09474747208
09474747208
    HARTING(浩亭)
    HA-VISSMARTPATCHCABLECAT6Y
09474747208 数据手册
HARTING Smart patch cable IP 20 Cat. 6 Han® 24Ha-VIS HPR enlarged Ha-VIS Smart patch cable IP 20 Cat. 6 Advantages General • Easy and fast illuminated detection of patch cables • Easy to use • Suitable for Gigabit Ethernet 1000 Mbit/s • Transmission performance in acc. with Cat. 6 ISO/IEC 11 801 • Compact and space saving plug by dual boot design • Capable for multiport applications • Very robust locking lever protection and unlocking latch • Good shielding against EMC influence • Flame retardant and halogen-free • Colour coding option • RFID option • GHMT certified This RJ45 patch cable comes with illuminated RJ45 Ethernet plugs. The plugs are very easy and comfortable to identify each other over distances up to 100 meters, e.g. in clusters of racks in data centres facilitate enormously the allocation of ports. Description Order number Each RJ45 connector has an integrated LED which is illuminated by a detector. It works in anyway if the connectors are plugged in or not. That function has no influence on the Ethernet data transmission. The new Smart patch cables expand HARTING’s Automation IT generic cabling system. The family is marked by an unique design of the two part boot, called dual-boot design. This offers a very easy robust handling and bending protection. Drawing RJ45 acc. to IEC 60 603-7 Boot grey Locking lever protection and unlocking latch Cable S/FTP AWG 27 LSZH chemical resistant cable jacket, yellow Wiring: 1:1 TIA/EIA-568-B, 8-wire 100 % electrical tested Ha-VIS Smart Patch cable Cat. 6 (further lengths on request) 1.0 m 2.0 m 5.0 m 7.0 m 10.0 m 09 47 474 7201 09 47 474 7203 09 47 474 7206 09 47 474 7208 09 47 474 7211 All data given are in line with the actual state of the art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING Ha-VIS Smart patch cable IP 20 Cat. 6 Technical characteristics Cat. 6 / Class E acc. to ISO/IEC 24 702 resp. ISO/IEC 11 801, IEC 61 935-2 Performance Mechanical Characteristics Bending protection Locking lever protection Electrical Characteristics Characteristic Impedance Wiring EMC 100 Ω 1:1 TIA/EIA-568-B Fully shielded (aluminised foil and tinned copper braid) Environmental Characteristics Protection class Halogen-free Flame retardant Low smoke density Lead free IP 20 IEC 60 754-2 IEC 60 332-3 IEC 61 034 LSZH and RoHS compliant Thermal Characteristics Operating temperature Mobile: Stationary: 0 °C ... +50 °C -20 °C ... +60 °C Printing HARTING Ha-VIS Smart Patch Cat. 6 FRNC Packaging One piece in poly-bag labelled All data given are in line with the actual state of the art and therefore not binding. HARTING reserves the right to modify designs without giving the relevant reasons. HARTING Ha-VIS Smart patch cable Detector Ha-VIS Smart patch cable Detector Description • Metal housing • Protection cover for the contacts • 4 batteries type LR4 included and available as spare parts at specialized trade • Operating modes: 1. light on 2. fast flash light 3. slow flash light 4. light off Order number General Make sure that the detector is switched off when not in use. otherwise the batteries will be discharged. It is obligatory to use only this detector with HARTING Ha-VIS Smart patch cables. Otherwise the cables could be damaged. 09 47 900 0001 HARTING RJ Industrial® 10G colour clips HARTING RJ Industrial® 10G colour clips Description Order number HARTING RJ Industrial® 10G Colour clips white grey yellow magenta red blue green brown 09 45 850 0001 09 45 850 0002 09 45 850 0003 09 45 850 0005 09 45 850 0007 09 45 850 0008 09 45 850 0009 09 45 850 0010 General These clips are suitable for colour coding of the HARTING Ha-VIS Smart patch cable as well as RJ Industrial® 10G. The colour clips provide an RFID option for automatic detection and storage of the patch cable ID. Every order number contains a package of 50 pieces. HARTING Electric GmbH & Co. KG Wilhelm-Harting-Straße 1 | D-32339 Espelkamp | Postfach 14 73 | D-32328 Espelkamp Tel.: +49 5772 47-97100 | Fax: +49 5772 47-688 | electric@HARTING.com | www.HARTING.com 2010-09-09
09474747208 价格&库存
很抱歉,暂时无法提供与“09474747208”相匹配的价格&库存,您可以联系我们找货
