N001-125-GY
N001-125-GY
    TRIPPLITE
    N001-125-GY
N001-125-GY 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat5e 350 MHz Snagless Molded Ethernet Cable (RJ45 M/M) - Gray, 125-ft. MODEL NUMBER: N001-125-GY Highlights ● Cabling for Category 5 (Cat5) and 5e (Cat5e) applications ● Solid Conductor wire for long distance performance ● Snagless boots protect the locking tabs on the RJ45 connectors from being damaged during installation ● Feature molded connectors with integral strain relief. Rated for 350 MHz/ 1 Gbps communication ● Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801, and ETL (Category 5e, draft 11) System Requirements ● Description Tripp Lite's 125-ft. gray snagless category 5e (Cat5e) patch cable has 2 snagless RJ45 molded male connectors featuring integral strain relief. The cable is manufactured from PVC 4-pair Solid Conductor UTP for improved long run performance, and is rated for 350MHz/1Gbps communication. All cables are offered in a variety of lengths and colors for all category 5 (Cat5) and 5e cabling needs. Standard category 5e patch cables are also available. Features ● Cabling for category 5 (Cat5) and 5e (Cat5e) applications ● Length: 125-ft. Color: gray Connectors: RJ45 male ● Feature molded connectors with integral strain relief ● Snagless design protects the locking tabs on the RJ45 connectors from being damaged or snapped off during installation ● PVC 4-pair Solid UTP ● Rated for 350MHz/ 1Gbps communication ● Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 5e draft 11) ● Available in other colors and lengths ● Also available without the snagless feature (N002 series) ● Also available - Cat6 cables (N201 series) Specifications OVERVIEW UPC Code 037332041951 Technology Cat5/5e 1/2 For 1000Base-T (1Gbps Ethernet), 10/100Base-T (Ethernet), 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice and Token Ring Type3 applications. Package Includes ● 125-ft. Gray Snagless Cat5e Patch Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color Gray Cable Shielding UTP Wire Type Solid Cable Length (ft.) 125 Cable Length (m) 38.11 Cable Length (in.) 1500 Cable Length (cm) 3810 Shipping Dimensions (hwd / in.) 17.00 x 14.00 x 2.00 Shipping Dimensions (hwd / cm) 43.18 x 35.56 x 5.08 Shipping Weight (lbs.) 2.80 Shipping Weight (kg) 1.27 COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit) CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) FEATURES & SPECIFICATIONS Snagless Connector Yes WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
N001-125-GY 价格&库存
很抱歉,暂时无法提供与“N001-125-GY”相匹配的价格&库存,您可以联系我们找货
