P007-012
P007-012
    TRIPPLITE
    P007-012
P007-012 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Computer Power Cord, NEMA 5-15P to C13 Heavy-Duty, 15A, 125V, 14 AWG, 12 ft. (3.66 m), Black Highlights ● Recommended for powering larger servers, laser printers and other network devices ● 12-ft. (3.66 m) length allows great flexibility in placing devices in relationship to AC outlet ● Computer power cable replaces or upgrades original manufacturer's power cord ● Thick 14 AWG wire gauge manages high power levels required for larger equipment MODEL NUMBER: P007-012 Applications Computer power cord connects a server, computer, monitor, printer or other device with a C14 inlet to an AC outlet on a PDU. Features ● Connect devices like computers, large servers and laser printers to a PDU up to 12 ft. away in your data center ● Extend an existing power connection up to 12-ft. (3.66 m) to more easily place a device or reach a power source in a rack ● Update or replace the standard power cord provided by a device's original manufacturer Package Includes 5-15P to C13 Power Cable for Network Devices That Require a Heavy-Gauge ConnectionThis computer power supply cable features 14 AWG wire suitable for high power connections, making it a reliable solution for large server applications that require a higher-rated, heavier-gauge cable. You can use it to connect a computer, server, monitor, laser printer or drive to a PDU, UPS, surge protector or AC wall outlet. It can also replace or upgrade the standard power cord provided by the device's manufacturer. The 12-ft. (3.66 m) length allows you great flexibility in placing equipment with respect to the power outlet. Specifications OVERVIEW UPC Code 037332182548 Device Compatibility Computer; Monitor/HDTV; Printer; Server; UPS; PDU Country/Region North America INPUT Maximum Input Amps 15 Voltage Compatibility (VAC) 125 PHYSICAL Plug Color Black Cable Jacket Color Black 1/3 ● P007-012 Desktop Computer Power Cord, 5-15P to C13, 12ft. (3.66 m), Black 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Material PVC Cable Jacket Rating VW-1 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 9.3mm Number of Conductors 3 Wire Gauge (AWG) 14 Wire Gauge (OD - mm²) 2.08 Cable Length (ft.) 12 Cable Length (m) 3.66 Shipping Dimensions (hwd / in.) 14.17 x 11.80 x 0.50 Shipping Dimensions (hwd / cm) 35.99 x 29.97 x 1.27 Shipping Weight (lbs.) 1.19 Shipping Weight (kg) 0.54 ENVIRONMENTAL Operating Temperature Range -4 F TO 140 F (-20 C TO 60 C) Storage Temperature Range -4 F TO 140 F (-20 C TO 60 C) Operating Humidity Range 10 TO 65% RH Storage Humidity Range 10 TO 65% RH CONNECTIONS Side A - Connector 1 NEMA 5-15P Side B - Connector 1 IEC-320-C13 FEATURES & SPECIFICATIONS High Voltage No Locking Plug No Antibacterial No Angled Plug No Coiled Power Cord No STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P007-012 价格&库存
很抱歉,暂时无法提供与“P007-012”相匹配的价格&库存,您可以联系我们找货
