N001-005-BK-R
N001-005-BK-R
    TRIPPLITE
    N001-005-BK-R
N001-005-BK-R 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 5-ft. Cat5e 350 MHz Snagless Molded Cable (RJ45 M/M) - Blue Highlights ● Premium cabling for Category 5 and 5e applications—rated for 350 MHz/1 Gbps communications ● IEEE 802.3ab ● PVC 4-pair stranded UTP ● All cables feature boots with integral strain-relief and RJ45 (Male) connectors ● Retail packaging MODEL NUMBER: N001-005-BL-R System Requirements ● For 1000Base-T (1Gbps Ethernet), 10/100Base-T (Ethernet), 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice and Token Ring Type3 applications. Package Includes ● Description Tripp Lite's 5-ft. blue snagless category 5e (Cat5e) patch cable has 2 snagless RJ45 molded male connectors featuring integral strain relief. The cable is manufactured from PVC 4-pair stranded UTP and is rated for 350MHz/1Gbps communication. All cables are offered in a variety of lengths and colors for all category 5 (Cat5) and 5e cabling needs. Standard category 5e patch cables are also available. Tripp Lite warrants this product to be free from defects in materials and workmanship for life. C Clamshell retail packaging. Features ● Cabling for category 5 (Cat5) and 5e (Cat5e) applications ● Length: 5-ft. color: blue connectors: RJ45 male ● Feature molded connectors with integral strain relief ● Snagless design protects the locking tabs on the RJ45 connectors from being damaged or snapped off during installation ● PVC 4-pair stranded UTP ● Rated for 350MHz/ 1Gbps communication ● Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 5e draft 11) ● Available in other colors and lengths ● Also available without the snagless feature (N002 series) ● Also available - Cat6 cables (N201 series) ● Warranted to be free from defects in materials and workmanship for life Specifications OVERVIEW UPC Code 037332012470 1/2 5-ft. Blue Snagless Cat5e Patch Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color Blue Cable Shielding UTP Cable Length (ft.) 5 Cable Length (m) 1.52 Shipping Dimensions (hwd / in.) 7.10 x 6.30 x 1.90 Shipping Dimensions (hwd / cm) 18.03 x 16.00 x 4.83 Shipping Weight (lbs.) 0.18 Shipping Weight (kg) 0.08 CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
N001-005-BK-R 价格&库存
很抱歉,暂时无法提供与“N001-005-BK-R”相匹配的价格&库存,您可以联系我们找货
