P034-008
P034-008
    TRIPPLITE
    P034-008
P034-008 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Computer Power Cord, C19 to NEMA 5-15P Heavy-Duty, 15A, 125V, 14 AWG, 8 ft. (2.43 m), Black Highlights ● Recommended for powering computers, servers and other network devices ● 8-ft. (2.43 m) length allows great flexibility in placing devices in relationship to AC outlet ● Heavy-duty computer power cord replaces or upgrades cord provided by manufacturer ● Thick 14 AWG wire gauge manages high power levels required for larger equipment MODEL NUMBER: P034-008 Applications ● Connect devices like computers, servers and monitors to a PDU up to 8-ft. (2.43 m) away in your data center ● Extend an existing power connection up to 8-ft. (2.43 m) to more easily place a device or reach a power source ● Update or replace the standard power cord provided by a device's original manufacturer C19 to 5-15P adapter connects devices with C20/NEMA 5-15R power connectors or extends your existing power connection by 8 ft. Package Includes Features Heavy-Duty Computer Power Cable for Devices That Require a Heavy-Gauge ConnectionThis C19 to 5-15P computer power cord features 14 AWG wire suitable for high power connections, making it a reliable solution for large server applications that require a higher-rated, heavier-gauge cable. It can be used to connect a computer, server, monitor or drive to a UPS system or PDU or replace or upgrade the standard power cord provided by the device's manufacturer. The 8-ft. (2.43 m) length allows you great flexibility in placing equipment with respect to the power outlet. Specifications OVERVIEW UPC Code 037332188717 Device Compatibility Computer; Monitor/HDTV; Server; UPS; PDU Country/Region North America INPUT Maximum Input Amps 15 Voltage Compatibility (VAC) 125 PHYSICAL Plug Color Black Cable Jacket Color Black 1/3 ● P034-008 Computer Power Cable, C19 to 5-15P, 8-ft. (2.43 m), Black 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Material PVC Cable Jacket Rating VW-1 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 9.3mm Number of Conductors 3 Wire Gauge (AWG) 14 Wire Gauge (OD - mm²) 2.08 Cable Length (ft.) 8 Cable Length (m) 2.44 Shipping Dimensions (hwd / in.) 8.85 x 12.80 x 0.50 Shipping Dimensions (hwd / cm) 22.48 x 32.51 x 1.27 Shipping Weight (lbs.) 0.95 Shipping Weight (kg) 0.43 ENVIRONMENTAL Operating Temperature Range 14 F TO 140 F (-10 C TO 60 C) Storage Temperature Range 14 F TO 140 F (-10 C TO 60 C) Operating Humidity Range 35% to 85% RH, Non-Condensing Storage Humidity Range 35% to 85% RH, Non-Condensing CONNECTIONS Side A - Connector 1 NEMA 5-15P Side B - Connector 1 IEC-320-C19 FEATURES & SPECIFICATIONS High Voltage No Locking Plug No Antibacterial No Angled Plug No Coiled Power Cord No STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P034-008 价格&库存
很抱歉,暂时无法提供与“P034-008”相匹配的价格&库存,您可以联系我们找货
