N001-014-BK-R
N001-014-BK-R
    TRIPPLITE
    N001-014-BK-R
N001-014-BK-R 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 14-ft. Cat5e 350 MHz Snagless Molded Cable (RJ45 M/M) - Black Highlights ● Premium cabling for Category 5 and 5e applications—rated for 350 MHz/1 Gbps communications ● IEEE 802.3ab ● PVC 4-pair stranded UTP ● All cables feature boots with integral strain-relief and RJ45 (Male) connectors ● Retail packaging MODEL NUMBER: N001-014-BK-R Description Tripp Lite's 14-ft. black snagless category 5e (Cat5e) patch cable has 2 snagless RJ45 molded male connectors featuring integral strain relief. The cable is manufactured from PVC 4-pair stranded UTP and is rated for 350MHz/1Gbps communication. All cables are offered in a variety of lengths and colors for all category 5 (Cat5) and 5e cabling needs. Standard category 5e patch cables are also available. Tripp Lite warrants this product to be free from defects in materials and workmanship for life. Features System Requirements ● Cabling for category 5 (Cat5) and 5e (Cat5e) applications ● Length: 14-ft. color: black connectors: RJ45 male ● Feature molded connectors with integral strain relief ● Snagless design protects the locking tabs on the RJ45 connectors from being damaged or snapped off during installation ● PVC 4-pair stranded UTP ● Rated for 350MHz/ 1Gbps communication ● Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 5e draft 11) ● Available in other colors and lengths ● Also available without the snagless feature (N002 series) ● Also available - Cat6 cables (N201 series) ● Warranted to be free from defects in materials and workmanship for life ● Package Includes ● Specifications OVERVIEW UPC Code For 1000Base-T (1Gbps Ethernet), 10/100Base-T (Ethernet), 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice and Token Ring Type3 applications. 037332012555 PHYSICAL Color Black Cable Shielding UTP Cable Length (ft.) 14 Cable Length (m) 4.27 Shipping Dimensions (hwd / in.) 7.50 x 7.25 x 2.50 Shipping Dimensions (hwd / cm) 19.05 x 18.42 x 6.35 Shipping Weight (lbs.) 0.66 Shipping Weight (kg) 0.30 CONNECTIONS 1/2 14-ft. Black Snagless Cat5e Patch Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
N001-014-BK-R 价格&库存
很抱歉,暂时无法提供与“N001-014-BK-R”相匹配的价格&库存,您可以联系我们找货
