P032-002-2C13
P032-002-2C13
    TRIPPLITE
    P032-002-2C13
P032-002-2C13 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Splitter Cable, Heavy-Duty, C20 to 2x C13 - 15A, 100-250V, 14 AWG, 2 ft. (0.61 m), Black MODEL NUMBER: P032-002-2C13 Highlights ● Connects 2 devices to one AC outlet to save space and reduce cable clutter ● Recommended for powering dual computers, monitors or other compatible peripherals ● 2-ft. (0.61 m) length allows flexibility in placing devices, while avoiding cable clutter ● Heavy-duty cord replaces or upgrades standard power cords provided by manufacturer ● Thick 14 AWG wire gauge manages high power levels required for larger equipment Applications C20-to-C13 splitter allows 2 devices with C14 inlets to share one AC power input cord and one C19 outlet on a PDU or UPS system. ● Connect 2 devices like computers, monitors, scanners and printers to one power outlet up to 2-ft. (0.61 m) away in your home office, work space or dorm room ● Cut cable clutter by powering both monitors in a dual-monitor display mount with a single cord ● Save space in a 0U vertical rack-mount PDU by plugging two rack devices into one outlet Features Heavy-Duty Splitter Cable for Network Devices That Require a Heavy-Gauge ConnectionThis C20to-C13 splitter features 14 AWG wire suitable for high power connections, making it a reliable solution for large server applications that require a higher-rated, heavier-gauge cable. It allows two devices with C14 power inlets to share one AC input cord and one C19 outlet. By connecting two devices to one outlet, the splitter frees up space in a PDU or surge protector and helps reduce cable clutter. The 2-ft. (0.61 m) length helps reduce cable clutter and minimize the risk of tripping. Dual IEC Cable Powers a Wide Variety of Essential ElectronicsWith this splitter, a single C19 outlet can power two devices, such as computers, monitors, printers, instrument amplifiers and other equipment compatible with a C19 connector. Ideal for areas where AC outlets are limited, such as rack cabinets, this dual IEC cable is compatible with Tripp Lite power and extension cords. Specifications OVERVIEW UPC Code 037332156495 Device Compatibility Computer; Monitor/HDTV; Server; UPS; PDU Country/Region North America INPUT Maximum Input Amps 15 Voltage Compatibility (VAC) 100-250 PHYSICAL 1/3 Package Includes ● P032-002-2C13 C20 to C13 Splitter, 2-ft. (0.61 m), Black 1000 Eaton Boulevard Cleveland, OH 44122 United States Plug Color Black Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Power Cord Jacket Type SJTW Cable Outer Diameter (OD) 9.3mm; 11mm Number of Conductors 3 Wire Gauge (AWG) 14 Wire Gauge (OD - mm²) 2.08 Cable Length (ft.) 2 Cable Length (m) 0.61 Shipping Dimensions (hwd / in.) 12.80 x 8.90 x 0.50 Shipping Dimensions (hwd / cm) 32.51 x 22.61 x 1.27 Shipping Weight (lbs.) 0.56 Shipping Weight (kg) 0.25 ENVIRONMENTAL Operating Temperature Range 14 F TO 140 F (-10 C TO 60 C) Storage Temperature Range 14 F TO 140 F (-10 C TO 60 C) Operating Humidity Range 35% to 85% RH, Non-Condensing Storage Humidity Range 35% to 85% RH, Non-Condensing CONNECTIONS Side A - Connector 1 IEC-320-C20 Side B - Connector 1 (2) IEC-320-C13 FEATURES & SPECIFICATIONS High Voltage Yes Locking Plug No Antibacterial No Angled Plug No Coiled Power Cord No STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL Listed Product Compliance RoHS 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P032-002-2C13 价格&库存
很抱歉,暂时无法提供与“P032-002-2C13”相匹配的价格&库存,您可以联系我们找货
