P004-006-2C13
P004-006-2C13
    TRIPPLITE
    P004-006-2C13
P004-006-2C13 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States C14 Male to C13 Female Splitter, PDU Style - C14 to 2x C13, 10A, 250V, 18 AWG, 6 ft. (1.83 m), Black Highlights ● Connects 2 devices to one AC outlet to save space and reduce cable clutter ● Recommended for powering dual computers, monitors or other compatible peripherals ● 6-ft. (1.83 m) length allows flexibility in placing devices in relationship to AC outlet ● Ideal replacement for worn-out or missing C13-to-C14 PDUstyle extension cord MODEL NUMBER: P004-006-2C13 Applications C14-to-C13 splitter allows 2 devices with C14 inlets to share one AC power input cord and one C13 outlet on a PDU or UPS system. Features ● Connect 2 devices like computers, monitors, scanners and printers to one power outlet up to 6-ft. (1.83 m) away in your home office, work space or dorm room ● Cut cable clutter by powering both monitors in a dual-monitor display mount with a single cord ● Save space in a 0U vertical rack-mount PDU by plugging two rack devices into one outlet Package Includes C14-to-C13 Y-Style Splitter Cord Connects 2 Devices with C14 Inlets to One C13 OutletThis IEC320-C14 to IEC-320-C13 splitter allows two devices with C14 power inlets to share one AC input cord and one C13 outlet. This C14 male to C13 female cord features a C14 end for connecting to an AC power source and two C13 ends for connecting to devices. By connecting two devices to one outlet, the power cord splitter frees up space in a PDU, UPS system or surge protector and helps reduce cable clutter. The 6-ft. (1.83 m) length allows you flexibility in placing equipment with respect to the power outlet. Dual IEC Cable Powers a Wide Variety of Essential ElectronicsWith this PC power splitter, a single C13 outlet can power two devices, such as computers, monitors, printers, instrument amplifiers and other equipment compatible with a C13 connector. Ideal for areas where AC outlets are limited, such as rack cabinets, this dual IEC cable is compatible with Tripp Lite power and extension cords. Specifications OVERVIEW UPC Code 037332154750 Device Compatibility Computer; Monitor/HDTV; Printer; Scanner; UPS; PDU Country/Region Global INPUT Maximum Input Amps 10 Voltage Compatibility (VAC) 100-250 1/3 ● P004-006-2C13 C14 Male to C13 Female Splitter, PDU Style, 6-ft. (1.83 m), Black 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Plug Color Black Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 7.8mm Number of Conductors 3 Wire Gauge (AWG) 18 Wire Gauge (OD - mm²) 0.82 Cable Length (ft.) 6 Cable Length (m) 1.83 Shipping Dimensions (hwd / in.) 10.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 25.40 x 17.78 x 1.27 Shipping Weight (lbs.) 0.73 Shipping Weight (kg) 0.33 ENVIRONMENTAL Operating Temperature Range -4 F TO 140 F (-20 C TO 60 C) Storage Temperature Range -4 F TO 140 F (-20 C TO 60 C) Operating Humidity Range 10 TO 65% RH Storage Humidity Range 10 TO 65% RH CONNECTIONS Side A - Connector 1 IEC-320-C14 Side B - Connector 1 (2) IEC-320-C13 FEATURES & SPECIFICATIONS High Voltage Yes Locking Plug No Antibacterial No Angled Plug No Coiled Power Cord No STANDARDS & COMPLIANCE Product Certifications CSA (Canada); cUL Listed; UL Listed 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P004-006-2C13 价格&库存
很抱歉,暂时无法提供与“P004-006-2C13”相匹配的价格&库存,您可以联系我们找货
P004-006-2C13
  • 1+176.232301+22.80540
  • 10+149.7609010+19.37990
  • 25+140.3702025+18.16470
  • 50+133.6266050+17.29200
  • 100+127.31420100+16.47520
  • 250+119.33680250+15.44290
  • 500+116.70170500+15.10180
库存:246
