DC-500-CA012
DC-500-CA012
    CICOIL
    CAT 5E PATCH CORD 12 FT
DC-500-CA012 数据手册
REVISIONS ASSY PN: DC-500-CA LTR NC DESCRIPTION DATE INITIAL RELEASE APPROVAL JRP 10-04-10 CROSS SECTION VIEW LENGTH (FEET):CA003;CA006;CA012 0.13 1.3 A 0.45 519N101 PN: 519N101 HEAT SHRINK TUBING, BLACK (x2) A BILL OF MATERIALS QTY DESC NOTES: 1 INSTALL RJ-45 CONNECTORS AS REQUIRED. 2 PN MFG CONNECTOR, CAT5E 111-08080028L34* AR CABLE, BULK, CAT5E 519N101 A/R BLACK HEAT SHRINK MANUFACTURING DISCRETION (-55°C TO +135°C) 2 THE ID OF THIS ASSY IS PRODUCTION PREFERENCE. 3 STRIP AND TIN PER IEC-J-STD-001 SENTINEL CICOIL --- 4 CONDUCTORS: ULTRA FLEXIBLE, FINELY STRANDED, TINNED COPPER 5 SHIELDING: ULTRA FLEXIBLE, BRAIDED SHIELDS,WITH 90% NOMINAL COVERAGE 6 MINIMUM BEND RADIUS: 6X CABLE HEIGHT FOR INTERMEDIATE FLEX; 10X CABLE HEIGHT FOR CONTINUOUS FLEX 7 FLEX LIFE: 10,000,000 CYCLES NOMINAL 8 OUTER JACKET DUROMETER RATING: 65 (SHORE A) NO 9 CABLE TEMPERATURE RATING: -65°C TO +165°C ASSEMBLY TEMPERATURE RATING: -40°C TO +70°C INCH SCALE STANDARD TOLERANCES UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN INCHES .X± .XX± .XXX± .005 FRAC± ANGLES± MM( ) MATL: 10 OUTER JACKET DIELECTRIC STRENGTH: 450 VOLTS/MILS (17.7 kv/mm) X 11 * OR EQUIVALENT CICOIL PN, REV VIEW PROJECTION DASH NO QTY REQD NEXT ASSEMBLY APPLICATION SIGNATURE DO NOT SCALE DRAWING 1 JRP 10-04-10 CHECK JRP 10-04-10 ENG. JRP 10-04-10 Q.A. APPR. DESCRIPTION QTY 2 CICOIL DATE DRAWN APPR. FINAL ASSEMBLY SUPPLIER PN, REV 0 VALENCIA, CALIFORNIA TITLE STANDARD PRODUCT DEFINITION DRAWING, CAT5E CABLE, (RJ-45) CAGE CODE 19476 SCALE: NONE DRAWING NUMBER REV DC-500-XXX A SHEET FILE: DC-500-XXX NC SIZE OF
DC-500-CA012 价格&库存
很抱歉,暂时无法提供与“DC-500-CA012”相匹配的价格&库存,您可以联系我们找货
