N001-250-GY
N001-250-GY
    TRIPPLITE
    N001-250-GY
N001-250-GY 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat5e 350 MHz Snagless Molded Ethernet Cable (RJ45 M/M) - Gray, 250-ft. MODEL NUMBER: N001-250-GY Description Tripp Lite's 250-ft. gray snagless category 5e (Cat5e) patch cable has 2 snagless RJ45 molded male connectors featuring integral strain relief. The cable is manufactured from PVC 4-pair Solid Conductor UTP for improved long run performance, and is rated for 350MHz/1Gbps communication. All cables are offered in a variety of lengths and colors for all category 5 (Cat5) and 5e cabling needs. Standard category 5e patch cables are also available. Highlights ● Cabling for Category 5 (Cat5) and 5e (Cat5e) applications ● Solid Conductor wire for long distance performance ● Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801, and ETL (Category 5e, draft 11) ● Feature molded connectors with integral strain relief. Rated for 350 MHz/ 1 Gbps communication. ● Snagless boots protect the locking tabs on the RJ45 connectors from being damaged during installation Features ● Cabling for category 5 (Cat5) and 5e (Cat5e) applications ● Length: 250- Ft. Color: gray Connectors: RJ45 male ● Feature molded connectors with integral strain relief ● Snagless design protects the locking tabs on the RJ45 connectors from being damaged or snapped off during installation ● PVC 4-pair Solid UTP ● Rated for 350MHz/ 1Gbps communication ● Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 5e draft 11) ● Available in other colors and lengths ● Also available without the snagless feature (N002 series) ● Also available - Cat6 cables (N201 series) System Requirements ● Package Includes ● Specifications OVERVIEW UPC Code 037332041975 PHYSICAL Color Gray Cable Shielding UTP Cable Length (ft.) 250 Cable Length (m) 76.22 Shipping Dimensions (hwd / in.) 20.00 x 18.00 x 3.00 Shipping Dimensions (hwd / cm) 50.80 x 45.72 x 7.62 Shipping Weight (lbs.) 5.50 Shipping Weight (kg) 2.49 For 1000Base-T (1Gbps Ethernet), 10/100Base-T (Ethernet), 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice and Token Ring Type3 applications. 1/2 250Ft Gray Snagless Cat5e Patch Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
N001-250-GY 价格&库存
很抱歉,暂时无法提供与“N001-250-GY”相匹配的价格&库存,您可以联系我们找货
