N261-006-6FF-BL
N261-006-6FF-BL
    TRIPPLITE
    N261-006-6FF-BL
N261-006-6FF-BL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6a 10G Pre-Terminated Copper Trunk Assembly (6x RJ45 F/F), Blue, 6 ft. (1.83 m) MODEL NUMBER: N261-006-6FF-BL Highlights ● 100% factory-terminated, bundled and -tested ● 6 certified Cat6a cables per bundle ● Unshielded female RJ45 connectors on each end ● 23 AWG solid conductor wire with CMR-rated PVC jacket ● Meets or exceeds ANSI/TIA568-C.2 standards Package Includes ● Factory-terminated copper trunk assembly combines 6 certified Cat6a cables to save time, space and money. Ideal for data centers and other areas where quick installation and consistent network connection are important. Features Combines 6 Certified Cat6a Cables in One Bundle ● 100% terminated, bundled and tested at the factory ● Ideal for data centers and other areas where quick installation and consistent network connection are important ● Designed for easy connection in switches and patch panels ● Saves time, space and labor costs Top-of-the-Line Construction ● Unshielded female RJ45 connectors on each end ● 23 AWG solid conductor wire ● Blue CMR-rated PVC jacket ● Black mesh tubing keeps cables neat and protects against fraying and damage ● 18 in. breakout legs labeled on ends for quick ID Fully Compliant and Compatible ● Meets or exceeds ANSI/TIA-568-C.2 category requirements for performance ● Backward compatible with Cat6 and Cat5e installations Specifications OVERVIEW UPC Code 037332196477 1/3 N261-006-6FF-BL Augmented Cat6/Cat6a Pre-Terminated Copper Trunk Bundle (F/F), 6 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States Technology Cat6a PHYSICAL Cable Jacket Color Blue Cable Jacket Material PVC Cable Jacket Rating CMR Cable Shielding UTP Cable Outer Diameter (OD) 7.8 mm Number of Conductors 4 Pair Conductor Material Solid Copper Conductor Gauge 23 AWG Cable Length (ft.) 6 Cable Length (m) 1.83 Cable Length (in.) 72 Cable Length (cm) 182.9 Shipping Dimensions (hwd / in.) 17.00 x 0.50 x 14.00 Shipping Dimensions (hwd / cm) 43.18 x 1.27 x 35.56 Shipping Weight (lbs.) 2.10 Shipping Weight (kg) 0.95 ENVIRONMENTAL Operating Temperature Range -4 to 140 F (-20 to 60 C) Storage Temperature Range 5 to 122 F (-15 to 50 C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 5% to 85% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 500 MHz Maximum Bandwidth as Tested 600 MHz Network Compatibility 10 Gbps IEEE Standards Supported 802.3ab; 802.3an; 802.3af; 802.3at CONNECTIONS Side A - Connector 1 (6) RJ45 (FEMALE) Side B - Connector 1 (6) RJ45 (FEMALE) Crossover Wiring No Contact Plating Gold 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States PoE Type Type 1 PoE (15.4W, IEEE 802.3af); Type 2 PoE+ (30W, IEEE 802.3at) Wiring Configuration EIA/TIA 568B Angled Connector No FEATURES & SPECIFICATIONS IP68 Rated No Snagless Connector No Antibacterial No STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3ab 1000Base-T; IEEE 802.3af PoE; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N261-006-6FF-BL 价格&库存
很抱歉,暂时无法提供与“N261-006-6FF-BL”相匹配的价格&库存,您可以联系我们找货
