1000 Eaton Boulevard
Cleveland, OH 44122
United States
Cat6a 10G Pre-Terminated Copper Trunk
Assembly (6x RJ45 F/F), Blue, 10 ft. (3.05 m)
MODEL NUMBER: N261-010-6FF-BL
Highlights
100% factory-terminated, bundled and -tested
6 certified Cat6a cables per
bundle
Unshielded female RJ45
connectors on each end
23 AWG solid conductor wire
with CMR-rated PVC jacket
Meets or exceeds ANSI/TIA568-C.2 standards
Package Includes
Factory-terminated copper trunk assembly combines 6 certified Cat6a cables to save time, space and
money. Ideal for data centers and other areas where quick installation and consistent network connection
are important.
Description
The N261-010-6FF-BL Augmented Cat6/Cat6a Pre-Terminated Copper Trunk Bundle (F/F) makes
installation a breeze and saves you time, space and money. All termination, bundling and testing is done
at the factory, so almost anyone can do the installation in your data center in less time. Six certified and
channel-tested Cat6a cables are bundled together, which cuts down on cable clutter in your cabinet. Both
ends feature an unshielded female RJ45 keystone jack.
Designed for easy patching in switches and patch panels, this 10-ft. (3.05 m) assembly is constructed
using 23 AWG solid conductor wire with a blue CMR-rated PVC jacket. Black mesh tubing keeps the
cable neat and protects against fraying and damage. The 18-inch breakout legs are labeled on the ends
for quick identification. System components meet or exceed ANSI/TIA-568-C.2 category requirements for
performance. Backward compatible with Cat6 and Cat5e installations.
Features
Combines 6 Certified Cat6a Cables in One Bundle
● 100% terminated, bundled and tested at the factory
Ideal for data centers and other areas where quick installation and consistent network connection are
important
Designed for easy connection in switches and patch panels
Saves time, space and labor costs
Top-of-the-Line Construction
● Unshielded female RJ45 connectors on each end
Blue CMR-rated PVC jacket
Black mesh tubing keeps cables neat and protects against fraying and damage
18 in. breakout legs labeled on ends for quick ID
1/3
Copper Trunk Bundle (F/F), 10ft. (3.05 m)
Cleveland, OH 44122
United States
Fully Compliant and Compatible
● Meets or exceeds ANSI/TIA-568-C.2 category requirements for performance
Specifications
OVERVIEW
UPC Code
037332196484
Technology
Cat6a
PHYSICAL
Cable Jacket Color
Blue
Cable Jacket Material
PVC
Cable Jacket Rating
CMR
Cable Shielding
UTP
Cable Outer Diameter (OD)
7.8 mm
Number of Conductors
4 Pair
Conductor Material
Solid Copper
Conductor Gauge
23 AWG
Cable Length (ft.)
10
Cable Length (m)
3.05
Cable Length (in.)
120
Cable Length (cm)
304.8
Shipping Dimensions (hwd / in.)
0.50 x 12.10 x 15.00
Shipping Dimensions (hwd / cm)
1.27 x 30.73 x 38.10
Shipping Weight (lbs.)
3.20
Shipping Weight (kg)
1.45
ENVIRONMENTAL
Operating Temperature Range
-4 to 140 F (-20 to 60 C)
Storage Temperature Range
5 to 122 F (-15 to 50 C)
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
Bandwidth per TIA Standard
500 MHz
Maximum Bandwidth as Tested
600 MHz
2/3
Cleveland, OH 44122
United States
Network Compatibility
10 Gbps
IEEE Standards Supported
802.3ab; 802.3an; 802.3af; 802.3at
CONNECTIONS
Side A - Connector 1
(6) RJ45 (FEMALE)
Side B - Connector 1
(6) RJ45 (FEMALE)
Crossover Wiring
No
Contact Plating
Gold
PoE Type
Type 1 PoE (15.4W, IEEE 802.3af); Type 2 PoE+ (30W, IEEE 802.3at)
Wiring Configuration
EIA/TIA 568B
Angled Connector
No
FEATURES & SPECIFICATIONS
IP68 Rated
No
Snagless Connector
No
Antibacterial
No
STANDARDS & COMPLIANCE
Product Certifications
UL Listed; cUL Listed
Product Compliance
CE (Europe); RoHS; IEEE 802.3ab 1000Base-T; IEEE 802.3af PoE; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+;
REACH; UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N261-010-6FF-BL”相匹配的价格&库存,您可以联系我们找货
