P032-007
P032-007
    TRIPPLITE
    P032-007
P032-007 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States C20 to C13 Power Cord for Computer - HeavyDuty, 15A, 100-250V, 14 AWG, 7 ft. (2.13 m), Black Highlights ● Recommended for powering computers, servers and other network devices ● 7-ft. (2.13 m) length allows flexibility in placing devices in relationship to AC outlet ● Heavy-duty C13-to-C20 cable replaces or upgrades standard cord provided by manufacturer ● Thick 14 AWG wire gauge manages high power levels required for larger equipment MODEL NUMBER: P032-007 Applications ● Connect devices like computers, servers and monitors to a PDU up to 7-ft. (2.13 m) away in your data center ● Extend an existing power connection up to 7-ft. (2.13 m) to more easily place a device or reach a power source ● Update or replace the standard power cord provided by a device's original manufacturer C20-to-C13 adapter connects devices with C19/C14 power connectors or extends your existing power connection by 7 ft. Package Includes Features Heavy-Duty Computer Power Cord for Devices That Require a Heavy-Gauge ConnectionThis C20to-C13 power cable features 14 AWG wire suitable for high power connections, making it a reliable solution for large server applications that require a higher-rated, heavier-gauge cable. This IEC C20-toC13 cord can be used to connect a computer, server, monitor or drive to a UPS system or PDU or replace or upgrade the standard power cord provided by the device’s manufacturer. The seven-foot length allows you flexibility in placing equipment with respect to the power outlet. Specifications OVERVIEW UPC Code 037332126313 Device Compatibility Computer; Monitor/HDTV; Server; UPS; PDU Country/Region North America INPUT Maximum Input Amps 15 Voltage Compatibility (VAC) 100-250 PHYSICAL Plug Color Black Cable Jacket Color Black 1/3 ● P032-007 C20 to C13 Power Cable for Computer, 7-ft. (2.13 m), Black 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Material PVC Cable Jacket Rating VW-1 Power Cord Jacket Type SJTW Cable Outer Diameter (OD) 9.3mm Number of Conductors 3 Wire Gauge (AWG) 14 Wire Gauge (OD - mm²) 2.08 Cable Length (ft.) 7 Cable Length (m) 2.13 Shipping Dimensions (hwd / in.) 12.80 x 8.90 x 0.50 Shipping Dimensions (hwd / cm) 32.51 x 22.61 x 1.27 Shipping Weight (lbs.) 1.15 Shipping Weight (kg) 0.52 ENVIRONMENTAL Operating Temperature Range -4 F TO 140 F (-20 C TO 60 C) Storage Temperature Range -4 F TO 140 F (-20 C TO 60 C) Operating Humidity Range 10 TO 65% RH Storage Humidity Range 10 TO 65% RH CONNECTIONS Side A - Connector 1 IEC-320-C20 Side B - Connector 1 IEC-320-C13 FEATURES & SPECIFICATIONS High Voltage Yes Locking Plug No Antibacterial No Angled Plug No Coiled Power Cord No STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P032-007 价格&库存
很抱歉,暂时无法提供与“P032-007”相匹配的价格&库存,您可以联系我们找货
