw-on type on steel plate walls see drawing 20 mm x 22 mm Diameter 3.4 mm IP 65 / IP 67 – 40 °C to + 70 °C Plastic version Housing material Colour Polyamide, UL 94-V0 Black Metal version Standard Housing material Colour Zinc, die-cast Grey Advantages Simple mounting RJ45 plug-compatible Additional power supply via Hybrid cable Coding possible HARTING Profile-specific Cabling – PROFINET Identification Part number Drawing Dimensions in mm Han® 3 A Hybrid Panel feed-through RJ45 Plastic version 09 45 225 1300 Accessories Protection cover IP 65 / IP 67 for panel feed-through 09 20 003 5445 Han® 3 A Hybrid Panel feed-through RJ45 10 12 005 1002 Accessories Protection cover IP 65 / IP 67 for panel feed-through 09 20 003 5425 Profile-specific Cabling – PROFINET Metal version Standard Accessories Set of coding pins 09 45 820 0000 C·P 13 HARTING Profile-specific Cabling – PROFINET Panel feed-throughs Han® 3 A Hybrid double-coupling RJ45 Hybrid double-coupling for control or distributor cabinets Profile-specific Cabling – PROFINET IP 20 C·P 14 IP 65 / IP 67 X IP 65 / IP 67 to IP 20 Cat. 5 X Cat. 6 Number of ports, Copper / Termination Termination Hybrid supply 2 / Han® 3 A RJ45 (IP 65 / IP 67) 4 contacts in the Han® 3 A connector (IP 65 / IP 67) Transmission performance Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 Transmission rate Shielding 10/100/1000 Mbit/s fully shielded, 360° shielding contact Mounting Dimensions Panel cut-out Mounting hole Degree of protection Operating temperature range screw-on type on steel plate walls see drawing 20 mm x 22 mm Diameter 3.4 mm IP 65 / IP 67 – 40 °C to + 70 °C Metal version Standard Housing material Colour Zinc, die-cast Grey Advantages Simple mounting RJ45 plug-compatible Additional power supply via Hybrid cable Coding possible HARTING Profile-specific Cabling – PROFINET Identification Part number Drawing Dimensions in mm Han® 3 A Hybrid Hybrid double-coupling RJ45 Metal version Standard 10 12 005 1003 Accessories 09 20 003 5425 Accessories Set of coding pins 09 45 820 0000 Profile-specific Cabling – PROFINET Protection cover IP 65 / IP 67 for panel feed-through C·P 15 HARTING Profile-specific Cabling – PROFINET Panel feed-throughs Han® M12 Panel feed-through D-coding M12 panel feed-through for control or distributor cabinets IP 20 IP 65 / IP 67 Profile-specific Cabling – PROFINET Number of ports, Copper / Termination C·P 16 IP 65 / IP 67 to IP 20 X Cat. 5 X Cat. 6 Transmission performance Transmission rate 2 / 1x M12, D-coding (IP 65 / IP 67) 1x RJ45 (Twisted Pair) (IP 20) Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100 Mbit/s Shielding fully shielded, 360° shielding contact Mounting Dimensions Panel cut-out Degree of protection Operating temperature range screw-on type on steel plate walls see drawing Diameter 16.5 mm IP 65 / IP 67 – 5 °C to + 60 °C Housing material Colour Metal / plastic Black Advantages Simple mounting RJ45 plug-compatible on back side HARTING Profile-specific Cabling – PROFINET Identification Part number Drawing Dimensions in mm Han® M12 Panel feed-through D-coding straight 21 03 381 2400 Han® M12 Panel feed-through D-coding 21 03 381 4400 Profile-specific Cabling – PROFINET angled C·P 17 Profile-specific Cabling – PROFINET Notes C·P 18 HARTING Profile-specific Cabling – PROFINET System cables HARTING Industrial Ethernet Patch cable RJ45, 8-wire RJ45 connection cable for control or distributor cabinets or within controllers X IP 65 / IP 67 IP 65 / IP 67 to IP 20 Cat. 5 X Cat. 6 Connector types Cable types Sheath material Wiring Transmission performance Transmission rate Shielding Operating temperature range RJ45, overmoulded 4 x 2, Twisted Pair, shielded PUR, halogen-free LSZH 8-pole, 1:1 Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s fully shielded, 360° shielding contact – 20 °C to + 60 °C Standard lengths Colour 0.5 m / 1 m / 2 m / 3 m / 5 m / 7.5 m other lengths on request Black or Green Advantages Robust design Easy handling for all applications Identification Profile-specific Cabling – PROFINET IP 20 Part number HARTING Industrial Ethernet Patch cable RJ45, 8-wire Length 0.5 m Length 1.0 m Length 2.0 m Length 3.0 m Length 5.0 m Length 7.5 m Black Green 09 45 971 1121 09 45 971 1122 09 45 971 1123 09 45 971 1124 09 45 971 1126 09 45 971 1129 09 45 971 1101 09 45 971 1102 09 45 971 1103 09 45 971 1104 09 45 971 1106 09 45 971 1109 C·P 19 HARTING Profile-specific Cabling – PROFINET System cables HARTING RJ Industrial® System cable RJ45, 4-wire RJ45 connection cable for control or distributor cabinets or within controllers IP 20 X IP 65 / IP 67 Connector types IP 65 / IP 67 to IP 20 Cat. 5 X Cat. 6 RJ45, overmoulded Profile-specific Cabling – PROFINET Cable types PROFINET Cable type Type A Type B Type C Cables Copper, solid, shielded Copper, stranded, shielded Copper, stranded, shielded, trailing cables useable Wire gauge 2 x 2 x AWG 22/1 2 x 2 x AWG 22/7 2 x 2 x AWG 22/7 Sheath material PVC PVC PUR Operating temperature range – 40 °C to + 70 °C – 40 °C to + 70 °C – 40 °C to + 70 °C Colour Green Green Green Wiring Transmission performance Transmission rate Shielding 4-pole, 1:1 (RJ45 contacts 1/2 and 3/6) Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100 Mbit/s fully shielded, 360° shielding contact Standard lengths 1.5 m / 3 m / 5 m / 10 m / 20 m other lengths on request Advantages Robust industrial design Available also as Multiport version for especially space-critical port configurations on switches or devices C·P 20 Additional technical information about overmoulded system cables find on page C·P 43 HARTING Profile-specific Cabling – PROFINET Identification Part number Standard Multiport HARTING RJ Industrial® System cable RJ45, 4-wire Type A Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m 09 45 771 0023 09 45 771 0025 09 45 771 0027 09 45 771 0051 09 45 771 0053 09 47 343 4006 09 47 343 4009 09 47 343 4012 09 47 343 4018 09 47 343 4020 09 45 771 1123 09 45 771 1125 09 45 771 1127 09 45 771 1151 09 45 771 1153 09 47 343 4034 09 47 343 4037 09 47 343 4040 09 47 343 4046 09 47 343 4048 09 45 771 1164 09 45 771 1166 09 45 771 1168 09 45 771 1173 09 45 771 1175 09 47 343 4090 09 47 343 4093 09 47 343 4096 09 47 343 4102 09 47 343 4104 HARTING RJ Industrial® System cable RJ45, 4-wire Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m HARTING RJ Industrial® System cable RJ45, 4-wire Type C Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m Profile-specific Cabling – PROFINET Type B C·P 21 HARTING Profile-specific Cabling – PROFINET System cables HARTING RJ Industrial® System cable RJ45, angled, 4-wire RJ45 connection cable, angled left to angled right, for control or distributor cabinets or within controllers IP 20 X IP 65 / IP 67 Connector types IP 65 / IP 67 to IP 20 Cat. 5 X Cat. 6 RJ45, overmoulded Profile-specific Cabling – PROFINET Cable types PROFINET Cable type Type A Type B Type C Outdoor Cables Copper, solid, shielded Copper, stranded, shielded Copper, stranded, shielded, trailing cables useable Copper, stranded, shielded Wire gauge 2 x 2 x AWG 22/1 2 x 2 x AWG 22/7 2 x 2 x AWG 22/7 2 x 2 x AWG 22/7 Sheath material PVC PVC PUR PVC Operating ­temperature range – 40 °C to + 70 °C – 40 °C to + 70 °C – 40 °C to + 70 °C – 45 °C to + 60 °C Colour Green Green Green Black Wiring Transmission performance Transmission rate Shielding 4-pole, 1:1 (RJ45 contacts 1/2 and 3/6) Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100 Mbit/s fully shielded, 360° shielding contact Standard lengths 0.5 m / 1 m / 1.5 m / 2 m / 3 m / 5 m other lengths on request Advantages Robust industrial design For especially space-saving cabling C·P 22 Additional technical information about overmoulded system cables find on page C·P 43 HARTING Profile-specific Cabling – PROFINET Identification Part number HARTING RJ Industrial® System cable RJ45, angled, 4-wire Type A, angled left to angled right Length 0.5 m Length 1.0 m Length 1.5 m Length 2.0 m Length 3.0 m Length 5.0 m 09 47 050 6001 09 47 050 6002 09 47 050 6003 09 47 050 6004 09 47 050 6005 09 47 050 6007 HARTING RJ Industrial® System cable RJ45, angled, 4-wire Length 0.5 m Length 1.0 m Length 1.5 m Length 2.0 m Length 3.0 m Length 5.0 m 09 47 050 6023 09 47 050 6024 09 47 050 6025 09 47 050 6026 09 47 050 6027 09 47 050 6029 HARTING RJ Industrial® System cable RJ45, angled, 4-wire Type C, angled left to angled right Length 0.5 m Length 1.0 m Length 1.5 m Length 2.0 m Length 3.0 m Length 5.0 m Profile-specific Cabling – PROFINET Type B, angled left to angled right 09 47 050 6045 09 47 050 6046 09 47 050 6047 09 47 050 6048 09 47 050 6049 09 47 050 6051 HARTING RJ Industrial® System cable RJ45, angled, 4-wire Outdoor, angled left to angled right Length 0.5 m Length 1.0 m Length 1.5 m Length 2.0 m Length 3.0 m Length 5.0 m 09 47 050 6067 09 47 050 6068 09 47 050 6069 09 47 050 6070 09 47 050 6071 09 47 050 6073 C·P 23 HARTING Profile-specific Cabling – PROFINET System cables HARTING RJ Industrial® System cable RJ45, angled, 4-wire RJ45 connection cable, angled top to angled bottom, for control or distributor cabinets or within controllers IP 20 X IP 65 / IP 67 Connector types IP 65 / IP 67 to IP 20 Cat. 5 X Cat. 6 RJ45, overmoulded Profile-specific Cabling – PROFINET Cable types PROFINET Cable type Type A Type B Type C Outdoor Cables Copper, solid, shielded Copper, stranded, shielded Copper, stranded, shielded, trailing cables useable Copper, stranded, shielded Wire gauge 2 x 2 x AWG 22/1 2 x 2 x AWG 22/7 2 x 2 x AWG 22/7 2 x 2 x AWG 22/7 Sheath material PVC PVC PUR PVC Operating ­temperature range – 40 °C to + 70 °C – 40 °C to + 70 °C – 40 °C to + 70 °C – 45 °C to + 60 °C Colour Green Green Green Black Wiring Transmission performance Transmission rate Shielding 4-pole, 1:1 (RJ45 contacts 1/2 and 3/6) Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100 Mbit/s fully shielded, 360° shielding contact Standard lengths 0.5 m / 1 m / 1.5 m / 2 m / 3 m / 5 m other lengths on request Advantages Robust industrial design For especially space-saving cabling C·P 24 Additional technical information about overmoulded system cables find on page C·P 43 HARTING Profile-specific Cabling – PROFINET Identification Part number HARTING RJ Industrial® System cable RJ45, angled, 4-wire Type A, angeld top to angled bottom Length 0.5 m Length 1.0 m Length 1.5 m Length 2.0 m Length 3.0 m Length 5.0 m 09 47 030 4001 09 47 030 4002 09 47 030 4003 09 47 030 4004 09 47 030 4005 09 47 030 4007 HARTING RJ Industrial® System cable RJ45, angled, 4-wire Length 0.5 m Length 1.0 m Length 1.5 m Length 2.0 m Length 3.0 m Length 5.0 m 09 47 030 4023 09 47 030 4024 09 47 030 4025 09 47 030 4026 09 47 030 4027 09 47 030 4029 HARTING RJ Industrial® System cable RJ45, angled, 4-wire Type C, angeld top to angled bottom Length 0.5 m Length 1.0 m Length 1.5 m Length 2.0 m Length 3.0 m Length 5.0 m Profile-specific Cabling – PROFINET Type B, angeld top to angled bottom 09 47 030 4045 09 47 030 4046 09 47 030 4047 09 47 030 4048 09 47 030 4049 09 47 030 4051 HARTING RJ Industrial® System cable RJ45, angled, 4-wire Outdoor, angeld top to angled bottom Length 0.5 m Length 1.0 m Length 1.5 m Length 2.0 m Length 3.0 m Length 5.0 m 09 47 030 4067 09 47 030 4068 09 47 030 4069 09 47 030 4070 09 47 030 4071 09 47 030 4073 C·P 25 HARTING Profile-specific Cabling – PROFINET System cables Exit left Exit right HARTING RJ Industrial® System cable RJ45 angled, 4-wire Exit top RJ45 connection cable, first end angled, second side open, for control or distributor cabinets or within controllers IP 20 X IP 65 / IP 67 Connector types IP 65 / IP 67 to IP 20 Cat. 5 Exit bottom X Cat. 6 RJ45, overmoulded, one side pre-assembled Profile-specific Cabling – PROFINET Cable types PROFINET Cable type Type A Type B Type C Outdoor Cables Copper, solid, shielded Copper, stranded, shielded Copper, stranded, shielded, trailing cables useable Copper, stranded, shielded Wire gauge 2 x 2 x AWG 22/1 2 x 2 x AWG 22/7 2 x 2 x AWG 22/7 2 x 2 x AWG 22/7 Sheath material PVC PVC PUR PVC Operating ­temperature range – 40 °C to + 70 °C – 40 °C to + 70 °C – 40 °C to + 70 °C – 45 °C to + 60 °C Colour Green Green Green Black Wiring Transmission performance Transmission rate Shielding first end 4-pole, (RJ45 contacts 1/2 and 3/6), other side open Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100 Mbit/s fully shielded, 360° shielding contact Standard lengths 0.5 m / 1 m / 1.5 m / 2 m / 3 m / 5 m other lengths on request Advantages Robust industrial design For especially space-saving cabling Exact length can be adjusted Use HARTING RJ45 connector (09 45 151 1100) C·P 26 Additional technical information about overmoulded system cables find on page C·P 43 HARTING Profile-specific Cabling – PROFINET Identification Part number angled left angled right angled top angled bottom 09 47 050 0001 09 47 050 0002 09 47 050 0003 09 47 050 0004 09 47 050 0005 09 47 050 0007 09 47 060 0001 09 47 060 0002 09 47 060 0003 09 47 060 0004 09 47 060 0005 09 47 060 0007 09 47 030 0001 09 47 030 0002 09 47 030 0003 09 47 030 0004 09 47 030 0005 09 47 030 0007 09 47 040 0001 09 47 040 0002 09 47 040 0003 09 47 040 0004 09 47 040 0005 09 47 040 0007 09 47 050 0023 09 47 050 0024 09 47 050 0025 09 47 050 0026 09 47 050 0027 09 47 050 0029 09 47 060 0023 09 47 060 0024 09 47 060 0025 09 47 060 0026 09 47 060 0027 09 47 060 0029 09 47 030 0023 09 47 030 0024 09 47 030 0025 09 47 030 0026 09 47 030 0027 09 47 030 0029 09 47 040 0023 09 47 040 0024 09 47 040 0025 09 47 040 0026 09 47 040 0027 09 47 040 0029 09 47 050 0045 09 47 050 0046 09 47 050 0047 09 47 050 0048 09 47 050 0049 09 47 050 0051 09 47 060 0045 09 47 060 0046 09 47 060 0047 09 47 060 0048 09 47 060 0049 09 47 060 0051 09 47 030 0045 09 47 030 0046 09 47 030 0047 09 47 030 0048 09 47 030 0049 09 47 030 0051 09 47 040 0045 09 47 040 0046 09 47 040 0047 09 47 040 0048 09 47 040 0049 09 47 040 0051 09 47 050 0067 09 47 050 0068 09 47 050 0069 09 47 050 0070 09 47 050 0071 09 47 050 0073 09 47 060 0067 09 47 060 0068 09 47 060 0069 09 47 060 0070 09 47 060 0071 09 47 060 0073 09 47 030 0067 09 47 030 0068 09 47 030 0069 09 47 030 0070 09 47 030 0071 09 47 030 0073 09 47 040 0067 09 47 040 0068 09 47 040 0069 09 47 040 0070 09 47 040 0071 09 47 040 0073 HARTING RJ Industrial® System cable RJ45 angled, 4-wire one side pre-assembled, second side open Type A Length 0.5 m Length 1.0 m Length 1.5 m Length 2.0 m Length 3.0 m Length 5.0 m one side pre-assembled, second side open Type B Length 0.5 m Length 1.0 m Length 1.5 m Length 2.0 m Length 3.0 m Length 5.0 m HARTING RJ Industrial® System cable RJ45 angled, 4-wire one side pre-assembled, second side open Type C Length 0.5 m Length 1.0 m Length 1.5 m Length 2.0 m Length 3.0 m Length 5.0 m Profile-specific Cabling – PROFINET HARTING RJ Industrial® System cable RJ45 angled, 4-wire HARTING RJ Industrial® System cable RJ45 angled, 4-wire one side pre-assembled, second side open Outdoor Length 0.5 m Length 1.0 m Length 1.5 m Length 2.0 m Length 3.0 m Length 5.0 m C·P 27 HARTING Profile-specific Cabling – PROFINET System cables Han® 3 A System cable RJ45, 4-wire Han® 3 A RJ45 connection cable for harsh industrial environments IP 20 IP 65 / IP 67 Connector types X IP 65 / IP 67 to IP 20 Cat. 5 X Cat. 6 Han® 3 A Metal RJ45 Profile-specific Cabling – PROFINET Cable types C·P 28 PROFINET Cable type Type A Type B Type C Cables Copper, solid, shielded Copper, stranded, shielded Copper, stranded, shielded, trailing cables useable Wire gauge 2 x 2 x AWG 22/1 2 x 2 x AWG 22/7 2 x 2 x AWG 22/7 Sheath material PVC PVC PUR Operating temperature range – 40 °C to + 70 °C – 40 °C to + 70 °C – 40 °C to + 70 °C Colour Green Green Green Wiring Transmission performance Transmission rate Shielding 4-pole (RJ45 contacts 1/2 and 3/6) Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100 Mbit/s fully shielded, 360° shielding contact Standard lengths 1.5 m / 3 m / 5 m / 10 m / 20 m other lengths on request Advantages Robust design Use on-site made possible by IP 65 / IP 67 protection Easy handling for all applications HARTING Profile-specific Cabling – PROFINET Identification Part number Han® 3 A System cable RJ45, 4-wire Type A Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m 09 45 715 1123 09 45 715 1125 09 45 715 1127 09 45 715 1151 09 45 715 1153 Han® 3 A System cable RJ45, 4-wire Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m 09 45 715 1164 09 45 715 1166 09 45 715 1168 09 45 715 1173 09 45 715 1175 Han® 3 A System cable RJ45, 4-wire Type C Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m Profile-specific Cabling – PROFINET Type B 09 45 715 0023 09 45 715 0025 09 45 715 0027 09 45 715 0051 09 45 715 0053 C·P 29 HARTING Profile-specific Cabling – PROFINET System cables Han® 3 A System cable RJ45, 4-wire Han® 3 A RJ45 connection cable for harsh industrial environments, change-over to IP 20 IP 20 IP 65 / IP 67 Connector types IP 65 / IP 67 to IP 20 X Cat. 5 X Cat. 6 Han® 3 A Metal RJ45 (IP 65 / IP 67) / RJ45 (IP 20) Profile-specific Cabling – PROFINET Cable types C·P 30 PROFINET Cable type Type A Type B Type C Cables Copper, solid, shielded Copper, stranded, shielded Copper, stranded, shielded, trailing cables useable Wire gauge 2 x 2 x AWG 22/1 2 x 2 x AWG 22/7 2 x 2 x AWG 22/7 Sheath material PVC PVC PUR Operating temperature range – 40 °C to + 70 °C – 40 °C to + 70 °C – 40 °C to + 70 °C Colour Green Green Green Wiring Transmission performance Transmission rate Shielding 4-pole (RJ45 contacts 1/2 and 3/6) Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100 Mbit/s fully shielded, 360° shielding contact Standard lengths 1.5 m / 3 m / 5 m / 10 m / 20 m other lengths on request Advantages Robust design Easy change-over from harsh industrial environment to protected IP 20 environment Easy handling for all applications HARTING Profile-specific Cabling – PROFINET Identification Part number Han® 3 A System cable RJ45, 4-wire Type A Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m 09 45 700 1123 09 45 700 1125 09 45 700 1127 09 45 700 1151 09 45 700 1153 Han® 3 A System cable RJ45, 4-wire Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m 09 45 700 1164 09 45 700 1166 09 45 700 1168 09 45 700 1173 09 45 700 1175 Han® 3 A System cable RJ45, 4-wire Type C Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m Profile-specific Cabling – PROFINET Type B 09 45 700 0023 09 45 700 0025 09 45 700 0027 09 45 700 0051 09 45 700 0053 C·P 31 HARTING Profile-specific Cabling – PROFINET System cables Han® 3 A Hybrid System cable RJ45, 4-wire Han® 3 A Hybrid connection cable for harsh industrial environments Profile-specific Cabling – PROFINET IP 20 C·P 32 IP 65 / IP 67 X IP 65 / IP 67 to IP 20 Cat. 5 X Cat. 6 Connector types Han® 3 A Hybrid, plastic Cable types Sheath material Wiring Transmission performance Transmission rate Shielding 2 x 2 x AWG 22/7, Twisted Pair, shielded + 4 power cores FRNC 4-pole (RJ45 contacts 1/2 and 3/6) Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100 Mbit/s + Power supply fully shielded, 360° shielding contact Operating temperature range – 20 °C to + 70 °C Standard lengths Colour 1.5 m / 3 m / 5 m / 10 m / 20 m other lengths on request Green Advantages Robust design Use on-site made possible via IP 65 / IP 67 protection Easy handling for applications with additional power supply HARTING Profile-specific Cabling – PROFINET Identification Part number Drawing Dimensions in mm Han® 3 A Hybrid System cable RJ45, 4-wire 09 45 725 1323 09 45 725 1325 09 45 725 1327 09 45 725 1351 09 45 725 1353 Profile-specific Cabling – PROFINET Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m C·P 33 HARTING Profile-specific Cabling – PROFINET System cables HARTING PushPull System cable RJ45, 4-wire RJ45 connection cable, PushPull, for IP 65 / IP 67 applications IP 20 IP 65 / IP 67 X Connector types IP 65 / IP 67 to IP 20 Cat. 5 X Cat. 6 RJ45 PushPull Profile-specific Cabling – PROFINET Cable types C·P 34 PROFINET Cable type Type A Type B Type C Outdoor Cables Copper, solid, shielded Copper, stranded, shielded Copper, stranded, shielded, trailing cables useable Copper, stranded, shielded Wire gauge 2 x 2 x AWG 22/1 2 x 2 x AWG 22/7 2 x 2 x AWG 22/7 2 x 2 x AWG 22/7 Sheath material PVC PVC PUR PVC Operating ­temperature range – 40 °C to + 70 °C – 40 °C to + 70 °C – 40 °C to + 70 °C – 45 °C to + 60 °C Colour Green Green Green Black Wiring Transmission performance Transmission rate Shielding 4-pole (RJ45 contacts 1/2 and 3/6) Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100 Mbit/s fully shielded, 360° shielding contact Standard lengths 1.5 m / 3 m / 5 m / 10 m / 20 m other lengths on request Advantages Space-saving IP 65 / IP 67 interface Easy handling HARTING Profile-specific Cabling – PROFINET Identification Part number HARTING PushPull System cable RJ45, 4-wire Type A Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m 09 45 745 1123 09 45 745 1125 09 45 745 1127 09 45 745 1151 09 45 745 1153 HARTING PushPull System cable RJ45, 4-wire Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m 09 45 745 1164 09 45 745 1166 09 45 745 1168 09 45 745 1173 09 45 745 1175 HARTING PushPull System cable RJ45, 4-wire Type C Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m Profile-specific Cabling – PROFINET Type B 09 45 745 0023 09 45 745 0025 09 45 745 0027 09 45 745 0051 09 45 745 0053 HARTING PushPull System cable RJ45, 4-wire Outdoor Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m 09 45 701 0064 09 45 701 0066 09 45 701 0068 09 45 701 0073 09 45 701 0075 C·P 35 HARTING Profile-specific Cabling – PROFINET System cables HARTING PushPull System cable RJ45, 4-wire RJ45 connection cable, PushPull, overmoulded, for IP 65 / IP 67 applications IP 20 IP 65 / IP 67 X Connector types IP 65 / IP 67 to IP 20 Cat. 5 X Cat. 6 RJ45 PushPull, overmoulded Profile-specific Cabling – PROFINET Cable types PROFINET Cable type Type A Type B Type C Outdoor Cables Copper, solid, shielded Copper, stranded, shielded Copper, stranded, shielded, trailing cables useable Copper, stranded, shielded Wire gauge 2 x 2 x AWG 22/1 2 x 2 x AWG 22/7 2 x 2 x AWG 22/7 2 x 2 x AWG 22/7 Sheath material PVC PVC PUR PVC Operating ­temperature range – 40 °C to + 70 °C – 40 °C to + 70 °C – 40 °C to + 70 °C – 45 °C to + 60 °C Colour Green Green Green Black Wiring Transmission performance Transmission rate Shielding 4-pole (RJ45 contacts 1/2 and 3/6) Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100 Mbit/s fully shielded, 360° shielding contact Standard lengths 1.5 m / 3 m / 5 m / 10 m / 20 m other lengths on request Advantages Space-saving IP 65 / IP 67 interface Protected cable duct via overmoulding Easy handling C·P 36 Additional technical information about overmoulded system cables find on page C·P 43 HARTING Profile-specific Cabling – PROFINET Identification Part number HARTING PushPull System cable RJ45, 4-wire Type A Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m 09 47 363 6003 09 47 363 6005 09 47 363 6007 09 47 363 6012 09 47 363 6014 HARTING PushPull System cable RJ45, 4-wire Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m 09 47 363 6025 09 47 363 6027 09 47 363 6029 09 47 363 6034 09 47 363 6036 HARTING PushPull System cable RJ45, 4-wire Type C Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m Profile-specific Cabling – PROFINET Type B 09 47 363 6047 09 47 363 6049 09 47 363 6051 09 47 363 6056 09 47 363 6058 HARTING PushPull System cable RJ45, 4-wire Outdoor Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m 09 47 363 6069 09 47 363 6071 09 47 363 6073 09 47 363 6078 09 47 363 6080 C·P 37 HARTING Profile-specific Cabling – PROFINET System cables HARTING PushPull System cable RJ45, 4-wire, angled RJ45 connection cable, Exit left PushPull, for IP 65 / IP 67 applications, first end angled, second side open, IP 20 IP 65 / IP 67 X Connector types Exit right IP 65 / IP 67 to IP 20 Exit top Cat. 5 Exit bottom X Cat. 6 RJ45 PushPull, overmoulded, angled, one side pre-assembled Profile-specific Cabling – PROFINET Cable types PROFINET Cable type Type A Type B Type C Outdoor Cables Copper, solid, shielded Copper, stranded, shielded Copper, stranded, shielded, trailing cables useable Copper, stranded, shielded Wire gauge 2 x 2 x AWG 22/1 2 x 2 x AWG 22/7 2 x 2 x AWG 22/7 2 x 2 x AWG 22/7 Sheath material PVC PVC PUR PVC Operating ­temperature range – 40 °C to + 70 °C – 40 °C to + 70 °C – 40 °C to + 70 °C – 45 °C to + 60 °C Wiring Transmission performance Transmission rate Shielding 4-pole (RJ45 contacts 1/2 and 3/6) Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100 Mbit/s fully shielded, 360° shielding contact Standard lengths 1.5 m / 3 m / 5 m / 10 m / 20 m other lengths on request Advantages robust cable duct via overmoulding For especially space-saving cabling Exact length can be adjusted Use HARTING PushPull RJ45 connector (09 45 145 1100) C·P 38 Additional technical information about overmoulded system cables find on page C·P 43 HARTING Profile-specific Cabling – PROFINET Identification Part number angled left angled right angled top angled bottom 09 47 390 0003 09 47 390 0005 09 47 390 0007 09 47 390 0012 09 47 390 0014 09 47 400 0003 09 47 400 0005 09 47 400 0007 09 47 400 0012 09 47 400 0014 09 47 370 0003 09 47 370 0005 09 47 370 0007 09 47 370 0012 09 47 370 0014 09 47 380 0003 09 47 380 0005 09 47 380 0007 09 47 380 0012 09 47 380 0014 09 47 390 0025 09 47 390 0027 09 47 390 0029 09 47 390 0034 09 47 390 0036 09 47 400 0025 09 47 400 0027 09 47 400 0029 09 47 400 0034 09 47 400 0036 09 47 370 0025 09 47 370 0027 09 47 370 0029 09 47 370 0034 09 47 370 0036 09 47 380 0025 09 47 380 0027 09 47 380 0029 09 47 380 0034 09 47 380 0036 09 47 390 0047 09 47 390 0049 09 47 390 0051 09 47 390 0056 09 47 390 0058 09 47 400 0047 09 47 400 0049 09 47 400 0051 09 47 400 0056 09 47 400 0058 09 47 370 0047 09 47 370 0049 09 47 370 0051 09 47 370 0056 09 47 370 0058 09 47 380 0047 09 47 380 0049 09 47 380 0051 09 47 380 0056 09 47 380 0058 09 47 390 0069 09 47 390 0071 09 47 390 0073 09 47 390 0078 09 47 390 0080 09 47 400 0069 09 47 400 0071 09 47 400 0073 09 47 400 0078 09 47 400 0080 09 47 370 0069 09 47 370 0071 09 47 370 0073 09 47 370 0078 09 47 370 0080 09 47 380 0069 09 47 380 0071 09 47 380 0073 09 47 380 0078 09 47 380 0080 HARTING PushPull System cable RJ45, 4-wire, angled one side pre-assembled, second side open Type A Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m HARTING PushPull System cable RJ45, 4-wire, angled Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m HARTING PushPull System cable RJ45, 4-wire, angled one side pre-assembled, second side open Type C Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m Profile-specific Cabling – PROFINET one side pre-assembled, second side open Type B HARTING PushPull System cable RJ45, 4-wire, angled one side pre-assembled, second side open Outdoor Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m C·P 39 HARTING Profile-specific Cabling – PROFINET System cables HARTING PushPull System cable RJ45, 4-wire RJ45 connection cable, PushPull, to RJ45 IP 20 IP 20 IP 65 / IP 67 Connector types IP 65 / IP 67 to IP 20 X Cat. 5 X Cat. 6 RJ45 PushPull and RJ45 IP 20 Profile-specific Cabling – PROFINET Cable types C·P 40 PROFINET Cable type Type A Type B Type C Cables Copper, solid, shielded Copper, stranded, shielded Copper, stranded, shielded, trailing cables useable Wire gauge 2 x 2 x AWG 22/1 2 x 2 x AWG 22/7 2 x 2 x AWG 22/7 Sheath material PVC PVC PUR Operating temperature range – 40 °C to + 70 °C – 40 °C to + 70 °C – 40 °C to + 70 °C Colour Green Green Green Wiring Transmission performance Transmission rate Shielding 4-pole (RJ45 contacts 1/2 and 3/6) Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100 Mbit/s fully shielded, 360° shielding contact Standard lengths 1.5 m / 3 m / 5 m / 10 m / 20 m other lengths on request Advantages Space-saving IP 65 / IP 67 interface Easy change-over from harsh industrial environment to protected IP 20 environment Easy handling for all applications HARTING Profile-specific Cabling – PROFINET Identification Part number HARTING PushPull System cable RJ45, 4-wire Type A Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m 09 45 701 1123 09 45 701 1125 09 45 701 1127 09 45 701 1151 09 45 701 1153 HARTING PushPull System cable RJ45, 4-wire Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m 09 45 701 1164 09 45 701 1166 09 45 701 1168 09 45 701 1173 09 45 701 1175 HARTING PushPull System cable RJ45, 4-wire Type C Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m Profile-specific Cabling – PROFINET Type B 09 45 701 0023 09 45 701 0025 09 45 701 0027 09 45 701 0051 09 45 701 0053 C·P 41 HARTING Profile-specific Cabling – PROFINET System cables Han® M12 System cable, 4-wire Han® M12 connection cable, D-coding, for harsh industrial environments Profile-specific Cabling – PROFINET IP 20 IP 65 / IP 67 X IP 65 / IP 67 to IP 20 Cat. 5 Cat. 6 Connector types Han® M12, D-coding, overmoulded Cable types Sheath material Wiring Transmission performance Transmission rate Shielding 2 x 2 x AWG 22/7, Twisted Pair, shielded PUR 4-pole (RJ45 contacts 1/2 and 3/6) Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100 Mbit/s fully shielded, 360° shielding contact Operating temperature range – 25 °C to + 70 °C Standard lengths Colour 1m/3m/5m other lengths on request Green Advantages Robust design Use on-site made possible by IP 65 / IP 67 protection Identification Part number Drawing Han® M12 System cable, 4-wire Length 1.0 m Length 3.0 m Length 5.0 m 21 03 485 1401 21 03 485 1403 21 03 485 1405 C·P 42 X Additional technical information about overmoulded system cables find on page C·P 43 Dimensions in mm HARTING Profile-specific Cabling – PROFINET System cables Additional technical information about overmoulded System cables X IP 65 / IP 67 X IP 65 / IP 67 to IP 20 Electrical characteristics at 20 °C Contact resistance: Insulation resistance: ≤ 20 mΩ ≥ 500 MΩ Dielectric withstand voltage: contact - contact contact - ground 1 kV 1.5 kV Electrical characteristics after damp heat cycles Contact resistance: ≤ 20 mΩ Insulation resistance: ≥ 100 MΩ Dielectric withstand voltage: contact - contact contact - ground 1 kV 1.5 kV Cat. 5 X Cat. 6 Profile-specific Cabling – PROFINET IP 20 C·P 43 HARTING Profile-specific Cabling – PROFINET Connector sets HARTING RJ Industrial® Connector set RJ45, 4-pole to make up RJ45 system cables PROFINET Profile-specific Cabling – PROFINET IP 20 C·P 44 X IP 65 / IP 67 IP 65 / IP 67 to IP 20 Cat. 5 X Cat. 6 Connector type Number of contacts Transmission performance Transmission rate RJ45 connector acc. to IEC 60 603-7 4 Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100 Mbit/s Shielding fully shielded, 360° shielding contact Mounting Wire termination Cable options – Strand diameter – Cable sheath diameter Degree of protection Operating temperature range Housing material Colour Field-assembly possible via IDC contacts, tool-less suitable for solid and stranded cores AWG 24/7 - AWG 22/7 (stranded) AWG 23/1 - AWG 22/1 (solid) 6.5 mm - 6.9 mm IP 20 – 40 °C to + 70 °C Polycarbonate, UL 94-V0 Black Advantages Field-assembly connector, Cat. 5 HARTING Profile-specific Cabling – PROFINET Identification Part number Drawing Dimensions in mm HARTING RJ Industrial® Connector set RJ45, 4-pole 09 45 151 1100 Profile-specific Cabling – PROFINET Set consists of: Housing including shielding splice element Cable gland Assembly instructions C·P 45 HARTING Profile-specific Cabling – PROFINET Connector sets HARTING PushPull Connector set RJ45, 4-pole to make up HARTING PushPull system cables RJ45 Profile-specific Cabling – PROFINET IP 20 IP 65 / IP 67 X IP 65 / IP 67 to IP 20 Cat. 5 HARTING PushPull connector RJ45 acc. to IEC 24 702 4 Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100 Mbit/s Shielding fully shielded, 360° shielding contact Mounting Wire termination Field-assembly possible via IDC contacts Cable options – Strand diameter – Cable sheath diameter Degree of protection Operating temperature range Housing material Colour AWG 24/7 - AWG 22/7 (stranded) AWG 23/1 - AWG 22/1 (solid) 6.5 mm - 8.6 mm IP 65 / IP 67 – 40 °C to + 70 °C Polyamide, UL 94-V0 Black Mounting information 46 Cat. 6 Connector type Number of contacts Transmission performance Transmission rate Advantages Field-assembly connector, IP 65 / IP 67 Cat. 5 C·P X Tool-less assembly HARTING Profile-specific Cabling – PROFINET Identification Part number Drawing Dimensions in mm HARTING PushPull Connector set RJ45, 4-pole 09 45 145 1100 Protection cover for PushPull connectors 09 45 845 0001 Profile-specific Cabling – PROFINET Set consists of: PushPull housing with RJ45 connector and shielding Cable gland Assembly instructions C·P 47 HARTING Profile-specific Cabling – PROFINET Connector sets Han® PushPull Connector set RJ45, 4-pole to make up Han® PushPull system cables RJ45 IP 20 IP 65 / IP 67 X IP 65 / IP 67 to IP 20 Cat. 5 X Cat. 6 Profile-specific Cabling – PROFINET Connector type Han PushPull connector RJ45 acc. to IEC 61 918 (AIDA compliant) Number of contacts 4 Transmission performance Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 Transmission rate Shielding 10/100 Mbit/s fully shielded, 360° shielding contact Mounting Wire termination Field-assembly possible via IDC contacts Cable options – Strand diameter – Cable sheath diameter Degree of protection Operating temperature range Housing material Colour AWG 24/7 - AWG 22/7 (stranded) AWG 23/1 - AWG 22/1 (solid) to 9 mm IP 65 / IP 67 – 40 °C to + 70 °C Polyamide, UL 94-V0 Black Advantages Field-assembly connector, IP 65 / IP 67 Cat. 5 Mounting information C·P 48 Tool-less IDC technology HARTING Profile-specific Cabling – PROFINET Identification Part number Drawing Dimensions in mm Han® PushPull Connector set RJ45, 4-pole 09 35 221 0421 Set consists of: PushPull housing with RJ45 connectors and shielding Cable gland Assembly instructions Profile-specific Cabling – PROFINET Panel cut-out C·P 49 HARTING Profile-specific Cabling – PROFINET Connector sets Han® PushPull Connector set SCRJ to make up Han® PushPull system cables SCRJ IP 20 IP 65 / IP 67 X IP 65 / IP 67 to IP 20 Cat. 5 Cat. 6 Profile-specific Cabling – PROFINET Connector type Han PushPull connector SCRJ according to IEC 61 918 (AIDA compliant) Number of fibres 2 Transmission performance depends on the used fibre type Fibre types Glass fibre MM 50 / 125 µm and 62.5 / 125 µm Glass fibre SM 9 / 125 µm and 10 / 125 µm HCS® 200/230 POF 1 mm C·P 50 Mounting Cable options Degree of protection Operating temperature range Housing material Colour Field-assembly via IDC contacts Sheath diameter up to 9 mm IP 65 / IP 67 – 40 °C to + 70 °C Polyamide, UL 94-V0 Black Advantages Field-assembly glass fibre connector, IP 65 / IP 67 HARTING Profile-specific Cabling – PROFINET Identification Part number Drawing Dimensions in mm Han® PushPull Connector set SCRJ 09 35 221 0422 Set consists of: PushPull housing with SCRJ feeding Cable gland Assembly instructions Panel cut-out Profile-specific Cabling – PROFINET Note: Order SC ferrules separately C·P 51 HARTING Profile-specific Cabling – PROFINET Connector sets Han® 3 A Connector set RJ45, 4-pole to make up Han® 3 A system cables RJ45 Profile-specific Cabling – PROFINET IP 20 C·P 52 IP 65 / IP 67 X IP 65 / IP 67 to IP 20 Cat. 5 X Cat. 6 Connector type Han® 3 A connector RJ45 acc. to IEC 61 918 Number of contacts Transmission performance Transmission rate 4 Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100 Mbit/s Shielding fully shielded, 360° shielding contact Mounting Wire termination Field-assembly possible via IDC contacts Cable options – Strand diameter – Cable sheath diameter Degree of protection Operating temperature range AWG 24/7 - AWG 22/7 (stranded) AWG 23/1 - AWG 22/1 (solid) 6.5 mm - 6.9 mm IP 65 / IP 67 – 40 °C to + 70 °C Plastic version Housing material Colour Polyamide, UL 94-V0 Black Metal version Standard Housing material Colour Zinc, die-cast Grey Metal version M Housing material Colour Zinc, die-cast, chromatised, powder coated Black Advantages Field-assembly connector, Cat. 5, IP 65 / IP 67 Tool-less assembly HARTING Profile-specific Cabling – PROFINET Identification Part number Han® 3 A Connector set RJ45, 4-pole Drawing Dimensions in mm mating face according to IEC 60603.7 Plastic version straight style angled style 09 45 125 1100 09 45 125 1104 Metal version Standard straight style angled style 09 45 115 1100 09 45 115 1104 Metal version M straight style angled style 09 45 115 1102 09 45 115 1106 Dimensions valid for straight Plastic version Profile-specific Cabling – PROFINET Set consists of: Han® 3 A housing including RJ45 connector and shielding Cable gland Assembly instructions Protection cover for Han® 3 A connector Plastic version Metal version Standard Metal version M 09 20 003 5442 09 20 003 5422 09 37 003 5402 Dimensions valid for Plastic version Set of coding pins 09 46 820 0000 C·P 53 HARTING Profile-specific Cabling – PROFINET Connector sets Han® 3 A Hybrid Connector set RJ45, 4-pole to make up HARTING Han® 3 A Hybrid system cables RJ45 IP 20 IP 65 / IP 67 X IP 65 / IP 67 to IP 20 Cat. 5 X Cat. 6 Profile-specific Cabling – PROFINET Connector type HARTING Han® 3 A Hybrid connector RJ45 according to IEC 61 918 Number of contacts 4 + 4x power contacts (up to max. 48 V, 16 A) Transmission performance Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 Transmission rate Shielding 10/100 Mbit/s fully shielded, 360° shielding contact Mounting Wire termination Cable options – Wire diameter (data) – Wire diameter (power) – Cable sheath diameter Degree of protection Operating temperature range Field-assembly possible via IDC contacts Hybrid cable (2x 2 data + 4x power) AWG 24/7 - AWG 22/7 (stranded) AWG 23/1 - AWG 22/1 (solid) 1.5 mm2, stranded 10 mm - 11 mm IP 65 / IP 67 – 40 °C to + 70 °C Plastic version Housing material Colour Polyamide, UL 94-V0 Black Metal version Standard Housing material Colour Zinc, die-cast Grey Advantages Field-assembly connector, IP 65 / IP 67 Cat. 5 Tool-less assembly C·P 54 HARTING Profile-specific Cabling – PROFINET Identification Part number Han® 3 A Hybrid Connector set RJ45, 4-pole Drawing Dimensions in mm mating face according IEC 60603.7 Plastic version straight style 09 45 125 1300 Metal version Standard straight style 10 12 005 2001 Protection cover for Han® 3 A connector Plastic version Metal version Standard 09 20 003 5442 09 20 003 5422 Profile-specific Cabling – PROFINET Set consists of: Han® 3 A Hybrid housing including RJ45 connector and shielding Cable gland Assembly instructions C·P 55 HARTING Profile-specific Cabling – PROFINET Connector sets HARAX ® M12 Connector D-coding, 4-pole to make up HARTING system cables M12 Profile-specific Cabling – PROFINET IP 20 C·P 56 IP 65 / IP 67 X IP 65 / IP 67 to IP 20 Cat. 5 Connector type HARAX ® connector M12-L, D-coding Number of contacts Transmission performance Transmission rate 4 Class D according to ISO/IEC 11 801:2002 10/100 Mbit/s Shielding fully shielded, 360° shielding contact Mounting Wire termination Field-assembly possible via IDC contacts Cable options – Strand diameter – Cable sheath diameter Degree of protection Operating temperature range AWG 24 - AWG 22 (Cord) 5.5 mm - 7.2 mm IP 65 / IP 67 – 25 °C to + 85 °C Housing material Metal Advantages Field-assembly M12 connector Tool-less assembly X Cat. 6 HARTING Profile-specific Cabling – PROFINET Identification Part number Drawing Dimensions in mm HARAX ® M12 Connector D-coding, 4-pole 21 03 281 1405 View Connection side Profile-specific Cabling – PROFINET straight style C·P 57 HARTING Profile-specific Cabling – PROFINET Cables PROFINET Type A cable Industrial Cat. 5 Standard cable, 4-wire for permanent installation or to make up PROFINET system cables Profile-specific Cabling – PROFINET IP 20 X IP 65 / IP 67 X PVC Cat. 6 Star quad, double shielding 2 x 2 x AWG 22/1, solid PVC 6.5 mm Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100 Mbit/s Shielding foil and shielding braid Operating temperature range – 40 °C to + 70 °C Standard lengths Colour Printing 20 m / 50 m / 100 m / 500 m Green HARTING specific printing Advantages Robust industrial-compatible design PROFINET compliant Part number PROFINET Type A cable Industrial Cat. 5 Standard cable, 4-wire PVC   20 m ring   50 m ring 100 m ring 500 m drum 58 X Cable structure Core structure Sheath material Cable sheath diameter Transmission performance Transmission rate Shielding Identification C·P Cat. 5 09 45 600 0130 09 45 600 0140 09 45 600 0100 09 45 600 0110 Drawing Dimensions in mm HARTING Profile-specific Cabling – PROFINET Cables PROFINET Type B cable Industrial Cat. 5 stranded cable, 4-wire to make up PROFINET system cables IP 20 X IP 65 / IP 67 X PVC Cat. 5 X Cat. 6 Star quad, double shielding 2 x 2 x AWG 22/7 (Cord) PVC 6.5 mm Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100 Mbit/s Shielding foil and shielding braid Operating temperature range – 40 °C to + 70 °C Standard lengths Colour Printing 20 m / 50 m / 100 m / 500 m Green HARTING specific printing Advantages Robust industrial-compatible design PROFINET compliant Identification Part number Drawing Profile-specific Cabling – PROFINET Cable structure Core structure Sheath material Cable sheath diameter Transmission performance Transmission rate Shielding Dimensions in mm PROFINET Type B cable Industrial Cat. 5 stranded cable, 4-wire PVC   20 m ring   50 m ring 100 m ring 500 m drum 09 45 600 0132 09 45 600 0142 09 45 600 0102 09 45 600 0112 C·P 59 HARTING Profile-specific Cabling – PROFINET Cables PROFINET Type C cable Industrial Cat. 5 stranded cable, 4-wire, useable as trailing cables to connect to mobile equipment to make up PROFINET system cables Profile-specific Cabling – PROFINET IP 20 IP 65 / IP 67 X PUR Cat. 6 Star quad, double shielding 2 x 2 x AWG 22/7 (Cord) PUR 6.5 mm Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100 Mbit/s Shielding foil and shielding braid Operating temperature range – 40 °C to + 70 °C Standard lengths Colour Printing 20 m / 50 m / 100 m / 500 m Green HARTING specific printing Advantages Robust industrial-compatible design PROFINET compliant Useable as trailing cables Part number PROFINET Type C cable Industrial Cat. 5 stranded cable, 4-wire, useable as trailing cables PUR   20 m ring   50 m ring 100 m ring 500 m drum 60 X Cable structure Core structure Sheath material Cable sheath diameter Transmission performance Transmission rate Shielding Identification C·P Cat. 5 09 45 600 0131 09 45 600 0141 09 45 600 0101 09 45 600 0111 Drawing Dimensions in mm HARTING Profile-specific Cabling – PROFINET Cables PROFINET Type B cable, outdoor Industrial Cat. 5 stranded cable, 4-wire to make up PROFINET system cables IP 20 IP 65 / IP 67 X PVC Cat. 5 X Cat. 6 Star quad, double shielding 2 x 2 x AWG 22/7 (Cord) PVC 6.5 mm Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100 Mbit/s Shielding foil and shielding braid Operating temperature range – 45 °C to + 60 °C Standard lengths Colour Printing 20 m / 50 m / 100 m / 500 m Black HARTING specific printing Advantages Robust industrial-compatible design PROFINET compliant UV protected Identification Part number Drawing Profile-specific Cabling – PROFINET Cable structure Core structure Sheath material Cable sheath diameter Transmission performance Transmission rate Shielding Dimensions in mm PROFINET Type B cable, Industrial Cat. 5 stranded cable, 4-wire, Outdoor PVC   20 m ring   50 m ring 100 m ring 500 m drum 09 45 600 0135 09 45 600 0145 09 45 600 0105 09 45 600 0115 C·P 61 HARTING Profile-specific Cabling – PROFINET Cables PROFINET Type B cable, Hybrid Industrial Cat. 5 Hybrid cable, 4-wire + 4 x Power to make up Hybrid system cables Profile-specific Cabling – PROFINET IP 20 IP 65 / IP 67 X FRNC Cat. 6 Twisted Pair + 4 power cores, double shielding 2 x 2 x AWG 22/7 + 4x 84 x 0.15 (Cord) FRNC 10.3 mm Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100 Mbit/s Shielding foil and shielding braid Operating temperature range – 20 °C to + 70 °C Standard lengths Colour Printing 10 m / 20 m / 50 m / 100 m Green HARTING specific printing Advantages Robust industrial-compatible design PROFINET compliant Additional power supply Part number PROFINET Type B cable, Hybrid Industrial Cat. 5 Hybrid cable, 4-wire + 4 x Power FRNC   10 m ring   20 m ring   50 m ring 100 m ring 62 X Cable structure Core structure Sheath material Cable sheath diameter Transmission performance Transmission rate Shielding Identification C·P Cat. 5 09 45 600 0310 09 45 600 0330 09 45 600 0340 09 45 600 0300 Drawing Dimensions in mm HARTING Profile-specific Cabling – EtherNet/IP List of contents Page Introduction ...................................................................................................... C·E   2 Distribution modules and Outlets HARTING Cabinet Outlet RJ45 . .......................................................... C·E   3 Panel feed-throughs Han-Max® Panel feed-through RJ45 . ................................................. C·E   4 Han® M12 Panel feed-through D-coding . ............................................ C·E   6 System cables Industrial Ethernet Patch cable RJ45, 8-wire ....................................... C·E   8 HARTING RJ Industrial® System cable RJ45, 8-wire .......................... C·E   9 Han® M12 System cable D-coding, 4-wire ........................................... C·E 10 Connector sets HARTING RJ Industrial® Connector set RJ45, 8-pole ......................... C·E 12 Han-Max® Connector set RJ45, 8-pole ................................................ C·E 14 Han® M12 Connector, D-coding, 4-pole . ............................................. C·E 16 Industrial Cat. 6 cable, stranded, 8-wire, PVC .................................... Industrial Cat. 6 cable, stranded, 8-wire, PUR .................................... Industrial Cat. 5 outdoor cable, 8-wire ................................................. Industrial Cat. 5 cable, stranded, 8-wire .............................................. C·E 18 C·E 19 C·E 20 C·E 21 Profile-specific Cabling – EtherNet/IP Cables C·E  HARTING Profile-specific Cabling – EtherNet/IP Introduction The chapter “Profile Specific Cabling – ­ EtherNet/IP” shows the complete HARTING cabling portfolio, that links machinery, equipment and controllers in accordance with the ODVA guidelines. EtherNet/IP together with DeviceNet™ and ­ControlNet™ uses a general application layer – the “Common Industrial Protocol” (CIP™). CIP™ makes possible the use of general software and hardware interfaces and consequently the integrated connection of Automation components from the field level over the control level up to the management level. EtherNet/IP demonstrates the implementation of CIP™ over TCP/IP and Ethernet over IEEE 802.3. The EtherNet/IP cabling product portfolio covers: Distributors and Connector boxes: ­Termination and distribution of cables in harsh IP 65 / IP 67 environments, but also within control or distribution cabinets. l Panel feed-throughs: To ensure cable introduction from IP 65 / IP 67 environments into control or distribution cabinets. l System cables: Made-up system cables for quick connection of terminal boxes, distributors or active devices with machines, equipment and controllers. l Connectors: Connector sets to make up specific system cables onsite. l Cables: A comprehensive cable portfolio for the laying out / manufacture of system cables onsite. l Fundamentally all EtherNet/IP applications can be carried over a future-proof generic cabling system. ODVA approves of several variants of cabling infrastructure and includes shielded cabling (STP) as well as unshielded (UTP). Unshielded systems contain a high risk of EMC interference and consequently to service reliability. The exact use of UTP systems must be checked – in case of doubt a shielded system is to be preferred. The advantages of the HARTING EtherNet/IP cabling system at-a-glance: EtherNet/IP conformant cabling infrastructure, usable for EtherNet/IP, DeviceNet™ and ControlNet™ applications l Supports all safety features and real-time requirements of EtherNet/IP l Together with the possibility of linking 8-wire cables and connectors, EtherNet/IP already leans relatively strongly on the principles of generic cabling. Can be expanded and integrated into existing EtherNet/IP infrastructures without problems l Conformance to ODVA guidelines makes roll-outs easier in firms which have set up EtherNet/IP as the communications platform Profile-specific Cabling – EtherNet/IP l C·E  However in contrast to generic cabling, EtherNet/IP IP 65 / IP 67 infrastructure solutions go back to a special bayonet-interface for connectors and these are also included in the HARTING range of EtherNet/IP cabling, e.g. Han-Max®. Use of ODVA-recommended connectors reduces the variety of parts and makes purchasing and stocking of components easier l Closeness to generic cabling allows the use of Gigabit Ethernet or PoE in the network l HARTING‘s EtherNet/IP cabling portfolio consequently allows a simple expansion of the networks for machines, equipment and controllers within customer‘s existing EtherNet/IP structures. The high quality of the cabling system guarantees a long useful life and reliable operations l Simple planning, installation and reliable operation saves costs and delivers a high ROI l The portfolio is part of HARTING‘s comprehensive Automation IT network solution, which brings together active network technology, cabling and solutions for device and equipment power supply. The EtherNet/IP cabling system is part of HARTING‘s one-stop Automation IT network solution l HARTING Profile-specific Cabling – EtherNet/IP Distribution modules and Outlets HARTING Cabinet Outlet RJ45 RJ45 distribution module for IP 20 environments (top-hat rail mounting) X IP 65 / IP 67 to IP 20 IP 65 / IP 67 Cat. 5 Cat. 6 Number of ports, Copper / Termination Transmission performance Transmission rate Termination 2 / RJ45 (Twisted Pair) Category 6 / Class E up to 250 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s LSA-PLUS module, terminated without special tools Strand diameter Strand isolation Cable diameter Shielding AWG 24 - 22 (0.5 mm - 0.65 mm) solid and stranded 0.7 mm - 1.6 mm 6 mm - 9 mm fully shielded, 360° shielding contact Mounting Dimensions (H x W x D) Degree of protection Operating temperature range Housing material Colour mounting onto 35 mm top-hat mounting rail acc. to DIN EN 60 715, alignable 82 x 28.4 x 74 mm IP 20 – 20 °C to + 70 °C Polycarbonate, V0 light grey RAL 7035 Advantages Simple mounting Cable entering ether from bottom or from top Dust protection covers Port identification Angled outputs Identification Part number HARTING Cabinet Outlet RJ45 consisting of: 2 port-housing including dust protection cover and labels 2x RJ45 female modules, Category 6 Assembly instructions 20 76 102 8000 Drawing X Dimensions in mm Profile-specific Cabling – EtherNet/IP IP 20 C·E  HARTING Profile-specific Cabling – EtherNet/IP Panel feed-throughs Han-Max® Panel feed-through RJ45 RJ45 panel feed-through for control or distributor cabinets IP 20 IP 65 / IP 67 IP 65 / IP 67 to IP 20 X Cat. 5 X Cat. 6 Number of ports, Copper / Termination 1x RJ45 (IP 65 / IP 67) on LSA-PLUS IDC terminal (IP 20) 1x RJ45 Bayonet (IP 65 / IP 67) Transmission performance Category 5e up to 100 MHz according to TIA/EIA 568-B Transmission rate 10/100/1000 Mbit/s Profile-specific Cabling – EtherNet/IP Shielding fully shielded, 360° shielding contact and unshielded C·E  Mounting Dimensions Panel cut-out Mounting hole Degree of protection Operating temperature range Housing material Colour screw-on type on steel plate walls see drawing see drawing Diameter 27 mm IP 65 / IP 67 – 25 °C to + 85 °C Zinc, die-cast, nickel-plated metal Advantages Solid metal interface IP 65 / IP 67 with bayonet nut Shielded and unshielded HARTING Profile-specific Cabling – EtherNet/IP Part number Drawing Dimensions in mm Han-Max® Panel feed-through RJ45 fully shielded (STP) unshielded (UTP) 09 15 300 0302 09 15 300 0301 consisting of: Bulkhead mounted including seal RJ45 female module, mounted on PCB LSA-PLUS termination blocks on the rear side 09 15 300 0301 09 15 300 0302 Protection cover for panel feed-through Panel cut-out for max. wall thickness 2.3 mm 09 15 300 5411 Length l (mm) 31.5 42.0 Profile-specific Cabling – EtherNet/IP Identification C·E  HARTING Profile-specific Cabling – EtherNet/IP Panel feed-throughs Han® M12 Panel feed-through D-coding M12 panel feed-through for control or distributor cabinets IP 20 IP 65 / IP 67 Profile-specific Cabling – EtherNet/IP Number of ports, Copper / Termination C·E  IP 65 / IP 67 to IP 20 X Cat. 5 X Cat. 6 Transmission performance Transmission rate 2 / 1x M12, D-coding (IP 65 / IP 67) 1x RJ45 (Twisted Pair) (IP 20) Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100 Mbit/s Shielding fully shielded, 360° shielding contact Mounting Dimensions Panel cut-out Degree of protection Operating temperature range screw-on type on steel plate walls see drawing Diameter 16.5 mm IP 65 / IP 67 – 5 °C to + 60 °C Housing material Colour Metal / plastic Black Advantages Simple mounting RJ45 plug-compatible on back side HARTING Profile-specific Cabling – EtherNet/IP Identification Part number Drawing Dimensions in mm Han® M12 Panel feed-through D-coding straight 21 03 381 2400 Han® M12 Panel feed-through D-coding 21 03 381 4400 Profile-specific Cabling – EtherNet/IP angled C·E  HARTING Profile-specific Cabling – EtherNet/IP System cables HARTING Industrial Ethernet Patch cable RJ45, 8-wire RJ45 connection cable for control or distributor cabinets or within controllers Profile-specific Cabling – EtherNet/IP IP 20 C·E  X IP 65 / IP 67 IP 65 / IP 67 to IP 20 Cat. 5 X Cat. 6 Connector types Cable types Sheath material Wiring Transmission performance Transmission rate Shielding Operating temperature range RJ45, overmoulded 4 x 2, Twisted Pair, shielded PUR, halogen-free LSZH 8-pole, 1:1 Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s fully shielded, 360° shielding contact – 20 °C to + 60 °C Standard lengths Colour 0.5 m / 1 m / 2 m / 3 m / 5 m / 7.5 m other lengths on request Black or Green Advantages Robust design Easy handling for all applications Identification Part number HARTING Industrial Ethernet Patch cable RJ45, 8-wire Length 0.5 m Length 1.0 m Length 2.0 m Length 3.0 m Length 5.0 m Length 7.5 m Black Green 09 45 971 1121 09 45 971 1122 09 45 971 1123 09 45 971 1124 09 45 971 1126 09 45 971 1129 09 45 971 1101 09 45 971 1102 09 45 971 1103 09 45 971 1104 09 45 971 1106 09 45 971 1109 HARTING Profile-specific Cabling – EtherNet/IP System cables HARTING RJ Industrial® System cable RJ45, 8-wire RJ45 connection cable for control or distributor cabinets or within controllers X IP 65 / IP 67 IP 65 / IP 67 to IP 20 Cat. 5 Cat. 6 Connector types Cable types Sheath material Wiring Transmission performance Transmission rate Shielding Operating temperature range RJ45 4 x 2, Twisted Pair, shielded PIMF PVC 8-pole, 1:1 Category 6 / Class E up to 250 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s fully shielded, 360° shielding contact – 10 °C to + 70 °C Standard lengths Colour 1.5 m / 3 m / 5 m / 10 m / 20 m other lengths on request Green Advantages Robust industrial design High operational reliability in vibration-prone locations Identification Part number HARTING RJ Industrial System cable RJ45, 8-wire Green Length   1.5 m Length   3.0 m Length   5.0 m Length 10.0 m Length 20.0 m 09 45 751 1523 09 45 751 1525 09 45 751 1527 09 45 751 1551 09 45 751 1553 Drawing X Dimensions in mm Profile-specific Cabling – EtherNet/IP IP 20 C·E  HARTING Profile-specific Cabling – EtherNet/IP System cables Han® M12 System cable, 4-wire Han® M12 connection cable, D-coding, for harsh industrial environments Profile-specific Cabling – EtherNet/IP IP 20 C·E 10 IP 65 / IP 67 X IP 65 / IP 67 to IP 20 Cat. 5 X Cat. 6 Connector types Han® M12, D-coding, overmoulded Cable types Sheath material Wiring Transmission performance Transmission rate Shielding 2 x 2 x AWG 22/7, Twisted Pair, shielded PUR 4-pole (RJ45 contacts 1/2 and 3/6) Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100 Mbit/s fully shielded, 360° shielding contact Operating temperature range – 25 °C to + 70 °C Standard lengths Colour 1m/3m/5m other lengths on request Green Advantages Robust design Use on-site made possible by IP 65 / IP 67 protection Identification Part number Han® M12 System cable, 4-wire Length 1.0 m Length 3.0 m Length 5.0 m 21 03 485 1401 21 03 485 1403 21 03 485 1405 Drawing Dimensions in mm Profile-specific Cabling – EtherNet/IP Notes C·E 11 HARTING Profile-specific Cabling – EtherNet/IP Connector sets HARTING RJ Industrial® Connector set RJ45, 8-pole to make up RJ45 system cables IP 20 X IP 65 / IP 67 IP 65 / IP 67 to IP 20 Cat. 5 Cat. 6 Connector type Number of contacts Transmission performance Transmission rate RJ45 connector acc. to IEC 60 603-7 8 Category 6 / Class E up to 250 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s Shielding fully shielded, 360° shielding contact Mounting Wire termination Field-assembly possible via piercing contacts Cable options – Strand diameter – Cable sheath diameter Degree of protection Operating temperature range Housing material Colour AWG 42/7 - AWG 27/7 6.5 mm - 6.9 mm IP 20 – 40 °C to + 70 °C Polycarbonate, UL 94-V0 Black Advantages Field-assembly connector, Cat. 6 X Profile-specific Cabling – EtherNet/IP Mounting information If the cable is assembled on both sides, please use one connector set with white and one connector set with blue cable manager (delivers optimal transmission behavior) C·E 12 HARTING Profile-specific Cabling – EtherNet/IP Identification Part number HARTING RJ Industrial® Connector set RJ45, 8-pole with cable manager White cable manager Blue Drawing Dimensions in mm mating face according to IEC 60 603-7 09 45 151 1500 09 45 151 1510 Set consists of: Housing including shielding Cable gland Assembly instructions contact no. 8 contact no. 1 Mounting tools 09 45 800 0500 Profile-specific Cabling – EtherNet/IP for RJ45 connector set C·E 13 HARTING Profile-specific Cabling – EtherNet/IP Connector sets Han-Max® Connector set RJ45, 8-pole to make up PushPull system cables RJ45 Profile-specific Cabling – EtherNet/IP IP 20 C·E 14 IP 65 / IP 67 X IP 65 / IP 67 to IP 20 Cat. 5 X Cat. 6 Connector type Number of contacts Transmission performance Transmission rate Bayonet connector RJ45 acc. to IEC 24 702 8 Category 5e up to 100 MHz according to TIA/EIA 568-B 10/100/1000 Mbit/s Shielding fully shielded, 360° shielding contact and unshielded Mounting Wire termination Field-assembly possible via crimp contacts Cable options – Strand diameter – Cable sheath diameter Degree of protection Operating temperature range Housing material Colour AWG 24 - AWG 26 (Cord) 4 mm - 8 mm IP 65 / IP 67 – 25 °C to + 80 °C Zinc, die-cast, nickel-plated metal Advantages Very robust IP 65 / IP 67 connector with bayonet nut Field-assembly connector, Cat. 5e, IP 65 / IP 67 HARTING Profile-specific Cabling – EtherNet/IP Identification Part number Drawing Dimensions in mm Han-Max® Connector set RJ45, 8-pole STP UTP 09 15 300 0402 09 15 300 0401 Set consists of: Bayonet housing including RJ45 connector Cable gland Assembly instructions Protection cover 09 15 300 5401 Profile-specific Cabling – EtherNet/IP for Han-Max® connector C·E 15 HARTING Profile-specific Cabling – EtherNet/IP Connector sets HARAX ® M12 Connector D-coding, 4-pole to make up HARTING system cables M12 Profile-specific Cabling – EtherNet/IP IP 20 C·E 16 IP 65 / IP 67 X IP 65 / IP 67 to IP 20 Cat. 5 Connector type HARAX ® connector M12-L, D-coding Number of contacts Transmission performance Transmission rate 4 Class D according to ISO/IEC 11 801:2002 10/100 Mbit/s Shielding fully shielded, 360° shielding contact Mounting Wire termination Field-assembly possible via IDC contacts Cable options – Strand diameter – Cable sheath diameter Degree of protection Operating temperature range AWG 24 - AWG 22 (Cord) 5.5 mm - 7.2 mm IP 65 / IP 67 – 25 °C to + 85 °C Housing material Metal Advantages Field-assembly M12 connector Tool-less assembly X Cat. 6 HARTING Profile-specific Cabling – EtherNet/IP Identification Part number Drawing Dimensions in mm HARAX ® M12 Connector D-coding, 4-pole 21 03 281 1405 View Connection side Profile-specific Cabling – EtherNet/IP straight style C·E 17 HARTING Profile-specific Cabling – EtherNet/IP Cables Industrial Cat. 6 cable, stranded, 8-wire, PVC to make up flexible connections (one- or two-sided assembled system cables) Profile-specific Cabling – EtherNet/IP IP 20 C·E 18 X IP 65 / IP 67 X PVC Cat. 5 Cat. 6 Cable structure Core structure Sheath material Cable sheath diameter Transmission performance Transmission rate Shielding Operating temperature range 4 x 2, Twisted Pair, shielded, PIMF Cord, 4 x 2 x AWG 27/7 PVC 6.8 mm Category 6 / Class E up to 250 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s each pair shielded and additional shield for the whole cable – 10 °C to + 70 °C Standard lengths Colour 20 m / 50 m / 100 m / 500 m Green Advantages Robust industrial-compatible design Optimal power reserves Identification Part number Industrial Cat. 6 cable, stranded, 8-wire PVC   20 m ring   50 m ring 100 m ring 500 m drum 09 45 600 0530 09 45 600 0540 09 45 600 0500 09 45 600 0520 Drawing X Dimensions in mm HARTING Profile-specific Cabling – EtherNet/IP Cables Industrial Cat. 6 cable, stranded, 8-wire, PUR to make up flexible connections (one- or two-sided assembled system cables) X IP 65 / IP 67 X PUR, halogen-free Cat. 5 Cat. 6 Cable structure Core structure Sheath material Cable sheath diameter Transmission performance Transmission rate Shielding Operating temperature range 4 x 2, Twisted Pair, shielded, PIMF Cord, 4 x 2 x AWG 27/7 PUR, halogen-free 6.8 mm Category 6 / Class E up to 250 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s each pair shielded and additional shield for the whole cable – 40 °C to + 70 °C Standard lengths Colour 20 m / 50 m / 100 m / 500 m Green Advantages Robust industrial-compatible design Halogen-free Identification Part number Industrial Cat. 6 cable, stranded, 8-wire PUR   20 m ring   50 m ring 100 m ring 500 m drum 09 45 600 0630 09 45 600 0640 09 45 600 0600 09 45 600 0620 Drawing X Dimensions in mm Profile-specific Cabling – EtherNet/IP IP 20 C·E 19 HARTING Profile-specific Cabling – EtherNet/IP Cables Industrial Cat. 5 outdoor cable, 8-wire to make up flexible connections (one- or two-sided assembled system cables) Profile-specific Cabling – EtherNet/IP IP 20 C·E 20 X IP 65 / IP 67 X PVC Cat. 5 X Cat. 6 Cable structure Core structure Sheath material Cable sheath diameter Transmission performance Transmission rate Shielding Operating temperature range 4 x 2, Twisted Pair, shielded, PIMF Cord, 4 x 2 x AWG 26/7 PVC 6.7 mm Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s each pair shielded and additional shield for the whole cable – 45 °C to + 60 °C Standard lengths Colour 20 m / 50 m / 100 m / 500 m Black Advantages Robust industrial-compatible design Applicable also for outside applications Identification Part number Industrial Cat. 5 outdoor cable, 8-wire   20 m ring   50 m ring 100 m ring 500 m drum 09 45 600 0230 09 45 600 0240 09 45 600 0200 09 45 600 0220 Drawing Dimensions in mm HARTING Profile-specific Cabling – EtherNet/IP Cables Industrial Cat. 5 cable, stranded, 8-wire, PUR to make up flexible connections (one- or two-sided assembled system cables) X IP 65 / IP 67 X PUR Cat. 5 X Cat. 6 Cable structure Core structure Sheath material Cable sheath diameter Transmission performance Transmission rate Shielding Operating temperature range 4 x 2, Twisted Pair, shielded, PIMF Cord, 4 x 2 x AWG 26/7 PUR 6.7 mm Category 5 / Class D up to 100 MHz according to ISO/IEC 11 801:2002, prEN 50 173-1 10/100/1000 Mbit/s each pair shielded and additional shield for the whole cable – 45 °C to + 60 °C Standard lengths Colour 20 m / 50 m / 100 m / 500 m Green Advantages Robust industrial-compatible design Halogen-free Identification Part number Industrial Cat. 5 stranded cable, 8-wire PUR   20 m ring   50 m ring 100 m ring 500 m drum 09 45 600 0430 09 45 600 0440 09 45 600 0400 09 45 600 0420 Drawing Dimensions in mm Profile-specific Cabling – EtherNet/IP IP 20 C·E 21 Profile-specific Cabling – EtherNet/IP Notes C·E 22 HARTING Tools List of contents Page Tools C·W  HARTING Tools Identification Part number HARTING RJ Industrial® GigalinkMounting tools for 4-pair HARTING RJ Industrial® Gigalink connectors 09 45 800 0500 With the RJ Industrial Gigalink Assembly Tool 4-pair connectors can be quickly, easily and reliably connected to flexible cables. HARTING RJ Industrial® Stripping Tool Stripping tool for 2-pair PROFINET cables including blade cassette 09 45 800 0000 Blade cassette 09 45 800 0001 The RJ Industrial Stripping Tool allows the insulation to be quickly and easily removed from 2-pair Industrial Ethernet cables with di­ameters between 2.5 - 8 mm. The tool is pre-set for a cable diameter of 6.5 mm. It ­allows the cable sheath and screening braid to be stripped consistently and simultaneously. HARTING RJ Industrial® LSA-Punch Down Tool 09 45 800 0020 The LSA-Punch Down Tool is used to wire RJ45 Industrial Metal Outlets (part no. 09 45 815 1100, see page C·P 6). The various conductors are cut to length and inserted into the insulation displacement contacts in a single pass. C·W  HARTING Automation IT eCon 2000 eCon 3000 eCon 6000 eCon 7000 eCon 9000 sCon 3000 sCon 9000 pCon 7000 pCon 2000 mCon 6000 mCon 7000 mCon 9000 mCon 3000 Standard / Approvals Shock assay IEC 60 068-2-27 X X X X X X X X X Vibration IEC 60 068-2-6 X X X X X X X X X Rail standard EN 50 155, Class 1 X X X X X X X Mechanical stability EMC standards Interference immunity ESD IEC 61 000-4-2 X X X X X X X X X Interference immunity HF, radiated IEC 61 000-4-3 X X X X X X X X X Interference immunity Burst IEC 61 000-4-4 X X X X X X X X X Interference immunity Surge IEC 61 000-4-5 X X X X X X X X X Interference immunity IEC 61 000-4-6 X X X X X X X X X Emitted radiation EN 55 011, Class A X X X X X X X X X Emitted radiation EN 55 022, Class A X X X X X X X X X System perturbation IEC 61 000-3-3 X X Rail standard EN 50 121-3-2 X X X X X X X Z  HARTING Automation IT Overview old – new product names Identification Part number Z  Old New 20 76 108 3000 ESC TP08 eCon 3080-A 20 76 108 3001 ESC TP08-F eCon 3080-A1 20 76 108 3002 ESC TP08-S eCon 3080-A2 20 76 108 3003 ESC TP08-S-F eCon 3080-A3 20 76 108 3004 ESC TP08 EXT eCon 3080-A4 20 76 108 3005 ESC TP08-Plus eCon 3080-A5 20 76 107 3100 ESC TP06/FX01-SC eCon 3061-AD 20 76 108 3100 ESC TP06/FX02-SC eCon 3062-AD 20 76 108 3101 ESC TP06/FX02-SC-F eCon 3062-AD1 20 76 108 3103 ESC TP06/FX02-SC-SM eCon 3062-AF 20 76 110 3100 ESC TP08/FX02-SC eCon 3082-AD 20 76 110 3101 ESC TP08/FX02-SC-F eCon 3082-AD1 20 76 107 3200 ESC TP06/FX01-ST eCon 3061-AE 20 76 108 3200 ESC TP06/FX02-ST eCon 3062-AE 20 76 108 3201 ESC TP06/FX02-ST-F eCon 3062-AE1 20 76 110 3200 ESC TP08/FX02-ST eCon 3082-AE 20 76 110 3201 ESC TP08/FX02-ST-F eCon 3082-AE1 20 73 305 3921 ESC 67-30 TP05U RJI eCon 6050-A 20 73 305 3941 ESC 67-30 TP05U M12 eCon 6050-BA 20 73 308 3972 ESC 67-30 TP08U RJI Hybrid eCon 6080-HA 20 70 305 3921 ESC 67-10 TP05U RJI eCon 7050-A 20 70 305 3941 ESC 67-10 TP05U M12 eCon 7050-B 20 70 310 3921 ESC 67-10 TP10U RJI eCon 7100-A 20 70 310 3941 ESC 67-10 TP10U M12 eCon 7100-B 20 76 208 7000 ESC 20-19 TP07/01 U M12 eCon 9080-B HARTING Automation IT Overview old – new product names Identification Part number Old New 20 76 110 1000 ESC TP10-SmartCon sCon 3100-A 20 76 110 1001 ESC TP10-Giga-SmartCon sCon 3100-AA 20 76 107 1100 ESC TP06/FX01-SC-SmartCon sCon 3061-AD 20 76 109 1100 ESC TP06/FX03-SC-SmartCon sCon 3063-AD 20 76 110 1100 ESC TP08/FX02-SC-SmartCon sCon 3082-AD 20 76 107 1200 ESC TP06/FX01-ST-SmartCon sCon 3061-AE 20 76 109 1200 ESC TP06/FX03-ST-SmartCon sCon 3063-AE 20 76 110 1200 ESC TP08/FX02-ST-SmartCon sCon 3082-AE 20 76 106 7000 ESC 20-19 TP06-S1-SmartCon sCon 9080-A 20 76 110 4000 ESC TP10-M mCon 3100-A 20 76 107 4100 ESC TP06/FX01-SC-M mCon 3061-AD 20 76 109 4100 ESC TP06/FX03-SC-M mCon 3063-AD 20 76 110 4100 ESC TP08/FX02-SC-M mCon 3082-AD 20 76 107 4200 ESC TP06/FX01-ST-M mCon 3061-AE 20 76 109 4200 ESC TP06/FX03-ST-M mCon 3063-AE 20 76 110 4200 ESC TP08/FX02-ST-M mCon 3082-AE 20 73 305 4921 ESC 67-30 TP05M RJI mCon 6050-A 20 73 305 4941 ESC 67-30 TP05M M12 mCon 6050-BA 20 70 305 4921 ESC 67-10 TP05M RJI mCon 7050-A 20 70 305 4941 ESC 67-10 TP05M M12 mCon 7050-B 20 70 310 4921 ESC 67-10 TP10M RJI mCon 7100-A 20 70 310 4941 ESC 67-10 TP10M M12 mCon 7100-B 20 76 208 7001 ESC 20-19 TP07/01 M M12 mCon 9080-B 20 80 300 3011 IPS 67-10 1-2-95W Han 3 A pCon 7095-24A 20 80 300 3012 IPS 67-10 1-2-95W M12 pCon 7095-24B Z  HARTING Automation IT Overview old – new product names Part number Z  Identification Old New 09 45 845 1500 HARTING RJ Industrial Outlet PushPull HARTING PushPull Outlet RJ45 09 45 845 1501 HARTING RJ Industrial Outlet PushPull HARTING PushPull Outlet RJ45 09 45 245 1102 IP 67 PushPull Panel feed-through HARTING PushPull Panel feedthrough RJ45 09 45 971 112x RJ Industrial Standard Patch cable IP 20 HARTING Industrial Ethernet Patch cable RJ45, 8-wire, Black 09 45 971 110x RJ Industrial Standard Patch cable IP 20 HARTING Industrial Ethernet Patch cable RJ45, 8-wire, Green 09 45 751 15xx RJ Industrial Fieldpatch IP 20 HARTING Industrial Ethernet System cable RJ45, 8-wire, Green 09 45 745 15xx RJ Industrial Fieldpatch IP 67 PushPull HARTING PushPull System cable RJ45, 8-wire, Green 09 45 715 15xx RJ Industrial Fieldpatch IP 67 Data 3A Han® 3 A System cable RJ45, 8-wire, Green 09 45 151 15x0 IP 20 Data-Connector, 4 pairs HARTING RJ Industrial® Connectors RJ45, 8-pole 09 45 145 15x0 IP 67 PushPull Connector, 4 pairs HARTING PushPull Connectors RJ45, 8-pole 09 45 125 15x0 IP 67 Data 3A Connector, 4 pairs Han® 3 A Connectors RJ45, 8-pole 09 45 115 15xx IP 67 Data 3A Connector, 4 pairs Han® 3 A Connectors RJ45, 8-pole 09 45 600 05x0 Gigabit Ethernet wire, 4 pairs Industrial Cat. 6 cable, stranded, 8-wire, PVC 09 45 600 06x0 Gigabit Ethernet wire, 4 pairs, halogen-free Industrial Cat. 6 cable, stranded, 8-wire, PUR 09 45 600 02x0 Industrial Ethernet cable, 4 pairs Industrial Cat. 5 outdoor cable, 8-wire 09 45 600 04x0 Industrial Ethernet cable, 4 pairs Industrial Cat. 5 cable, stranded, 8-wire, PUR HARTING Automation IT Overview old – new product names Identification Part number Old New 20 79 302 0922 HARTING RJ Industrial Metal Outlet Cat. 6 Han® 3 A Metal Outlet RJ45, Cat. 6 09 45 815 1100 HARTING RJ Industrial Metal Outlet Han® 3 A Metal Outlet RJ45, Cat. 5 20 73 302 4941 Industrial outlet with Metal housing INO 67 M12 HARTING M12 Metal Outlet D-coding, Cat. 5 09 42 2x5 11xx IP 67 Data 3A-Panel feed-through Han® 3 A Panel feed-through RJ45 09 45 2x5 11xx IP 67 Data 3A-Hybrid double-coupling Han® 3 A Hybrid double-coupling RJ45 09 45 225 1300 IP 67 Hybrid-Panel feed-through Han® 3 A Hybrid panel feedthrough RJ45 10 12 005 1003 HARTING RJ Industrial Hybrid Hybrid doublecoupling IP 67 (Metal) Han® 3 A Hybrid double-coupling RJ45 21 03 381 x400 Adapter M12-RJ45 Han® M12 Panel feed-through D-coding 21 03 485 14xx System cable with circular connector Han M12 Han® M12 System cable, 4-wire 09 45 971 11xx RJ Industrial standard Patch cable IP 20 HARTING Industrial Ethernet Patch cable RJ45, 8-wire 09 45 771 xxxx RJ Industrial overmoulded IP 20 HARTING RJ Industrial® System cable RJ45, 4-wire 09 47 050 60xx RJ Industrial overmoulded IP 20 HARTING RJ Industrial® System cable RJ45, angled, 4wire 09 45 715 xxxx RJ Industrial Fieldpatch IP 67 Data 3A Han® 3 A System cable RJ45, 4-wire 09 45 700 xxxx RJ Industrial Fieldpatch IP 67 Data 3A Han® 3 A System cable RJ45, 4-wire 09 45 715 13xx RJ Industrial Fieldpatch IP 67 Hybrid Han® 3 A Hybrid system cables RJ45, 4-wire 09 45 7xx xxxx RJ Industrial Fieldpatch IP 67 PushPull HARTING PushPull System cable RJ45, 4-wire 09 45 701 xxxx RJ Industrial Fieldpatch IP 67 PushPull HARTING PushPull System cable RJ45, 4-wire 21 03 485 140x System cable with circular connector Han M12 Han® M12 System cable, 4-wire 21 03 281 1405 HARAX circular connector M12-L HARAX® M12 Connector D-coding, 4-pole 09 15 300 030x Han-Max® Panel feed-through Han-Max® Panel feed-through RJ45 09 15 300 040x Han-Max® cable side Han-Max® Connector set RJ45, 8-pole Z  List of part numbers Part number Z  Page Part number Page 09 15 300 0301 09 15 300 0302 09 15 300 030x 09 15 300 0401 09 15 300 0402 09 15 300 040x 09 15 300 5401 09 15 300 5411 C·E   5 C·E   5 Z 5 C·E 15 C·E 15 Z 5 C·E 15 C·E   5 09 45 115 1510 09 45 115 1512 09 45 115 15xx C·G 17 C·G 17 Z 4 09 45 125 1100 09 45 125 1104 09 45 125 1300 09 45 125 1500 09 45 125 1510 09 45 125 15x0 C·P 53 C·P 53 C·P 55 C·G 17 C·G 17 Z 4 09 20 003 2711 09 20 003 2711 09 20 003 5422 09 20 003 5422 09 20 003 5422 09 20 003 5425 09 20 003 5425 09 20 003 5425 09 20 003 5425 09 20 003 5426 09 20 003 5426 09 20 003 5426 09 20 003 5426 09 20 003 5442 09 20 003 5442 09 20 003 5442 09 20 003 5445 09 20 003 5445 09 20 003 5445 A·E 41 A·M 24 C·G 17 C·P 53 C·P 55 C·P   9 C·P 11 C·P 13 C·P 15 A·E 41 A·E 41 A·M 24 A·M 24 C·G 17 C·P 53 C·P 55 C·P   9 C·P 11 C·P 13 09 45 145 1100 09 45 145 1500 09 45 145 1510 09 45 145 15x0 C·P 47 C·G 15 C·G 15 Z 4 09 45 151 1100 09 45 151 1500 09 45 151 1500 09 45 151 1510 09 45 151 1510 09 45 151 15x0 C·P 45 C·G 13 C·E 13 C·G 13 C·E 13 Z 4 09 45 215 1100 09 45 215 1102 09 45 215 1103 09 45 215 1107 09 45 215 1108 09 45 215 1109 09 45 215 1110 C·P   9 C·P   9 C·P   9 C·P 11 C·P   9 C·P   9 C·P 11 09 20 004 2711 09 20 004 2711 A·E 41 A·M 24 09 35 221 0421 09 35 221 0422 C·P 49 C·P 51 09 45 225 1100 09 45 225 1107 09 45 225 1108 09 45 225 1300 09 45 225 1300 C·P 9 C·P 11 C·P   9 C·P 13 Z 5 09 45 245 1102 09 45 245 1102 C·G   7 Z 4 09 37 003 5402 09 37 003 5402 09 37 003 5405 09 37 003 5405 C·G 17 C·P 53 C·P   9 C·P 11 09 45 2x5 11xx Z 5 09 42 2x5 11xx Z 5 09 45 115 1100 09 45 115 1102 09 45 115 1104 09 45 115 1106 09 45 115 1500 09 45 115 1502 C·P 53 C·P 53 C·P 53 C·P 53 C·G 17 C·G 17 09 45 600 0100 09 45 600 0101 09 45 600 0102 09 45 600 0105 09 45 600 0110 09 45 600 0111 09 45 600 0112 09 45 600 0115 09 45 600 0130 09 45 600 0131 09 45 600 0132 09 45 600 0135 09 45 600 0140 09 45 600 0141 C·P 58 C·P 60 C·P 59 C·P 61 C·P 58 C·P 60 C·P 59 C·P 61 C·P 58 C·P 60 C·P 59 C·P 61 C·P 58 C·P 60 Part number Page 09 45 600 0142 09 45 600 0145 09 45 600 0200 09 45 600 0200 09 45 600 0220 09 45 600 0220 09 45 600 0230 09 45 600 0230 09 45 600 0240 09 45 600 0240 09 45 600 02x0 09 45 600 0300 09 45 600 0310 09 45 600 0330 09 45 600 0340 09 45 600 0400 09 45 600 0400 09 45 600 0420 09 45 600 0420 09 45 600 0430 09 45 600 0430 09 45 600 0440 09 45 600 0440 09 45 600 04x0 09 45 600 0500 09 45 600 0500 09 45 600 0520 09 45 600 0520 09 45 600 0530 09 45 600 0530 09 45 600 0540 09 45 600 0540 09 45 600 05x0 09 45 600 0600 09 45 600 0600 09 45 600 0620 09 45 600 0620 09 45 600 0630 09 45 600 0630 09 45 600 0640 09 45 600 0640 09 45 600 06x0 C·P 59 C·P 61 C·G 20 C·E 20 C·G 20 C·E 20 C·G 20 C·E 20 C·G 20 C·E 20 Z 4 C·P 62 C·P 62 C·P 62 C·P 62 C·G 21 C·E 21 C·G 21 C·E 21 C·G 21 C·E 21 C·G 21 C·E 21 Z 4 C·G 18 C·E 18 C·G 18 C·E 18 C·G 18 C·E 18 C·G 18 C·E 18 Z 4 C·G 19 C·E 19 C·G 19 C·E 19 C·G 19 C·E 19 C·G 19 C·E 19 Z 4 09 45 700 0023 09 45 700 0025 09 45 700 0027 09 45 700 0051 09 45 700 0053 09 45 700 1123 09 45 700 1125 09 45 700 1127 09 45 700 1151 C·P 31 C·P 31 C·P 31 C·P 31 C·P 31 C·P 31 C·P 31 C·P 31 C·P 31 Part number Page 09 45 700 1153 09 45 700 1164 09 45 700 1166 09 45 700 1168 09 45 700 1173 09 45 700 1175 09 45 700 xxxx C·P 31 C·P 31 C·P 31 C·P 31 C·P 31 C·P 31 Z 5 09 45 701 0023 09 45 701 0025 09 45 701 0027 09 45 701 0051 09 45 701 0053 09 45 701 0064 09 45 701 0066 09 45 701 0068 09 45 701 0073 09 45 701 0075 09 45 701 1123 09 45 701 1125 09 45 701 1127 09 45 701 1151 09 45 701 1153 09 45 701 1164 09 45 701 1166 09 45 701 1168 09 45 701 1173 09 45 701 1175 09 45 701 xxxx C·P 41 C·P 41 C·P 41 C·P 41 C·P 41 C·P 35 C·P 35 C·P 35 C·P 35 C·P 35 C·P 41 C·P 41 C·P 41 C·P 41 C·P 41 C·P 41 C·P 41 C·P 41 C·P 41 C·P 41 Z 5 09 45 715 0023 09 45 715 0025 09 45 715 0027 09 45 715 0051 09 45 715 0053 09 45 715 1123 09 45 715 1125 09 45 715 1127 09 45 715 1151 09 45 715 1153 09 45 715 1164 09 45 715 1166 09 45 715 1168 09 45 715 1173 09 45 715 1175 09 45 715 13xx 09 45 715 1523 09 45 715 1525 09 45 715 1527 09 45 715 1551 09 45 715 1553 09 45 715 15xx 09 45 715 xxxx C·P 29 C·P 29 C·P 29 C·P 29 C·P 29 C·P 29 C·P 29 C·P 29 C·P 29 C·P 29 C·P 29 C·P 29 C·P 29 C·P 29 C·P 29 Z 5 C·G 11 C·G 11 C·G 11 C·G 11 C·G 11 Z 4 Z 5 List of part numbers Part number Page 09 45 725 1323 09 45 725 1325 09 45 725 1327 09 45 725 1351 09 45 725 1353 C·P 33 C·P 33 C·P 33 C·P 33 C·P 33 09 45 745 0023 09 45 745 0025 09 45 745 0027 09 45 745 0051 09 45 745 0053 09 45 745 1123 09 45 745 1125 09 45 745 1127 09 45 745 1151 09 45 745 1153 09 45 745 1164 09 45 745 1166 09 45 745 1168 09 45 745 1173 09 45 745 1175 09 45 745 1523 09 45 745 1525 09 45 745 1527 09 45 745 1551 09 45 745 1553 09 45 745 15xx C·P 35 C·P 35 C·P 35 C·P 35 C·P 35 C·P 35 C·P 35 C·P 35 C·P 35 C·P 35 C·P 35 C·P 35 C·P 35 C·P 35 C·P 35 C·G   10 C·G   10 C·G   10 C·G   10 C·G   10 Z 4 09 45 751 1523 09 45 751 1523 09 45 751 1525 09 45 751 1525 09 45 751 1527 09 45 751 1527 09 45 751 1551 09 45 751 1551 09 45 751 1553 09 45 751 1553 09 45 751 15xx C·G   9 C·E   9 C·G   9 C·E   9 C·G   9 C·E   9 C·G   9 C·E   9 C·G   9 C·E   9 Z 4 09 45 771 0023 09 45 771 0025 09 45 771 0027 09 45 771 0051 09 45 771 0053 09 45 771 1123 09 45 771 1125 09 45 771 1127 09 45 771 1151 09 45 771 1153 09 45 771 1164 09 45 771 1166 09 45 771 1168 09 45 771 1173 C·P 21 C·P 21 C·P 21 C·P 21 C·P 21 C·P 21 C·P 21 C·P 21 C·P 21 C·P 21 C·P 21 C·P 21 C·P 21 C·P 21 Part number Page 09 45 771 1175 09 45 771 xxxx C·P 21 Z 5 09 45 7xx xxxx Z 5 09 45 800 0000 09 45 800 0001 09 45 800 0020 09 45 800 0500 09 45 800 0500 09 45 800 0500 09 45 800 0500 09 45 800 0500 C·W   2 C·W   2 C·W   2 C·G 13 C·G 15 C·G 17 C·E 13 C·W   2 09 45 815 1100 09 45 815 1100 C·P   6 Z 5 09 45 820 0000 09 45 820 0000 09 45 820 0000 09 45 820 0000 C·P   9 C·P 11 C·P 13 C·P 15 09 45 845 0001 09 45 845 0001 09 45 845 0004 09 45 845 1500 09 45 845 1500 09 45 845 1501 09 45 845 1501 C·G 15 C·P 47 C·G   7 C·G   4 Z 4 C·G   4 Z 4 09 45 971 1101 09 45 971 1101 09 45 971 1101 09 45 971 1102 09 45 971 1102 09 45 971 1102 09 45 971 1103 09 45 971 1103 09 45 971 1103 09 45 971 1104 09 45 971 1104 09 45 971 1104 09 45 971 1106 09 45 971 1106 09 45 971 1106 09 45 971 1109 09 45 971 1109 09 45 971 1109 09 45 971 110x 09 45 971 1121 09 45 971 1121 09 45 971 1121 09 45 971 1122 09 45 971 1122 09 45 971 1122 C·G   8 C·P 19 C·E   8 C·G   8 C·P 19 C·E   8 C·G   8 C·P 19 C·E   8 C·G   8 C·P 19 C·E   8 C·G   8 C·P 19 C·E   8 C·G   8 C·P 19 C·E   8 Z 4 C·G   8 C·P 19 C·E   8 C·G   8 C·P 19 C·E   8 Part number Page 09 45 971 1123 09 45 971 1123 09 45 971 1123 09 45 971 1124 09 45 971 1124 09 45 971 1124 09 45 971 1126 09 45 971 1126 09 45 971 1126 09 45 971 1129 09 45 971 1129 09 45 971 1129 09 45 971 112x 09 45 971 11xx C·G   8 C·P 19 C·E   8 C·G   8 C·P 19 C·E   8 C·G   8 C·P 19 C·E   8 C·G   8 C·P 19 C·E   8 Z 4 Z 5 09 46 820 0000 C·P 53 09 47 030 0001 09 47 030 0002 09 47 030 0003 09 47 030 0004 09 47 030 0005 09 47 030 0007 09 47 030 0023 09 47 030 0024 09 47 030 0025 09 47 030 0026 09 47 030 0027 09 47 030 0029 09 47 030 0045 09 47 030 0046 09 47 030 0047 09 47 030 0048 09 47 030 0049 09 47 030 0051 09 47 030 0067 09 47 030 0068 09 47 030 0069 09 47 030 0070 09 47 030 0071 09 47 030 0073 09 47 030 4001 09 47 030 4002 09 47 030 4003 09 47 030 4004 09 47 030 4005 09 47 030 4007 09 47 030 4023 09 47 030 4024 09 47 030 4025 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 25 C·P 25 C·P 25 C·P 25 C·P 25 C·P 25 C·P 25 C·P 25 C·P 25 Part number Page 09 47 030 4026 09 47 030 4027 09 47 030 4029 09 47 030 4045 09 47 030 4046 09 47 030 4047 09 47 030 4048 09 47 030 4049 09 47 030 4051 09 47 030 4067 09 47 030 4068 09 47 030 4069 09 47 030 4070 09 47 030 4071 09 47 030 4073 C·P 25 C·P 25 C·P 25 C·P 25 C·P 25 C·P 25 C·P 25 C·P 25 C·P 25 C·P 25 C·P 25 C·P 25 C·P 25 C·P 25 C·P 25 09 47 040 0001 09 47 040 0002 09 47 040 0003 09 47 040 0004 09 47 040 0005 09 47 040 0007 09 47 040 0023 09 47 040 0024 09 47 040 0025 09 47 040 0026 09 47 040 0027 09 47 040 0029 09 47 040 0045 09 47 040 0046 09 47 040 0047 09 47 040 0048 09 47 040 0049 09 47 040 0051 09 47 040 0067 09 47 040 0068 09 47 040 0069 09 47 040 0070 09 47 040 0071 09 47 040 0073 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 09 47 050 0001 09 47 050 0002 09 47 050 0003 09 47 050 0004 09 47 050 0005 09 47 050 0007 09 47 050 0023 09 47 050 0024 09 47 050 0025 09 47 050 0026 09 47 050 0027 09 47 050 0029 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 Z  List of part numbers Part number 09 47 050 0045 09 47 050 0046 09 47 050 0047 09 47 050 0048 09 47 050 0049 09 47 050 0051 09 47 050 0067 09 47 050 0068 09 47 050 0069 09 47 050 0070 09 47 050 0071 09 47 050 0073 09 47 050 6001 09 47 050 6002 09 47 050 6003 09 47 050 6004 09 47 050 6005 09 47 050 6007 09 47 050 6023 09 47 050 6024 09 47 050 6025 09 47 050 6026 09 47 050 6027 09 47 050 6029 09 47 050 6045 09 47 050 6046 09 47 050 6047 09 47 050 6048 09 47 050 6049 09 47 050 6051 09 47 050 6067 09 47 050 6068 09 47 050 6069 09 47 050 6070 09 47 050 6071 09 47 050 6073 09 47 050 60xx Z  09 47 060 0001 09 47 060 0002 09 47 060 0003 09 47 060 0004 09 47 060 0005 09 47 060 0007 09 47 060 0023 09 47 060 0024 09 47 060 0025 09 47 060 0026 09 47 060 0027 09 47 060 0029 09 47 060 0045 09 47 060 0046 Page C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 23 C·P 23 C·P 23 C·P 23 C·P 23 C·P 23 C·P 23 C·P 23 C·P 23 C·P 23 C·P 23 C·P 23 C·P 23 C·P 23 C·P 23 C·P 23 C·P 23 C·P 23 C·P 23 C·P 23 C·P 23 C·P 23 C·P 23 C·P 23 Z 5 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 Part number Page 09 47 060 0047 09 47 060 0048 09 47 060 0049 09 47 060 0051 09 47 060 0067 09 47 060 0068 09 47 060 0069 09 47 060 0070 09 47 060 0071 09 47 060 0073 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 C·P 27 09 47 343 4006 09 47 343 4009 09 47 343 4012 09 47 343 4018 09 47 343 4020 09 47 343 4034 09 47 343 4037 09 47 343 4040 09 47 343 4046 09 47 343 4048 09 47 343 4090 09 47 343 4093 09 47 343 4096 09 47 343 4102 09 47 343 4104 C·P 21 C·P 21 C·P 21 C·P 21 C·P 21 C·P 21 C·P 21 C·P 21 C·P 21 C·P 21 C·P 21 C·P 21 C·P 21 C·P 21 C·P 21 09 47 363 6003 09 47 363 6005 09 47 363 6007 09 47 363 6012 09 47 363 6014 09 47 363 6025 09 47 363 6027 09 47 363 6029 09 47 363 6034 09 47 363 6036 09 47 363 6047 09 47 363 6049 09 47 363 6051 09 47 363 6056 09 47 363 6058 09 47 363 6069 09 47 363 6071 09 47 363 6073 09 47 363 6078 09 47 363 6080 C·P 37 C·P 37 C·P 37 C·P 37 C·P 37 C·P 37 C·P 37 C·P 37 C·P 37 C·P 37 C·P 37 C·P 37 C·P 37 C·P 37 C·P 37 C·P 37 C·P 37 C·P 37 C·P 37 C·P 37 09 47 370 0003 09 47 370 0005 09 47 370 0007 09 47 370 0012 09 47 370 0014 09 47 370 0025 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 Part number Page 09 47 370 0027 09 47 370 0029 09 47 370 0034 09 47 370 0036 09 47 370 0047 09 47 370 0049 09 47 370 0051 09 47 370 0056 09 47 370 0058 09 47 370 0069 09 47 370 0071 09 47 370 0073 09 47 370 0078 09 47 370 0080 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 09 47 380 0003 09 47 380 0005 09 47 380 0007 09 47 380 0012 09 47 380 0014 09 47 380 0025 09 47 380 0027 09 47 380 0029 09 47 380 0034 09 47 380 0036 09 47 380 0047 09 47 380 0049 09 47 380 0051 09 47 380 0056 09 47 380 0058 09 47 380 0069 09 47 380 0071 09 47 380 0073 09 47 380 0078 09 47 380 0080 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 09 47 390 0003 09 47 390 0005 09 47 390 0007 09 47 390 0012 09 47 390 0014 09 47 390 0025 09 47 390 0027 09 47 390 0029 09 47 390 0034 09 47 390 0036 09 47 390 0047 09 47 390 0049 09 47 390 0051 09 47 390 0056 09 47 390 0058 09 47 390 0069 09 47 390 0071 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 Part number Page 09 47 390 0073 09 47 390 0078 09 47 390 0080 C·P 39 C·P 39 C·P 39 09 47 400 0003 09 47 400 0005 09 47 400 0007 09 47 400 0012 09 47 400 0014 09 47 400 0025 09 47 400 0027 09 47 400 0029 09 47 400 0034 09 47 400 0036 09 47 400 0047 09 47 400 0049 09 47 400 0051 09 47 400 0056 09 47 400 0058 09 47 400 0069 09 47 400 0071 09 47 400 0073 09 47 400 0078 09 47 400 0080 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 C·P 39 10 12 005 1002 10 12 005 1003 10 12 005 1003 10 12 005 2001 C·P 13 C·P 15 Z 5 C·P 55 19 00 000 5080 19 00 000 5080 A·E 41 A·M 24 19 20 003 1440 19 20 003 1440 19 20 003 1440 19 20 003 1440 A·E 41 A·E 41 A·M 24 A·M 24 20 70 305 3921 20 70 305 3921 20 70 305 3941 20 70 305 3941 20 70 305 4921 20 70 305 4921 20 70 305 4941 20 70 305 4941 A·E 42 Z 2 A·E 43 Z 2 A·M 25 Z 3 A·M 26 Z 3 List of part numbers Part number 20 70 310 3921 20 70 310 3921 20 70 310 3941 20 70 310 3941 20 70 310 4921 20 70 310 4921 20 70 310 4941 20 70 310 4941 Page A·E 44 Z 2 A·E 45 Z 2 A·M 27 Z 3 A·M 28 Z 3 20 73 302 4941 20 73 305 3921 20 73 305 3921 20 73 305 3941 20 73 305 3941 20 73 305 4921 20 73 305 4921 20 73 305 4941 20 73 305 4941 Z 5 A·E 36 Z 2 A·E 37 Z 2 A·M 20 Z 3 A·M 21 Z 3 20 73 308 3972 20 73 308 3972 A·E 38 Z 2 20 76 102 8000 20 76 102 8000 20 76 102 8000 C·G   3 C·P   4 C·E   3 20 76 103 3000 A·E   5 20 76 104 3000 A·E   6 20 76 105 3000 20 76 106 7000 20 76 106 7000 A·E   7 A·S 17 Z 3 20 76 107 1100 20 76 107 1100 20 76 107 1200 20 76 107 1200 20 76 107 3100 20 76 107 3100 20 76 107 3200 20 76 107 3200 20 76 107 4100 20 76 107 4100 20 76 107 4200 20 76 107 4200 A·S   9 Z 3 A·S 12 Z 3 A·E 17 Z 2 A·E 24 Z 2 A·M   8 Z 3 A·M 11 Z 3 20 76 108 3000 20 76 108 3000 20 76 108 3001 20 76 108 3001 20 76 108 3002 20 76 108 3002 A·E 11 Z 2 A·E 12 Z 2 A·E 13 Z 2 Part number Page 20 76 108 3003 20 76 108 3003 20 76 108 3004 20 76 108 3004 20 76 108 3005 20 76 108 3005 20 76 108 3100 20 76 108 3100 20 76 108 3101 20 76 108 3101 20 76 108 3102 20 76 108 3103 20 76 108 3103 20 76 108 3200 20 76 108 3200 20 76 108 3201 20 76 108 3201 A·E 14 Z 2 A·E 15 Z 2 A·E 16 Z 2 A·E 18 Z 2 A·E 19 Z 2 A·E 20 A·E 21 Z 2 A·E 25 Z 2 A·E 26 Z 2 20 76 109 1100 20 76 109 1100 20 76 109 1200 20 76 109 1200 20 76 109 4100 20 76 109 4100 20 76 109 4200 20 76 109 4200 A·S 10 Z 3 A·S 13 Z 3 A·M   9 Z 3 A·M 12 Z 3 20 76 110 1000 20 76 110 1000 20 76 110 1001 20 76 110 1001 20 76 110 1100 20 76 110 1100 20 76 110 1200 20 76 110 1200 20 76 110 3100 20 76 110 3100 20 76 110 3101 20 76 110 3101 20 76 110 3200 20 76 110 3200 20 76 110 3201 20 76 110 3201 20 76 110 4000 20 76 110 4000 20 76 110 4001 20 76 110 4100 20 76 110 4100 20 76 110 4200 20 76 110 4200 A·S   7 Z 3 A·S   8 Z 3 A·S 11 Z 3 A·S 14 Z 3 A·E 22 Z 2 A·E 23 Z 2 A·E 27 Z 2 A·E 28 Z 2 A·M   6 Z 3 A·M   7 A·M 10 Z 3 A·M 13 Z 3 20 76 208 7000 20 76 208 7000 A·E 31 Z 2 Part number Page 20 76 208 7001 20 76 208 7001 A·M 16 Z 3 20 79 302 0922 20 79 302 0922 C·P   5 Z 5 20 80 000 0003 20 80 000 0003 20 80 000 0003 20 80 000 0004 20 80 000 0004 A·E 41 A·M 24 A·P   5 A·E 35 A·M 19 20 80 000 3121 A·P 9 20 80 010 0001 20 80 010 0001 20 80 010 0001 20 80 010 0002 20 80 010 0002 A·E 41 A·M 24 A·P   5 A·E 41 A·M 24 20 80 024 0002 20 80 024 0002 20 80 024 0002 A·E 41 A·M 24 A·P   5 20 80 300 3011 20 80 300 3011 20 80 300 3012 20 80 300 3012 A·P   6 Z 3 A·P   7 Z 3 21 03 212 2305 21 03 212 2305 A·E 41 A·M 24 21 03 281 1405 21 03 281 1405 21 03 281 1405 C·P 57 C·E 17 Z 5 21 03 381 2400 21 03 381 2400 21 03 381 4400 21 03 381 4400 21 03 381 x400 C·P 17 C·E   7 C·P 17 C·E   7 Z 5 21 03 485 1401 21 03 485 1401 21 03 485 1403 21 03 485 1403 21 03 485 1405 21 03 485 1405 21 03 485 140x 21 03 485 14xx C·P 42 C·E 10 C·P 42 C·E 10 C·P 42 C·E 10 Z 5 Z 5 Part number Page Z  Catalogue order information Please send me further information: 35 1  HARTING CD-Rom HARKIS® HARTING DVD HARKIS® TCA Connectors  TCA connectors Interface Connectors HARTING Interface Connectors People | Power | Partnership People | Power | Partnership 4#!INDD  HARTING Technologies meet Markets Industrial Connectors Han® )NTERFACEINDD Industrial Connectors Han®   HARTING People | Power | Partnership Application brochure 19 1 03 6 (ANINDD  HARTING HARTING Coaxial and Metric Connectors !PPLIKATIONINDD  Coaxial and Metric Connectors Automation IT Connectors DIN 41 612 Ethernet Network Solutions for the Industry People | Power | Partnership Ethernet Network Solutions for the Industry Connectors DIN 41 612 (ARBUS(-INDD  People | Power | Partnership Sender: Company: Titel+U2.indd 1 03.10.2006 12:25:47 $).INDD Street:  Department: Postcode/Town: Name: Country: Prename: Phone: Function: Fax: E-mail: Please send it by post or fax to your local HARTING Representatives (see page addresses) or visit us under www.HARTING.com. Production plants   – worldwide Espelkamp / Germany – Plant 1 Espelkamp / Germany – Plant 2 Representatives – worldwide Argentina  Condel Electronica  Julian Agüero 3355  (1605) Munro, Pcia. de Buenos Aires  Phone + Fax +54 11 4762.0118  E-Mail: mediavicondel@arnet.com.ar Estland  SKS-tehnika Ou   Mustamäe tee 55, EE-10621 Tallinn  Phone +372 6819 234  Fax +372 6819 235   E-Mail: peeter.kuus@sks.fi Australia  ADILAM Electronics Pty. Ltd.  14 Nicole Close  North Bayswater, 3153 Victoria  Phone +61 3 9737 4900  Fax +61 3 9737 4999  E-Mail: mark.c@adilam.com.au  Internet: www.adilam.com.au Finland  SKS-automaatio OY  Martinkyläntie 50, FIN-01721 Vantaa  Phone +358 9 852 661  Fax +358 9 852 68 20  E-Mail: automaatio@sks.fi Bulgaria  COMET ELECTRONICS  16, Tsar Samuil Str., BG-1000 Sofia  Phone +359-2-9155800  Fax +359-2-9540384  E-Mail: office@comet.bg  Internet: www.comet.bg Denmark  Knud Wexøe A/S  Skaettekaeret 11, P.O. Box 152  DK-2840 Holte  Phone +45 45 46 58 00  Fax +45 45 46 58 01  E-Mail: wexoe@wexoe.dk  Internet: www.wexoe.dk Hungary  Mile Kft.  Mádi u. 52, H-1104 Budapest  Phone +36-1-431-9800  Fax +36-1-431-9817  E-Mail: milekft@mile-kft.hu  Internet: www.mile-kft.hu Island  Smith & Norland  Nóatún 4, IS - 105 Reykjavík  Phone +354 520 3000  Fax +354 520 3011  E-Mail: olaf@sminor.is  Internet: www.sminor.is Espelkamp / Germany – Plant 3 Espelkamp / Germany – Plant 4 Zhuhai / China Northampton / Great Britain Espelkamp / Germany – Plant 5 Sibiu / Romania Biel / Switzerland Representatives   – worldwide Israel  MIGVAN   Technologies & Engineering Ltd.  13 Hashiloh St., P.O.Box 7022  IL - Petach Tikva 49170  Phone +972 3 9240784  Fax +972 3 9240787  E-Mail: info@mte.co.il  Internet: www.mte.co.il Subsidiary companies – worldwide Austria  HARTING Ges. m. b. H.  Deutschstraße 3, A-1230 Wien  Phone +43 1 / 6 16 21 21  Fax +43 1 / 6 16 21 21-21  E-Mail: at@HARTING.com Belgium  HARTING N.V. / S.A.  Z.3 Doornveld 23, B-1731 Zellik  Phone +32 2 / 4 66 01 90  Fax +32 2 / 4 66 78 55  E-Mail: be@HARTING.com Germany  HARTING Deutschland   GmbH & Co. KG  Postfach 2451 · D-32381 Minden  Simeonscarré 1 · D-32427 Minden  Phone (05 71) 88 96 - 0  Fax (05 71) 88 96 - 2 82  E-Mail: de@HARTING.com  Internet: www.HARTING.com Office Germany  HARTING Deutschland   GmbH & Co. KG  Blankenauer Straße 99  Poland  D-09113 Chemnitz   Brazil  Soyter Sp. z o. o.  Phone +49 0371 429211  HARTING Ltda.  ul. Warszawska 3,   Av. Dr. Lino de Moraes, Pq. Jabaquara, 255  Fax +49 0371 429222   05-082 Warszawa - Stare Babice  CEP 04360-001 - São Paulo - SP - Brazil  E-Mail: de@HARTING.com Phone +48 22 722 0 685  Phone +55 11 / 50 35- 00 73  Fax +48 22 722 0 550  Great Britain  Fax +55 11 / 50 34 - 47 43  E-Mail: handlowy@soyter.com.pl  E-Mail: br@HARTING.com  HARTING Ltd.  Internet: www.soyter.com Internet: www.HARTING.com.br Caswell Road  Brackmills Industrial Estate  GB-Northampton, NN4 7PW  China  Phone +44 16 04 / 76 66 86, 82 75 00  Zhuhai HARTING   South-Africa  Fax +44 16 04 / 70 67 77,   Limited Shanghai branch  HellermannTyton Pty Ltd.,   Room 5403, 300 Huaihai Zhong Road  E-Mail: gb@HARTING.com  Private Bag X158 Rivonia 2128  Internet: www.HARTING.co.uk Hong Kong New World Tower  34 Milky Way Avenue  Luwan District, P.R.C   Linbro Business Park 2065  Hong Kong  Shanghai 200021, China  Johannesburg, South Africa  Phone +86 21 - 63 86 22 00  HARTING (HK) Limited,   Phone +27 (0)11 879-66 00  Fax +86 21 - 63 86 86 36  Regional Office Asia Pacific  Fax +27 (0)11 879-66 06  E-Mail: cn@HARTING.com 4208 Metroplaza Tower 1  E-Mail: sales.jhb@hellermann.co.za 223 Hing Fong Road  Kwai Fong, N. T., Hong Kong  Czech Republic  Phone +8 52 / 24 23 - 73 38  HARTING spol. s.r.o.,   Fax +8 52 / 24 80 - 43 78  Mlýnská 2, 160 00 Praha 6  Turkey  E-Mail: ap@HARTING.com  Phone +420 220 380 460  Gökhan Elektrik San. Tic. Ltd. Sti.  Internet: www.HARTING.com.hk Fax +420 220 380 461  Perpa Elektrikçiler Is Merkezi A Blok   E-Mail: cz@HARTING.com  Kat:7-8-9 No.694  Hungary  Internet: www.HARTING.cz TR - 80270 Okmeydani/Istanbul   HARTING Eastern Europe GmbH  Phone +9 0 (212) 2 21 32 36 (pbx)  Magyarországi Kereskedelmi Finland  Fax +9 0 (212) 2 21 32 40  ­Képviselete  HARTING Oy  E-Mail: gokhan@gokhanelektrik.com.tr  Teknobulevardi 3-5, PL 35  1119 Budapest  Internet: www.gokhanelektrik.com Fehérvári út 89-95, II. emelet 217/A.  FI-01530 Vantaa  Phone +36-1-205 3464  Phone +358 9 350 873 00  Fax +36-1-205 3465  Fax +358 9 350 873 20  E-Mail: hu@HARTING.com  E-Mail: fi@HARTING.com Ukraine  Internet: www.HARTING.hu Incomtech Ltd.  France  4 Lermontovskaya St.  India  HARTING France  UA-04050 Kiev  181 avenue des Nations, Paris Nord 2  HARTING India Private Limited  Phone +380-44-213-3641  No. D, 4th Floor, 'Doshi Towers'  BP 66058 Tremblay en France  Fax +380-44-213-3814  No. 156 Poonamallee High Road,   F-95972 Roissy Charles de Gaulle E-Mail: eletech@incomtech.com.ua  Cédex  Kilpauk, Chennai 600 010,   Internet: www.incomtech.com.ua Tamil Nadu, Chennai  Phone +33 1 49 38 34 00  Phone +91-44-4356 0415/6  Fax +33 1 48 63 23 06  Fax +91-44-4356 0417  E-Mail: fr@HARTING.com E-Mail: in@HARTING.com  Internet: www.HARTING.com Subsidiary companies – worldwide Italy  HARTING SpA  Via Dell' Industria 7  I-20090 Vimodrone (Milano),   Phone +39 02 / 25 08 01  Fax +39 02 / 2 65 05 97,   E-Mail: it@HARTING.com Japan  HARTING K. K.  Yusen Shin-Yokohama 1 Chome Bldg., 2F  1-7-9, Shin-Yokohama  Kohoku-ku, Yokohama  222-0033 Japan  Phone +81 45 476 3456  Fax: +81 45 476 3466  E-Mail: jp@HARTING.com  Internet: www.HARTING.co.jp Korea  HARTING Korea Limited  #308 Leaders Bldg., 342-1,   Yatap-dong, Bundang-gu,   Sungnam-City, Kyunggi-do,   463-828, Korea  Phone +82-31-781-4615  Fax +82-31-781-4616  E-Mail: kr@HARTING.com Netherlands  HARTING B.V.  Larenweg 44  NL-5234 KA 's-Hertogenbosch  Postbus 3526  NL-5203 DM 's-Hertogenbosch  Phone +31 73 / 6 41 04 04  Fax +31 73 / 6 44 06 99  E-Mail: nl@HARTING.com Norway  HARTING A/S,   Østensjøveien 36, N-0667 Oslo,   Phone +47 22 / 70 05 55  Fax +47 22 / 70 05 70  E-Mail: no@HARTING.com Poland HARTING Eastern Europe GmbH Przedstawicielstwo w Polsce ul. Kamieńskiego 201-219 51-126 Wrocław Phone +48 71-352 81 71 Phone +48 71-352 81 74 Fax +48 71-320 74 44 E-Mail: pl@HARTING.com Internet : www.HARTING.pl Russia  HARTING ZAO  ul. Tobolskaja 12, Saint Petersburg  194044 Russia   Phone +7 / 8 12 / 3 27 64 77  Fax +7 / 8 12 / 3 27 64 78  E-Mail: ru@HARTING.com  Internet: www.HARTING.ru Eastern-Europe  HARTING Eastern Europe GmbH  Bamberger Straße 7  D-01187 Dresden  Phone +49 351 / 4361760  Fax +49 351 / 4361770  E-Mail: Eastern.Europe@HARTING. com Singapore  HARTING Singapore Pte Ltd.  No. 1 Coleman Street  #B1-21 The Adelphi  Singapore 179803  Phone +656 2 25 52 85  Fax +656 2 25 99 47  E-Mail: sg@HARTING.com Other countries  HARTING Electric GmbH & Co. KG  P.O. Box 14 73, D-32328 Espelkamp  Phone +49 57 72 / 47 - 97 100  Fax + 49 57 72 / 47 - 4 95  E-Mail: electric@HARTING.com Spain  HARTING Iberia S.A.  Josep Tarradellas 20-30 4º 6ª  E-08029 Barcelona  Phone +34 933 638 475  Fax +34 934 199 585  E-Mail: es@HARTING.com Sweden  HARTING AB  Gustavslundsvägen 141 B 4tr  167 51 Bromma  Phone +46 8 / 4 45 71 71  Fax +46 8 / 4 45 71 70  E-Mail: se@HARTING.com Switzerland  HARTING AG  Industriestrasse 26  CH-8604 Volketswil  Phone +41 44 908 20 60  Fax +41 44 908 20 69  E-Mail: ch@HARTING.com Taiwan  HARTING R.O.C. Limited  Room 6, 10 Floor, No. 171  Sung-Te-Road, Taipei, 110 Taiwan  Phone +8 86 - 2 - 23 46 - 31 77,   Fax +8 86 - 2 - 23 46 - 26 90  E-Mail: tw@HARTING.com Distributor –   Canada Chartwell Electronics Inc.  140 Duffield Drive  Markham, Ontario L6G 1B5  Tel. 905-513-7100  Toll Free 877-513-7769  Fax 905-513-7101  Internet: www.chartwell.ca Distributors –   worldwide Farnell InOne  www.farnellinone.com;   in US: Newark InOne:   www.newarkinone.com RS Components  www.rs-components.com;   in US: Allied Electronics:   www.alliedelec.com USA  HARTING Inc. of North America  1370 Bowes Road  Elgin, Illinois 60123  Phone +1 (877) 741-1500 (toll free)  Global Business Unit   Fax +1 (866) 278-0307 (Inside Sales)  Fax +1 (847) 717-9430 (Sales and Marketing)  Electric E-Mail: us@HARTING.com  Portugal  Internet: www.HARTING-USA.com HARTING Electric GmbH & Co. KG HARTING Iberia, S. A.  P.O. Box 14 73  Avda. Josep Tarradellas, 20-30, 4º 6ª   D-32328 Espelkamp E-08029 Barcelona  Phone +49 57 72 / 47- 97 100  Phone +351.219.673.177  Fax +49 57 72 / 47- 4 95 Fax +351.219.678.457  E-Mail: electric@HARTING.com  E-Mail: es@HARTING.com Internet: www.HARTING.com MO/23.11.06/5.0 98 41 103 0201 People | Power | Partnership Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: HARTING: 0945 700 5025 09473434034 09473434037 09473434040 09473434046 09473434048 09470600002 09470600023 09470600024 09470600025 09470600026 09470600027 09470600029 09470600045 09470600046 09470600048 09470600049 09470600051 09457000023 09457000025 09457000026 09457000027 09457000028 09457000051 09457001125 09457001151 09457001164 09457001166 09457001168 09457001173 09457001175 09457001176 09457001184 09457001185 09457152503 09457152505 09457152507 09457152512 09457251322 09457251332 09457251534 09457451532 09457451567 09457451574 09457451575 09457711184 09457714023 09457714025 09457714027 09457714123 09457714125 09457714151 09457714153 09457714164 09470600031 09470600047 09473030005 09473030010 09473030015 09473030020 09473030025 09473030030 09473434025 09473434033 09473434151 09473434152 09473434153 09473434157 09473434202 09473434204 09473434208 09473434213 09473434215 09473434228 09473434229 09473434230 09473434231 09473434232 09473454031 09473636012 09473636023 09473636027 09473636034 09473636036 09473636051 09473800027 09473800034 09473800036
09473434204 价格&库存
很抱歉,暂时无法提供与“09473434204”相匹配的价格&库存,您可以联系我们找货
