P047-006
P047-006
    TRIPPLITE
    P047-006
P047-006 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Power Cord, C19 to C14 - Heavy-Duty, 15A, 250V, 14 AWG, 6 ft. (1.83 m), Black MODEL NUMBER: P047-006 Highlights ● C19 to C14 cable for powering computers, servers and other network devices ● 6-ft. (1.83 m) length allows flexibility in placing devices in relationship to AC outlet ● Heavy-duty cable replaces or upgrades standard power cord provided by manufacturer ● Thick 14 AWG wire gauge manages high power levels required for larger equipment Applications C14 to C19 power cord transforms a C20 plug into a C14 plug for connecting to a C13 outlet on a PDU or UPS system. ● Connect devices like computers, servers and drives to a PDU up to 6-ft. (1.83 m) away in your data center ● Extend an existing power connection up to 6-ft. (1.83 m) to more easily place a device or reach a power source in a rack ● Update or replace the standard power cord provided by a device's original manufacturer Features C19 to C14 Power Cord for Network Devices That Require a Heavy-Gauge ConnectionThis C14 to C19 cable features 14 AWG wire suitable for high power connections, making it a reliable solution for large server applications that require a higher-rated, heavier-gauge cable. The C14 to C19 power cable can be used to connect a computer, server or drive to a UPS system or PDU or replace or upgrade the standard power cord provided by the device's manufacturer. The 6-ft. (1.83 m) length allows you flexibility in placing equipment with respect to the power outlet. Specifications OVERVIEW UPC Code 037332150059 Device Compatibility Computer; Server; UPS; PDU Country/Region North America INPUT Maximum Input Amps 15 Voltage Compatibility (VAC) 100-250 PHYSICAL Plug Color Black Cable Jacket Color Black Cable Jacket Material PVC 1/3 Package Includes ● P047-006 C19 to C14 Power Cord, 6-ft. (1.83 m), Black 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Rating VW-1 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 9.3mm Number of Conductors 3 Wire Gauge (AWG) 14 Wire Gauge (OD - mm²) 2.08 Cable Length (ft.) 6 Cable Length (m) 1.83 Shipping Dimensions (hwd / in.) 12.80 x 8.90 x 0.50 Shipping Dimensions (hwd / cm) 32.51 x 22.61 x 1.27 Shipping Weight (lbs.) 0.80 Shipping Weight (kg) 0.36 ENVIRONMENTAL Operating Temperature Range -4 F TO 140 F (-20 C TO 60 C) Storage Temperature Range -4 F TO 140 F (-20 C TO 60 C) Operating Humidity Range 10 TO 65% RH Storage Humidity Range 10 TO 65% RH CONNECTIONS Side A - Connector 1 IEC-320-C14 Side B - Connector 1 IEC-320-C19 FEATURES & SPECIFICATIONS High Voltage Yes Locking Plug No Antibacterial No Angled Plug No Coiled Power Cord No STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P047-006 价格&库存
很抱歉,暂时无法提供与“P047-006”相匹配的价格&库存,您可以联系我们找货
