P005-002-14LA
P005-002-14LA
    TRIPPLITE
    CABLECONVERTER2'
P005-002-14LA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Heavy-Duty Power Extension Cord, 15A, 14AWG (Left Angle IEC-320-C14 to IEC-320-C13), 2-ft. MODEL NUMBER: P005-002-14LA Highlights ● 2 ft. C13 to Left-Angle C14 Power Cord ● 14 AWG x 3C, 15A, 100-250V, SJT ● UL Listed Package Includes ● Save space in tight areas with this left-angle connector cord Description Use Tripp Lite's P005-002-14LA in server applications that require a higher rated, heavier gauge cable, and in which space is in high demand. The left-angle C14 connector on this power cord is perfect for saving space in tight areas, such as in the back of your rack enclosure cabinet. When plugged in, it seats flush against the back of a device (e.g. PDU, UPS, etc.), providing space for your rack door to close, or additional room to organize a tight area. C13 to Left-Angle C14 connectors, 3 x 14 AWG conductors, 15A rating, 100-250V, SJT jacket. Tripp Lite Lifetime Limited Warranty. Features ● Molded, Heavy-Duty Power Cable, 2 ft. ● IEC-60320-C13 to Left-Angle IEC-60320-C14 connectors ● Left-angle C14 connector is perfect for saving space in tight areas ● 14 AWG x 3C, 15A, 100-250V, SJT jacket ● RoHS Compliant ● UL Listed Specifications OVERVIEW UPC Code 037332179906 PHYSICAL Color Black 1/2 P005-002-14LA C13 to LeftAngle C14 Power Cord 1000 Eaton Boulevard Cleveland, OH 44122 United States Power Cord Jacket Type SJT Wire Gauge (AWG) 14 Cable Length (ft.) 2 Cable Length (m) 0.61 Shipping Dimensions (hwd / in.) 10.00 x 7.00 x 0.10 Shipping Dimensions (hwd / cm) 25.40 x 17.78 x 0.25 Shipping Weight (lbs.) 0.31 Shipping Weight (kg) 0.14 ENVIRONMENTAL Operating Temperature Range -4 F (-20 C) to 140 F (60 C) Storage Temperature Range -4 F (-20 C) to 140 F (60 C) Operating Humidity Range 10-85% RH Storage Humidity Range 10-85% RH CONNECTIONS Side A - Connector 1 IEC-320-C14 - LEFT ANGLE Side B - Connector 1 IEC-320-C13 WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P005-002-14LA
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入、输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗电子等领域。
7. 封装信息:采用QFN封装,尺寸为4x4mm。
P005-002-14LA 价格&库存
很抱歉,暂时无法提供与“P005-002-14LA”相匹配的价格&库存,您可以联系我们找货
