P036-002
P036-002
    TRIPPLITE
    P036-002
P036-002 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Power Extension Cord, C19 to C20 - Heavy-Duty, 20A, 250V, 12 AWG, 2 ft. (0.61 m), Black MODEL NUMBER: P036-002 Highlights ● Recommended for powering servers, routers and other highoutput network devices ● 2-ft. (0.61 m) length allows flexibility in placing devices, while avoiding cable clutter ● C20 to C19 cord replaces or upgrades standard power cord provided by manufacturer ● Thick 12 AWG wire gauge manages high power levels required for larger equipment Applications C19 to C20 20A heavy-duty extension cable connects high-output devices with C19/C20 power connectors, including blade server chassis. ● Connect devices like computers, servers and monitors to a PDU up to 2-ft. (0.61 m) away in your data center ● Extend an existing power connection up to 2-ft. (0.61 m) to more easily place a device or reach a power source in a rack ● Update or replace the standard power cord provided by a device's original manufacturer Features 20A C20-to-C19 Power Cable for Network Devices That Require a Heavy-Gauge ConnectionThis heavy-duty extension cord features 12 AWG wire suitable for high power connections, making it a reliable solution for large server applications that require a higher-rated, heavier-gauge cable. This cord can be used to connect a server, router, network switch or blade server enclosure to a UPS system or PDU or replace or upgrade the standard power cord provided by the device's manufacturer. The 2-ft. (0.61 m) length helps reduce cable clutter and minimize the risk of tripping. Specifications OVERVIEW UPC Code 037332141613 Device Compatibility Server; Router; Network Switch; UPS; PDU Country/Region North America INPUT Maximum Input Amps 20 Voltage Compatibility (VAC) 100-250 PHYSICAL Plug Color Black Cable Jacket Color Black Cable Jacket Material PVC 1/3 Package Includes ● P036-002 C19 to C20 HeavyDuty Extension Cord, 2-ft. (0.61 m), Black 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Rating VW-1 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 11mm Number of Conductors 3 Wire Gauge (AWG) 12 Wire Gauge (OD - mm²) 3.31 Cable Length (ft.) 2 Cable Length (m) 0.61 Shipping Dimensions (hwd / in.) 12.80 x 8.90 x 0.50 Shipping Dimensions (hwd / cm) 32.51 x 22.61 x 1.27 Shipping Weight (lbs.) 0.55 Shipping Weight (kg) 0.25 ENVIRONMENTAL Operating Temperature Range -4 F TO 140 F (-20 C TO 60 C) Storage Temperature Range -4 F TO 140 F (-20 C TO 60 C) Operating Humidity Range 10 TO 65% RH Storage Humidity Range 10 TO 65% RH CONNECTIONS Side A - Connector 1 IEC-320-C20 Side B - Connector 1 IEC-320-C19 FEATURES & SPECIFICATIONS High Voltage Yes Locking Plug No Antibacterial No Angled Plug No Coiled Power Cord No STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P036-002 价格&库存
很抱歉,暂时无法提供与“P036-002”相匹配的价格&库存,您可以联系我们找货
