N261-015-6FF-BL
N261-015-6FF-BL
    TRIPPLITE
    AUGMENTEDCAT6/CAT6APRE-TERMINA
N261-015-6FF-BL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat6a 10G Certified Pre-Terminated Copper Trunk Assembly (6x RJ45 F/F), Blue, 15 ft. (4.57 m) MODEL NUMBER: N261-015-6FF-BL Highlights ● 100% factory-terminated, bundled and -tested ● 6 certified Cat6a cables per bundle ● Unshielded female RJ45 connectors on each end ● 23 AWG solid conductor wire with CMR-rated PVC jacket ● Meets or exceeds ANSI/TIA568-C.2 standards Package Includes ● Factory-terminated copper trunk assembly combines 6 certified Cat6a cables to save time, space and money. Ideal for data centers and other areas where quick installation and consistent network connection are important. Description The N261-015-6FF-BL Augmented Cat6/Cat6a Pre-Terminated Copper Trunk Bundle (F/F) makes installation a breeze and saves you time, space and money. All termination, bundling and testing is done at the factory, so almost anyone can do the installation in your data center in less time. Six certified and channel-tested Cat6a cables are bundled together, which cuts down on cable clutter in your cabinet. Both ends feature an unshielded female RJ45 keystone jack. Designed for easy patching in switches and patch panels, this 15-ft. (4.57 m) assembly is constructed using 23 AWG solid conductor wire with a blue CMR-rated PVC jacket. Black mesh tubing keeps the cable neat and protects against fraying and damage. The 18-inch breakout legs are labeled on the ends for quick identification. System components meet or exceed ANSI/TIA-568-C.2 category requirements for performance. Backward compatible with Cat6 and Cat5e installations. Features Combines 6 Certified Cat6a Cables in One Bundle ● 100% terminated, bundled and tested at the factory ● Ideal for data centers and other areas where quick installation and consistent network connection are important ● Designed for easy connection in switches and patch panels ● Saves time, space and labor costs Top-of-the-Line Construction 1/3 N261-015-6FF-BL Augmented Cat6/Cat6a Pre-Terminated Copper Trunk Bundle (F/F), 15ft. (4.57 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Unshielded female RJ45 connectors on each end ● 23 AWG solid conductor wire ● Blue CMR-rated PVC jacket ● Black mesh tubing keeps cables neat and protects against fraying and damage ● 18 in. breakout legs labeled on ends for quick ID Fully Compliant and Compatible ● Meets or exceeds ANSI/TIA-568-C.2 category requirements for performance ● Backward compatible with Cat6 and Cat5e installations Specifications OVERVIEW UPC Code 037332196491 Technology Cat6a PHYSICAL Color Blue Cable Jacket Color Blue Cable Jacket Rating CMR Cable Shielding UTP Wire Type Solid Cable Length (ft.) 15 Cable Length (m) 4.57 Cable Length (in.) 180 Cable Length (cm) 457.2 Shipping Dimensions (hwd / in.) 17.00 x 0.50 x 14.25 Shipping Dimensions (hwd / cm) 43.18 x 1.27 x 36.20 Shipping Weight (lbs.) 4.80 Shipping Weight (kg) 2.18 COMMUNICATIONS Network Compatibility 10 Gbps CONNECTIONS Side A - Connector 1 (6) RJ45 (FEMALE) Side B - Connector 1 (6) RJ45 (FEMALE) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States FEATURES & SPECIFICATIONS Snagless Connector No WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N261-015-6FF-BL 价格&库存
很抱歉,暂时无法提供与“N261-015-6FF-BL”相匹配的价格&库存,您可以联系我们找货
