1000 Eaton Boulevard
Cleveland, OH 44122
United States
Power Cord, C19 to NEMA 5-20P - Heavy-Duty,
20A, 125V, 12 AWG, 10 ft. (3.05 m), Black
Highlights
10-ft. (3.05 m) length allows
great flexibility in placing
devices in relationship to AC
outlet
Heavy-duty cable replaces or
upgrades standard power cord
provided by manufacturer
Thick 12 AWG wire gauge
manages high power levels
required for larger equipment
MODEL NUMBER: P049-010
Applications
Heavy-duty extension cord transforms a C20 plug into a NEMA 5-20P plug and extends an existing
connection up to 10 ft.
Connect devices to a power
outlet up to 10-ft. (3.05 m) away
in your office or work space
Transform a C20 plug into a
NEMA 5-20P plug with no
electrician needed
Extend an existing power
connection up to 10-ft. (3.05 m)
to more easily place a device or
reach a power source in a rack
Update or replace the standard
power cord provided by a
device's original manufacturer
Features
Heavy-Duty Extension Cable Connects Devices That Require a Heavy-Gauge ConnectionThis
heavy-duty extension cord features 12 AWG wire suitable for high power connections, making it a reliable
solution for large server applications that require a higher-rated, heavier-gauge cable. This C19 to 5-20P
cord can be used to connect a high-output device to a wall outlet or a PDU or UPS with 5-20R outlets. It is
also a recommended replacement or upgrade of a standard power cord provided by the device's
manufacturer. The 10-ft. (3.05 m) length allows you great flexibility in placing equipment with respect to
the power outlet.
Specifications
OVERVIEW
UPC Code
037332140944
Device Compatibility
Server; Router; Network Switch; UPS; PDU
Country/Region
North America
INPUT
Maximum Input Amps
Voltage Compatibility (VAC)
125
PHYSICAL
Color
Black
Plug Color
Black
1/3
Package Includes
P049-010 C19 to 5-20P HeavyDuty Extension Cord, 10-ft.
(3.05 m), Black
Cleveland, OH 44122
United States
Cable Jacket Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
VW-1
Power Cord Jacket Type
SJT
Cable Outer Diameter (OD)
11mm
Number of Conductors
3
Wire Gauge (AWG)
12
Wire Gauge (OD - mm²)
3.31
Cable Length (ft.)
10
Cable Length (m)
3.05
Shipping Dimensions (hwd / in.)
10.98 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
27.89 x 17.78 x 1.27
Shipping Weight (lbs.)
1.54
Shipping Weight (kg)
0.70
ENVIRONMENTAL
Operating Temperature Range
-4 F TO 140 F (-20 C TO 60 C)
Storage Temperature Range
Relative Humidity
10 ~ 65% RH, Non-Condensing
CONNECTIONS
Side A - Connector 1
NEMA 5-20P
Side B - Connector 1
IEC-320-C19
FEATURES & SPECIFICATIONS
High Voltage
No
Locking Plug
No
Antibacterial
No
Angled Plug
No
Coiled Power Cord
No
STANDARDS & COMPLIANCE
Product Certifications
cUL Listed; UL Listed
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
2/3
Cleveland, OH 44122
United States
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“P049-010”相匹配的价格&库存,您可以联系我们找货
