P005-006
P005-006
    TRIPPLITE
    P005-006
P005-006 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Heavy-Duty PDU Power Cord, C13 to C14 - 15A, 250V, 14 AWG, 6 ft. (1.83 m), Black MODEL NUMBER: P005-006 Highlights ● Recommended for powering computers, servers and other network devices ● 6-ft. (1.83 m) length allows flexibility in placing devices in relationship to AC outlet ● PDU-style cord replaces or upgrades standard power cord provided by manufacturer ● Thick 14 AWG wire gauge manages high power levels required for larger equipment Applications Computer power extension cord connects devices with C13/C14 power connectors or extends your existing power connection by 6 ft. ● Connect devices like computers, servers and monitors to a PDU up to 6-ft. (1.83 m) away in your data center ● Extend an existing power connection up to 6-ft. (1.83 m) to more easily place a device or reach a power source in a rack ● Update or replace the standard power cord provided by a device's original manufacturer Features C14-to-C13 Power Cable for Network Devices That Require a Heavy-Gauge ConnectionThis IEC320-C14 to IEC-320-C13 cable features 14 AWG wire suitable for high power connections, making it a reliable solution for large server applications that require a higher-rated, heavier-gauge cable. This C14 male to C13 female cord can be used to connect a computer, server, monitor or drive to a UPS system or PDU or replace or upgrade the standard power cord provided by the device's manufacturer. The 6-ft. (1.83 m) length allows you flexibility in placing equipment with respect to the power outlet. Specifications OVERVIEW UPC Code 037332150004 Device Compatibility Computer; Monitor/HDTV; Printer; Server; Router; Network Switch; UPS; PDU Country/Region Global INPUT Maximum Input Amps 15 Voltage Compatibility (VAC) 100-250 PHYSICAL Plug Color Black Cable Jacket Color Black 1/3 Package Includes ● P005-006 Heavy-Duty C13 to C14 PDU-Style Power Extension Cable, 6-ft. (1.83 m), Black 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Material PVC Cable Jacket Rating VW-1 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 9.3mm Number of Conductors 3 Wire Gauge (AWG) 14 Wire Gauge (OD - mm²) 2.08 Cable Length (ft.) 6 Cable Length (m) 1.83 Shipping Dimensions (hwd / in.) 1.00 x 7.00 x 11.00 Shipping Dimensions (hwd / cm) 2.54 x 17.78 x 27.94 Shipping Weight (lbs.) 0.78 Shipping Weight (kg) 0.35 ENVIRONMENTAL Operating Temperature Range -4 F TO 140 F (-20 C TO 60 C) Storage Temperature Range -4 F TO 140 F (-20 C TO 60 C) Operating Humidity Range 10 TO 65% RH Storage Humidity Range 10 TO 65% RH CONNECTIONS Side A - Connector 1 IEC-320-C14 Side B - Connector 1 IEC-320-C13 FEATURES & SPECIFICATIONS High Voltage Yes Locking Plug No Antibacterial No Angled Plug No Coiled Power Cord No STANDARDS & COMPLIANCE Product Certifications CSA (Canada); cUL Listed; UL Listed Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P005-006 价格&库存
很抱歉,暂时无法提供与“P005-006”相匹配的价格&库存,您可以联系我们找货
