P004-004-BL
P004-004-BL
    TRIPPLITE
    P004-004-BL
P004-004-BL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States PDU Power Cord, C13 to C14 - 10A, 250V, 18 AWG, 4 ft. (1.22 m), Blue MODEL NUMBER: P004-004-BL Highlights ● Recommended for powering computers, printers and other essential peripherals ● 4-ft. (1.22 m) length allows flexibility in placing devices, while avoiding cable clutter ● C13-to-C14 PDU-style extension cord is ideal replacement for worn-out or missing cable ● Color-coded blue for fast, easy identification in a crowded rack or workstation Applications ● Connect devices like computers, servers and monitors to a PDU up to 4-ft. (1.22 m) away in your data center ● Extend an existing power connection up to 4-ft. (1.22 m) to more easily place a device or reach a power source near your workstation ● Provide a high-quality replacement for a worn-out or missing power cord Blue computer power extension cord connects devices with C13/C14 power connectors or extends your existing power connection by 4 ft. Features C14-to-C13 Power Cable Connects Computers, Printers, Servers and Other EquipmentThis IEC320-C14 to IEC-320-C13 cable is designed for small data center, office workstation and other lower-amp applications. This C14 male to C13 female cord can be used to power a computer, server or monitor; attach a server or drive to a UPS system or PDU; or extend an existing connection up to 4-ft. (1.22 m). The 4-ft. (1.22 m) length helps reduce cable clutter and minimize the risk of tripping. Color-Coded to Avoid Misidentification That Can Cause Costly DowntimeThis computer power extension cord features a blue SJT jacket and fully molded blue ends. The color-coding allows easy, fast identification in a crowded rack or workstation and helps prevent the cable from becoming inadvertently disconnected. Specifications OVERVIEW UPC Code 037332173218 Device Compatibility Computer; Monitor/HDTV; Printer; Server; UPS; PDU Country/Region Global INPUT Maximum Input Amps 10 Voltage Compatibility (VAC) 100-250 PHYSICAL 1/3 Package Includes ● P004-004 C14 Male to C13 Female Power Cable, 4-ft. (1.22 m), Blue 1000 Eaton Boulevard Cleveland, OH 44122 United States Plug Color Blue Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating FT2 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 7.7mm Number of Conductors 3 Wire Gauge (AWG) 18 Wire Gauge (OD - mm²) 0.82 Cable Length (ft.) 4 Cable Length (m) 1.22 Shipping Dimensions (hwd / in.) 10.00 x 7.10 x 0.50 Shipping Dimensions (hwd / cm) 25.40 x 18.03 x 1.27 Shipping Weight (lbs.) 0.42 Shipping Weight (kg) 0.19 ENVIRONMENTAL Operating Temperature Range -4 TO 140 F (- 20° TO 60°C) Storage Temperature Range -4 TO 140 F (- 20° TO 60°C) Operating Humidity Range 20-80% RH Storage Humidity Range 20-80% RH CONNECTIONS Side A - Connector 1 IEC-320-C14 Side B - Connector 1 IEC-320-C13 FEATURES & SPECIFICATIONS High Voltage Yes Locking Plug No Antibacterial No Angled Plug No Coiled Power Cord No STANDARDS & COMPLIANCE Product Certifications CSA (Canada); cUL Listed; UL Listed Product Compliance RoHS; REACH 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P004-004-BL 价格&库存
很抱歉,暂时无法提供与“P004-004-BL”相匹配的价格&库存,您可以联系我们找货
