1000 Eaton Boulevard
Cleveland, OH 44122
United States
Power Cord, C19 to NEMA L6-20 - Heavy-Duty,
20A, 250V, 12 AWG, 10 ft. (3.05 m), Black
MODEL NUMBER: P040-010
Highlights
Recommended for powering
servers, switches and other
essential network devices
L6-20 Locking connector
maintains secure link to avoid
loss of power and costly
downtime
Thick 12 AWG wire gauge
manages high power levels
required for larger equipment
C19 to L6-20P power cord is
ideal replacement for worn-out
or missing cable
Long 10-ft. (3.05 m) cord
provides flexibility in placing
connected device away from
outlet
Applications
Connect network devices like
servers, switches and blade
server enclosures to a PDU up
to 10-ft. (3.05 m) away in your
data center
Extend an existing power
connection up to 10-ft. (3.05 m)
to more easily place a device or
reach a power source in a rack
Replace a worn-out or missing
heavy-gauge power cord
Heavy-duty power cord supplies power to network devices that require a heavy-gauge connection, such
as larger servers and switches.
Features
C19 to L6-20P Power Cable for Network Devices That Require a Heavy-Gauge ConnectionThis 12
AWG power cable is designed for servers, routers, network switches, blade server enclosures and other
devices that require a heavy-gauge connection capable of managing high power levels. The fully molded
C19 end connects to your device's C20 inlet, and the fully molded NEMA L6-20P plug connects to an AC
power source up to 10-ft. (3.05 m) away. The 10-ft. (3.05 m) length allows you great flexibility in placing
equipment with respect to the power outlet.
Package Includes
Locking Connector Helps Prevent Accidental Disconnection and Expensive DowntimeHaving a
cable come loose accidentally can mean the loss of power and costly downtime. The locking NEMA L620P connector helps you avoid such danger, protecting critical equipment by maintaining a secure link
without failure. The locking connector is also invaluable when moving equipment in a rack or removing
equipment from tight areas, ensuring the heavy-duty power cable always stays connected.
Specifications
OVERVIEW
UPC Code
037332140951
Device Compatibility
Server; Router; Network Switch; UPS; PDU
Country/Region
North America
INPUT
Maximum Input Amps
Voltage Compatibility (VAC)
250
1/3
P040-010 C19 to L6-20P Power
Cord, 10-ft. (3.05 m), Black
Cleveland, OH 44122
United States
PHYSICAL
Color
Black
Cable Jacket Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
VW-1
Power Cord Jacket Type
SJT
Cable Outer Diameter (OD)
11mm
Number of Conductors
3
Wire Gauge (AWG)
12
Wire Gauge (OD - mm²)
3.31
Cable Length (ft.)
10
Cable Length (m)
3.05
Shipping Dimensions (hwd / in.)
10.98 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
27.89 x 17.78 x 1.27
Shipping Weight (lbs.)
1.71
Shipping Weight (kg)
0.78
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
ENVIRONMENTAL
Operating Temperature Range
-4 F TO 140 F (-20 C TO 60 C)
Storage Temperature Range
Relative Humidity
10 ~ 65% RH, Non-Condensing
Storage Humidity Range
10 TO 65% RH
CONNECTIONS
Side A - Connector 1
NEMA L6-20P
Side B - Connector 1
IEC-320-C19
FEATURES & SPECIFICATIONS
High Voltage
Yes
Locking Plug
Yes
Antibacterial
No
Angled Plug
No
Coiled Power Cord
No
STANDARDS & COMPLIANCE
2/3
Cleveland, OH 44122
United States
Product Certifications
cUL Listed; UL Listed
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“P040-010”相匹配的价格&库存,您可以联系我们找货
