N201-100-GY-P
N201-100-GY-P
    TRIPPLITE
    N201-100-GY-P
N201-100-GY-P 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6 Gigabit Snagless Molded Plenum-Rated (UTP) Ethernet Cable, (RJ45 M/M), PoE, Gray, 100 ft. (30.5 m) Highlights ● CMP plenum-rated gray Cat6 patch cable ● For use in walls or ceilings where fire codes dictate plenumrated cabling ● Pliable snagless boot protects RJ45 tab when pulling through ceilings, etc. MODEL NUMBER: N201-100-GY-P Package Includes ● Features ● CMP plenum-rated, pre-terminated Cat6 patch cable ● Protective, flexible boot ● Cat6 rated "staggered" RJ45 plugs for greatly reduced NEXT Specifications OVERVIEW UPC Code 037332141118 Technology Cat6 PHYSICAL Cable Jacket Color Gray Cable Jacket Material PVC Cable Jacket Rating CMP Cable Shielding UTP Cable Outer Diameter (OD) 5.7 mm Number of Conductors 4 Pair Conductor Material Solid Copper Conductor Gauge 24 AWG 1/3 100-ft. (30.5 m) Cat6 Gray Gigabit Plenum Snagless Patch Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Length (ft.) 100 Cable Length (m) 30.49 Cable Length (in.) 1200 Cable Length (cm) 3048 Shipping Dimensions (hwd / in.) 17.00 x 14.00 x 0.50 Shipping Dimensions (hwd / cm) 43.18 x 35.56 x 1.27 Shipping Weight (lbs.) 2.65 Shipping Weight (kg) 1.20 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 250 MHz Maximum Bandwidth as Tested 500 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3an; 802.3at CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) Crossover Wiring No Contact Plating Gold PoE Type Type 2 PoE+ (30W, IEEE 802.3at) Connector Type Snagless; Molded Wiring Configuration EIA/TIA 568B Angled Connector No FEATURES & SPECIFICATIONS IP68 Rated No Snagless Connector Yes Antibacterial No STANDARDS & COMPLIANCE 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N201-100-GY-P 价格&库存
很抱歉,暂时无法提供与“N201-100-GY-P”相匹配的价格&库存,您可以联系我们找货
