N201-007-GN-R
N201-007-GN-R
    TRIPPLITE
    N201-007-GN-R
N201-007-GN-R 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 7-ft. Cat6 Gigabit Snagless Molded Ethernet Cable (RJ45 M/M) - Green MODEL NUMBER: N201-007-GN-R Highlights ● Meets Category 6 cabling standards. Reduces return loss and cross talk. ● Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801, and ETL (Category 6, draft 11) ● Drastically reduce impedance & structural return loss compared to standard 100Mhz wire. ● Snagless boots protect the locking tabs on the RJ45 connectors from being damaged during installation. ● Feature molded connectors with integral strain relief. Rated for 550 MHz/1 Gbps communication. Comes in retail packaging. ● Lifetime product warranty System Requirements Description With Tripp Lite's new category 6 molded patch cables you can stay ahead of the game by using this highspeed cable to distribute data, voice and video. These cables deliver stable performance up to 550MHz. Each comes UL verified meets EIA/TIA Cat6 TIA/EIA-568-B-2.1 draft 9 standards. Constructed with highquality copper wire and a staggered-pin plug design, near-end crosstalk levels are kept to a minimum. Designed for use in category 6, category 5e and category 5 applications. Cat6 cables are available in a variety of colors with a snagless boot preventing cable snags. Tripp Lite warrants this product to be free from defects in materials and workmanship for life. Clamshell retail packaging. ● For 1000 Base-T (1Gbps Ethernet), 10/100 Base-T (Ethernet), 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice and Token Ring TYPE 3 applications as well as EIA/TIA applications. Package Includes Features ● ● Meets category 6 cabling standards ● Premium cabling for category 6, category 5e and category 5 applications ● Length: 7-ft. Color: green Connectors: RJ45 male ● Drastically reduce impedance & structural return loss compared to standard 100MHz wire ● High-quality copper wire and a staggered-pin plug design to keep near-end crosstalk levels to a minimum ● Feature molded connectors with integral strain relief ● Snagless design protects the locking tabs on the RJ45 connectors from being damaged or snapped off during installation ● PVC 4-pair stranded UTP ● Deliver stable performance up to 550MHz/1 Gbps communication ● Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 6 draft 11) ● Available in other colors and lengths ● Warranted to be free from defects in materials and workmanship for life Specifications 1/2 7-ft. Cat6 Green Gigabit Patch Cord Snagless Molded RJ45 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332116925 PHYSICAL Color Green Cable Shielding UTP Cable Length (ft.) 7 Cable Length (m) 2.13 Shipping Dimensions (hwd / in.) 0.01 x 0.01 x 2.00 Shipping Dimensions (hwd / cm) 0.03 x 0.03 x 5.08 Shipping Weight (lbs.) 0.01 COMMUNICATIONS Attenuation @ 850NM 26.1 dB/100 m CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
N201-007-GN-R 价格&库存
很抱歉,暂时无法提供与“N201-007-GN-R”相匹配的价格&库存,您可以联系我们找货
