N007-150-GY
N007-150-GY
    TRIPPLITE
    PATCHCABLERJ45GRY150'
N007-150-GY 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat5e 350 MHz Outdoor-Rated Molded (UTP) Ethernet Cable (RJ45 M/M), PoE - Gray, 150 ft. (45.72 m) Highlights ● High Quality Outdoor Rated PVC Jacket ● Molded, Snagless RJ45 Connector MODEL NUMBER: N007-150-GY Package Includes ● Description Tripp Lite's line of Outdoor Rated Cat5e Patch Cables are manufactured with high quality UV (Ultra Violet) resistant PVC cable. With an operating temperature range of -40C to +60C (-40F to +140F), this 150-ft. (45.72 m) cable handles a wide range of weather conditions, most importantly, the degrading effects of Ultra Violet rays. Molded, snagless connectors provide a secure connection every time. Cables meet EIA/TIA 568-B.2, and are UL verified to Category 5e. Features ● UV (Ultra Violet) Resistant Gray PVC jacket ● CMR, CMX, and UL444 Rated ● EIA/TIA 568-B.2 Compliant ● UL Verified Category 5e ● Molded, Snagless Connectors ● 4pr, Solid Conductors for long distance signal integrity Specifications OVERVIEW UPC Code 037332140609 Technology Cat5/5e POWER Power Over Cable (PoC) Support No 1/3 150-ft. (45.72 m) Outdoor Rated Cat5e Patch Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Cable Jacket Color Gray Cable Jacket Material PVC Cable Jacket Rating CMR; CMX Cable Shielding UTP Cable Outer Diameter (OD) 5.5 mm Number of Conductors 4 Pair Conductor Material Solid Copper Conductor Gauge 24 AWG Cable Length (ft.) 150 Cable Length (m) 45.73 Cable Length (in.) 1800 Cable Length (cm) 4572 Shipping Dimensions (hwd / in.) 17.00 x 14.00 x 0.50 Shipping Dimensions (hwd / cm) 43.18 x 35.56 x 1.27 Shipping Weight (lbs.) 3.47 Shipping Weight (kg) 1.57 ENVIRONMENTAL Operating Temperature Range 14 to 104 F (-10 to 40 C) Storage Temperature Range 5 to 122 F (-15 to 50 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 100 MHz Maximum Bandwidth as Tested 350 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3ab; 802.3at CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) Crossover Wiring No Contact Plating Gold PoE Type Type 2 PoE+ (30W, IEEE 802.3at) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Connector Type Molded Wiring Configuration EIA/TIA 568B Angled Connector No FEATURES & SPECIFICATIONS IP68 Rated No Snagless Connector No Antibacterial No STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3ab 1000Base-T; IEEE 802.3at PoE+; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N007-150-GY 价格&库存
很抱歉,暂时无法提供与“N007-150-GY”相匹配的价格&库存,您可以联系我们找货
