P043-002
P043-002
    TRIPPLITE
    HEAVYDUTYPWRCORDW/BREAKER2'
P043-002 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Power Extension Cord, NEMA L5-30P to NEMA L5-20R Extension Cord with Breaker - 20A, 120V, 10 AWG, 2 ft. (0.61 m), Black Highlights ● Built-in 20A breaker allows easy transition to L5-20R outlet with no electrician needed ● 2-ft. (0.61 m) length allows flexibility in placing devices, while avoiding cable clutter ● Heavy-duty cable replaces or upgrades standard power cord provided by manufacturer ● Thick 10 AWG wire gauge manages high power levels required for larger equipment ● Locking connectors maintain secure link to avoid loss of power and costly downtime MODEL NUMBER: P043-002 Applications ● Connect PDUs and UPS systems to a power outlet up to 2-ft. (0.61 m) away in your office or workspace ● Extend an existing power connection up to 2-ft. (0.61 m) to more easily place a device or reach a power source in a rack ● Transform a NEMA L5-30R outlet into a NEMAL L5-20R outlet with no electrician needed ● Update or replace the standard power cord provided by a device's original manufacturer L5-30P to L5-20R extension cord with breaker transforms a NEMA L5-30R wall outlet into a NEMA L520R outlet. Features Heavy-Duty Extension Cable Connects Devices That Require a Heavy-Gauge ConnectionThis heavy-duty extension cord with breaker features 10 AWG wire suitable for high power connections, making it a reliable solution for large server applications that require a higher-rated, heavier-gauge cable. It comes with a built-in metal 20-amp breaker box, which allows you to transform a NEMA L5-30R wall outlet into a NEMA L5-20R outlet. It is also a recommended replacement or upgrade of a standard power cord provided by the device's manufacturer. The 2-ft. (0.61 m) length helps reduce cable clutter and minimize the risk of tripping. Locking Connectors Help Prevent Accidental Disconnection and Expensive DowntimeHaving a cable come loose accidentally can mean the loss of power and costly downtime. Locking connectors on each end help you avoid such danger, protecting critical equipment by maintaining a secure link without failure. The locking cable is also invaluable when moving equipment in a rack or removing equipment from tight areas, ensuring the power cord always stays connected. Specifications OVERVIEW UPC Code 037332142306 Device Compatibility UPS; PDU Country/Region North America INPUT Maximum Input Amps 20 1/3 Package Includes ● P043-002 L5-30P to L5-20R Extension Cord with Breaker, 2ft. (0.61 m), Black 1000 Eaton Boulevard Cleveland, OH 44122 United States Voltage Compatibility (VAC) 120 PHYSICAL Plug Color Black Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 14.6mm Number of Conductors 3 Wire Gauge (AWG) 10 Wire Gauge (OD - mm²) 5.26 Cable Length (ft.) 2 Cable Length (m) 0.61 Shipping Dimensions (hwd / in.) 18.90 x 11.80 x 0.50 Shipping Dimensions (hwd / cm) 48.01 x 29.97 x 1.27 Shipping Weight (lbs.) 1.10 Shipping Weight (kg) 0.50 ENVIRONMENTAL Operating Temperature Range 14 F TO 140 F (-10 C TO 60 C) Storage Temperature Range 14 F TO 140 F (-10 C TO 60 C) Operating Humidity Range 35% to 85% RH, Non-Condensing Storage Humidity Range 35% to 85% RH, Non-Condensing CONNECTIONS Side A - Connector 1 NEMA L5-30P Side B - Connector 1 NEMA L5-20R FEATURES & SPECIFICATIONS High Voltage No Locking Plug Yes Antibacterial No Angled Plug No Coiled Power Cord No STANDARDS & COMPLIANCE 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Certifications cUL Listed; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P043-002 价格&库存
很抱歉,暂时无法提供与“P043-002”相匹配的价格&库存,您可以联系我们找货
