P018-002
P018-002
    TRIPPLITE
    P018-002
P018-002 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Power Cord C14 to C15 - Heavy-Duty, 15A, 250V, 14 AWG, 2 ft. (0.61 m), Black MODEL NUMBER: P018-002 Highlights ● Recommended for powering PoE switches with high-wattage power supplies ● 2-ft. (0.61 m) length allows flexibility in placing devices, while avoiding cable clutter ● C14 to C15 power cable replaces or upgrades original manufacturer's power cord ● Thick 14 AWG wire gauge manages high power levels required for larger equipment Applications Heavy-duty C14 to C15 power cord connects a PoE network switch or other device with a C16 power inlet to a PDU or UPS system. ● Connect devices like highwattage PoE switches to a PDU up to 2-ft. (0.61 m) away in your data center ● Update or replace the standard power cord provided by a device's original manufacturer ● Extend an existing power connection by 2-ft. (0.61 m) Package Includes Features ● C15 to C14 Power Cord for Network Devices That Require a Heavy-Gauge ConnectionThis 250V C15 to C14 cable features 14 AWG wire suitable for high power connections, making it reliable for large server applications that require a higher-rated, heavier-gauge cable. The C15 connector is designed for higher-temperature devices, such as electric kettles, PoE (Power over Ethernet) switches with highwattage power supplies, and similar network components. This IEC C14 to IEC C15 cord can also replace or upgrade the standard power cord provided by the device's manufacturer. The 2-ft. (0.61 m) length helps reduce cable clutter and minimize the risk of tripping. Specifications OVERVIEW UPC Code 037332182555 Device Compatibility Network Switch; UPS; PDU Country/Region North America INPUT Maximum Input Amps 15 Voltage Compatibility (VAC) 100-250 PHYSICAL Plug Color Black Cable Jacket Color Black 1/3 P018-002 IEC C14 to IEC C15 Power Cable, 2-ft. (0.61 m), Black 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Material PVC Cable Jacket Rating FT2 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 9.2mm Number of Conductors 3 Wire Gauge (AWG) 14 Wire Gauge (OD - mm²) 2.08 Cable Length (ft.) 2 Cable Length (m) 0.61 Shipping Dimensions (hwd / in.) 0.50 x 3.00 x 4.00 Shipping Dimensions (hwd / cm) 1.27 x 7.62 x 10.16 Shipping Weight (lbs.) 0.30 Shipping Weight (kg) 0.14 ENVIRONMENTAL Operating Temperature Range -4 TO 140 F (- 20° TO 60°C) Storage Temperature Range -4 TO 140 F (- 20° TO 60°C) Operating Humidity Range 20-80% RH Storage Humidity Range 20-80% RH CONNECTIONS Side A - Connector 1 IEC-320-C14 Side B - Connector 1 IEC-320-C15 FEATURES & SPECIFICATIONS High Voltage Yes Locking Plug No Antibacterial No Angled Plug No Coiled Power Cord No STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P018-002 价格&库存
很抱歉,暂时无法提供与“P018-002”相匹配的价格&库存,您可以联系我们找货
