P005-006-GN
P005-006-GN
    TRIPPLITE
    P005-006-GN
P005-006-GN 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Heavy-Duty PDU Power Cable, C13 to C14 - 15A, 250V, 14 AWG, Green, 6 ft. (1.83 m) MODEL NUMBER: P005-006-GN Highlights ● Ideal for powering your server, computer or other network component ● PDU power cable upgrades or replaces the manufacturer's standard computer power cord ● 14 AWG construction designed to handle high power levels needed for powering large equipment ● Green connectors allow quick identification in a crowded workstation or rack ● 6-ft. (1.83 m) power cable gives you flexibility in placing your devices away from an outlet Applications Computer power cord extends your existing C13-to-C14 power connection as much as 6 feet. Features Power Cable for Network Devices That Require a Heavy-Gauge ConnectionThis 14 AWG C14-to-C13 computer power cord is appropriate for high power connections and a dependable solution for server applications that demand a higher-rated, heavier-gauge cable. You can use this computer power cable for connecting a server, hard drive, monitor or computer to a PDU or USB system. It's a worthy upgrade or replacement for the power cable that came included with your device. At 6-ft. (1.83 m), the P005-006-GN gives you some flexibility in placing your connected devices. Green Connectors for Fast, Easy ID That Can Save Costly DowntimeThis 6-ft. (1.83 m) computer power cable features fully molded green C14 and C13 connectors. This allows you to color-code your connection in a crowded workstation or rack, helping you quickly identify it and prevent an accidental disconnection. Specifications OVERVIEW UPC Code 037332168368 Device Compatibility Computer; Monitor/HDTV; Printer; Server; Router; Network Switch; UPS; PDU Country/Region Global INPUT Maximum Input Amps 15 Voltage Compatibility (VAC) 100-250 PHYSICAL 1/3 ● Connect a computer, server, hard drive or display to a PDU or UPS up to 6-ft. (1.83 m) away ● Replace or update the standard power cable provided by your device's original manufacturer ● Extend an existing power connection up to 6-ft. (1.83 m) to more easily place a device or reach a power source in a rack Package Includes ● P005-006-GN Heavy-Duty Power Cable, Green, 6-ft. (1.83 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States Plug Color Green Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating FT2 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 9.2mm Number of Conductors 3 Wire Gauge (AWG) 14 Wire Gauge (OD - mm²) 2.08 Cable Length (ft.) 6 Cable Length (m) 1.83 Shipping Dimensions (hwd / in.) 10.00 x 7.10 x 0.50 Shipping Dimensions (hwd / cm) 25.40 x 18.03 x 1.27 Shipping Weight (lbs.) 0.71 Shipping Weight (kg) 0.32 ENVIRONMENTAL Operating Temperature Range -4 TO 140 F (- 20° TO 60°C) Storage Temperature Range -4 TO 140 F (- 20° TO 60°C) Operating Humidity Range 20-80% RH Storage Humidity Range 20-80% RH CONNECTIONS Side A - Connector 1 IEC-320-C14 Side B - Connector 1 IEC-320-C13 FEATURES & SPECIFICATIONS High Voltage Yes Locking Plug No Angled Plug No WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P005-006-GN 价格&库存
很抱歉,暂时无法提供与“P005-006-GN”相匹配的价格&库存,您可以联系我们找货
