P036-006-2C19
P036-006-2C19
    TRIPPLITE
    P036-006-2C19
P036-006-2C19 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Power Extension Cord/Splitter, 2 x C19 to C20 Y Splitter - Heavy-Duty, 20A, 250V, 12 AWG, 6 ft. (1.83 m), Black Highlights ● Connects 2 devices to one AC outlet to save space and reduce cable clutter ● Recommended for powering servers, routers and other highoutput network devices ● 6-ft. (1.83 m) length allows flexibility in placing devices in relationship to AC outlet ● C20 to C19 cord replaces or upgrades standard power cord provided by manufacturer ● Thick 12 AWG wire gauge manages high power levels required for larger equipment MODEL NUMBER: P036-006-2C19 Applications ● Connect 2 devices like highpower servers, routers and blade server chassis to one power outlet up to 6-ft. (1.83 m) away in your network setup ● Save space in a 0U vertical rack-mount PDU by plugging two rack devices into one outlet ● Update or replace the standard power cords provided by your devices' original manufacturer C19-to-C20 splitter allows 2 devices with C20 inlets to share one AC power input cord and one C19 outlet on a PDU or UPS system. Features Heavy-Duty Y-Style Splitter Cable Connects 2 Devices with C20 Inlets to One C19 OutletThis heavyduty splitter extension cord features 12 AWG wire suitable for high power connections, making it a reliable solution for large server applications that require a higher-rated, heavier-gauge cable. This cord features a C20 plug for connecting to an AC power source and two C19 pigtails for connecting to devices. By connecting two devices to one outlet, the power cord splitter frees up space in a PDU, UPS system or surge protector and helps reduce cable clutter. The 6-ft. (1.83 m) length allows you flexibility in placing equipment with respect to the power outlet. Dual IEC Cable Powers a Wide Variety of Essential ElectronicsWith this 20A power splitter, a single C19 outlet can power two high-output devices, such as servers, routers, blade server chassis and other equipment compatible with a C19 connector. Ideal for areas where AC outlets are limited, such as rack cabinets, this cable is compatible with Tripp Lite power and extension cords. Specifications OVERVIEW UPC Code 037332156549 Device Compatibility Server; Router; Network Switch; UPS; PDU Country/Region North America INPUT Maximum Input Amps 20 Voltage Compatibility (VAC) 100-250 1/3 Package Includes ● P036-006-2C19 2x C19 to C20 Y Splitter Heavy-Duty Power Extension Cord, 6-ft. (1.83 m), Black 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Plug Color Black Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 11.2mm Number of Conductors 3 Wire Gauge (AWG) 12 Wire Gauge (OD - mm²) 3.31 Cable Length (ft.) 6 Cable Length (m) 1.83 Shipping Dimensions (hwd / in.) 1.00 x 5.60 x 8.50 Shipping Dimensions (hwd / cm) 2.54 x 14.22 x 21.59 Shipping Weight (lbs.) 0.90 Shipping Weight (kg) 0.41 ENVIRONMENTAL Operating Temperature Range 14 F TO 140 F (-10 C TO 60 C) Storage Temperature Range 14 F TO 140 F (-10 C TO 60 C) Operating Humidity Range 35% to 85% RH, Non-Condensing Storage Humidity Range 35% to 85% RH, Non-Condensing CONNECTIONS Side A - Connector 1 IEC-320-C20 Side B - Connector 1 (2) IEC-320-C19 FEATURES & SPECIFICATIONS High Voltage Yes Locking Plug No Antibacterial No Angled Plug No Coiled Power Cord No STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL Listed 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P036-006-2C19 价格&库存
很抱歉,暂时无法提供与“P036-006-2C19”相匹配的价格&库存,您可以联系我们找货
