1000 Eaton Boulevard
Cleveland, OH 44122
United States
Power Extension Cord/Splitter, NEMA L6-30P to
2x NEMA L6-30R Y Splitter, Heavy-Duty - 30A,
250V, 10 AWG, 1 ft. (0.31 m), Black
Highlights
Connects 2 devices to one AC
outlet to save space and reduce
cable clutter
Recommended for powering
dual PDUs, UPS systems or
other heavy-duty devices
Adds 1-ft. (0.31 m) to your
existing power connection to
provide flexibility in placing
devices
Locking connectors maintain
secure link to avoid loss of
power and costly downtime
Thick 10 AWG wire gauge
manages high power levels
required for larger equipment
MODEL NUMBER: P041-001-2
Applications
Connect 2 devices like PDUs
and UPS systems to one power
outlet up to 1-ft. (0.31 m) away
in your office or work space
Save space in a 0U vertical
rack-mount PDU by plugging
two rack devices into one outlet
Update or replace the standard
power cord provided by a
device's original manufacturer
L6-30P to L6-30R splitter allows two devices with NEMA L6-30P plugs to share one AC power input cord
and one NEMA L6-30R outlet.
Features
Heavy-Duty Y-Style Splitter Cable Connects 2 Devices with L6-30P Plugs to One AC OutletThis Y
splitter cable features 10 AWG wire suitable for high power connections, making it a reliable solution for
large server applications that require a higher-rated, heavier-gauge cable. With this extension cord splitter,
a single NEMA L6-30R outlet can power two devices, such as PDUs, UPS systems, instrument amplifiers
and other equipment compatible with a NEMA L6-30P plug. Ideal for areas where AC outlets are limited,
such as rack cabinets or small network closets, this L6-30P to L6-30R Y splitter is compatible with Tripp
Lite power and extension cords. The 1-ft. (0.31 m) length helps reduce cable clutter.
Locking Connectors Help Prevent Accidental Disconnection and Expensive DowntimeHaving a
cable come loose accidentally can mean the loss of power and costly downtime. Locking connectors on
each end help you avoid such danger, protecting critical equipment by maintaining a secure link without
failure. The locking cable is also invaluable when moving equipment in a rack or removing equipment from
tight areas, ensuring the power cord always stays connected.
Specifications
OVERVIEW
UPC Code
037332141484
Device Compatibility
Server; Router; Network Switch; UPS; PDU
Country/Region
North America
INPUT
Maximum Input Amps
30
1/3
Package Includes
P041-001-2 L6-30P to 2x L630R Y Splitter, 1-ft. (0.31 m),
Black
Cleveland, OH 44122
United States
Voltage Compatibility (VAC)
100-250
PHYSICAL
Plug Color
Black
Cable Jacket Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
FT2
Power Cord Jacket Type
SJT
Cable Outer Diameter (OD)
14.5mm
Number of Conductors
3
Wire Gauge (AWG)
10
Wire Gauge (OD - mm²)
5.26
Cable Length (ft.)
1
Cable Length (m)
0.30
Shipping Dimensions (hwd / in.)
15.80 x 11.80 x 0.50
Shipping Dimensions (hwd / cm)
40.13 x 29.97 x 1.27
Shipping Weight (lbs.)
2.40
Shipping Weight (kg)
1.09
ENVIRONMENTAL
Operating Temperature Range
-4 to 140 F (-20 to 60 C)
Storage Temperature Range
Operating Humidity Range
20% to 70% RH
Storage Humidity Range
20% to 80% RH
CONNECTIONS
Side A - Connector 1
NEMA L6-30P
Side B - Connector 1
(2) NEMA L6-30R
FEATURES & SPECIFICATIONS
High Voltage
Yes
Locking Plug
Yes
Angled Plug
No
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
2/3
Cleveland, OH 44122
United States
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“P041-001-2”相匹配的价格&库存,您可以联系我们找货
