P006-014-13RA
P006-014-13RA
    TRIPPLITE
    P006-014-13RA
P006-014-13RA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Computer Power Cord, NEMA 5-15P to RightAngle C13 - 10A, 125V, 18 AWG, 14 ft. (4.27 m), Black Highlights ● Right-angle C13 plug allows easier connection in confined or hard-to-reach spaces ● Recommended for powering computers, printers and other compatible peripherals ● Adds 14-ft. (4.27 m) to your existing power connection to provide flexibility in placing devices ● Ideal replacement for worn-out or missing computer power cable ● NEMA 5-15P plug connects to AC power; C13 plug connects to device's C14 inlet MODEL NUMBER: P006-014-13RA Applications Computer power cord with right-angled C13 plug allows connection of a PC, monitor or printer in a tight space or at an awkward angle. ● Connect devices like computers, monitors, scanners and printers to a power outlet up to 14-ft. (4.27 m) away in your home office, work space or dorm room ● Extend an existing power connection up to 14-ft. (4.27 m) to more easily place a device or reach a power source away from your workstation ● Provide a high-quality replacement for a worn-out or missing power cord ● Power a device located in a hard-to-access area behind a desk or flush against a wall Features Desktop Computer Power Cord Connects PCs, Printers, Monitors and Other EquipmentThis desktop computer power cord is designed for computers, monitors, scanners, printers and other compatible peripherals. It features a right-angled C13 end for connecting to a device and a 5-15P plug for connecting to an AC power source. The 14-ft. (4.27 m) length allows you great flexibility in placing equipment with respect to the power outlet. Right-Angle PC Power Cable Is Easier to Connect in Tight SpacesThe angled C13 connector makes installations easier in confined spaces, such as the back of a rack enclosure cabinet. When plugged in, the right-angled plug guides the computer power supply cable parallel to your peripheral, allowing you to push the device up against a wall or hide it behind a desk to maximize space. Specifications OVERVIEW UPC Code 037332185877 Device Compatibility Computer; Monitor/HDTV; Printer; Server; UPS; PDU Country/Region North America INPUT Maximum Input Amps 10 1/3 Package Includes ● P006-014-13RA NEMA 5-15P to Right-Angle C13 Power Extension Cable, 14-ft. (4.27 m), Black 1000 Eaton Boulevard Cleveland, OH 44122 United States Voltage Compatibility (VAC) 125 PHYSICAL Plug Color Black Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating FT2 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 7.7mm Number of Conductors 3 Wire Gauge (AWG) 18 Wire Gauge (OD - mm²) 0.82 Cable Length (ft.) 14 Cable Length (m) 4.27 Shipping Dimensions (hwd / in.) 9.98 x 7.09 x 0.50 Shipping Dimensions (hwd / cm) 25.35 x 18.01 x 1.27 Shipping Weight (lbs.) 0.89 Shipping Weight (kg) 0.40 ENVIRONMENTAL Operating Temperature Range -4 TO 140 F (- 20° TO 60°C) Storage Temperature Range -4 TO 140 F (- 20° TO 60°C) Operating Humidity Range 20-80% RH Storage Humidity Range 20-80% RH CONNECTIONS Side A - Connector 1 NEMA 5-15P Side B - Connector 1 IEC-320-C13 - RIGHT ANGLE FEATURES & SPECIFICATIONS High Voltage No Locking Plug No Antibacterial No Angled Plug Yes Coiled Power Cord No STANDARDS & COMPLIANCE 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Certifications cUL Listed; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P006-014-13RA 价格&库存
很抱歉,暂时无法提供与“P006-014-13RA”相匹配的价格&库存,您可以联系我们找货
