N265-007
N265-007
    TRIPPLITE
    PATCHCABLESTRAIGHTRJ45M/M7'
N265-007 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States T1 Shielded RJ48C Patch Cable (RJ45 M/M), 7-ft. Highlights ● 22AWG, 100ohm T1 Rated Cable ● Connects your T1 CSU/DSU ● Meets ANSI T1.403 Cabling Requirement ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: N265-007 Package Includes 7ft T1 Shielded RJ48C Patch Cable Description Tripp Lite's T1, RJ45-RJ45 , ( RJ48C ) Patch Cables are constructed with premium Quabbin 9720, T1 certified cable. Two individually shielded, 22AWG, 100ohm pairs, maximize the performance of your expensive T1 circuits and equipment. Beware of generic T1 patch cables made with inexpensive Cat5 unshielded patch cable. The American National Standards Institute ( ANSI ) states in ANSI T1.403 that T1 cable be constructed of two balanced pairs, 22 AWG Solid conductor, 100ohm impedance, with a loss budget of 5.5db. Straight through wiring configuration available in 3ft, 5ft, 7ft, and 10ft lengths. Custom lengths available...consult your reseller. Also available in Crossover wiring configuration...see Tripp Lite N266- Series T1 patch cables. Features ● ANSI certified T1 cable, Levels 1, 1A, and 1C ● Complies with ANSI T1.403 Carrier-to-Customer Installation-DS1 Metallic Interface ● Straight through T1 wiring configuration ● Available in 3ft, 5ft, 7ft, and 10ft stocked lengths ● Custom length cables available ● NEC (UL) Type CMR ● Available in Crossover wiring configurations ● 22AWG Solid Tinned Copper Specifications OVERVIEW UPC Code 037332150325 PHYSICAL 1/2 1000 Eaton Boulevard Cleveland, OH 44122 United States Color Beige Cable Jacket Rating CMR Cable Shielding STP Wire Type Solid Cable Length (ft.) 7 Cable Length (m) 2.13 Cable Length (in.) 84 Cable Length (cm) 213.4 Shipping Dimensions (hwd / in.) 12.00 x 10.00 x 0.50 Shipping Dimensions (hwd / cm) 30.48 x 25.40 x 1.27 Shipping Weight (lbs.) 0.25 Shipping Weight (kg) 0.11 CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) FEATURES & SPECIFICATIONS Snagless Connector No WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
N265-007 价格&库存
很抱歉,暂时无法提供与“N265-007”相匹配的价格&库存,您可以联系我们找货
