1000 Eaton Boulevard
Cleveland, OH 44122
United States
Heavy-Duty PDU Power Cord, C13 to Left-Angle
C14 - 15A, 250V, 14 AWG, 6 ft. (1.83 m), Black
MODEL NUMBER: P005-006-14LA
Highlights
Left-angle C14 plug allows
easier connection in confined or
hard-to-reach spaces
Recommended for powering
computers, servers and other
network devices
6-ft. (1.83 m) length allows
flexibility in placing devices in
relationship to AC outlet
PDU-style cord replaces or
upgrades standard power cord
provided by manufacturer
Thick 14 AWG wire gauge
manages high power levels
required for larger equipment
Applications
Computer power extension cord with left-angle C14 plug allows connection of a PC, printer or monitor in
tight spaces or awkward angles.
Connect devices like computers,
servers and monitors to a PDU
up to 6-ft. (1.83 m) away in your
data center
Extend an existing power
connection up to 6-ft. (1.83 m) to
more easily place a device or
reach a power source away
from your workstation
Update or replace the standard
power cord provided by a
device's original manufacturer
Power a device located in a
hard-to-access area behind a
desk or flush against a wall
Features
C14-to-C13 Power Cable for Network Devices That Require a Heavy-Gauge ConnectionThis IEC320-C14 to IEC-320-C13 cable features 14 AWG wire suitable for high power connections, making it a
reliable solution for large server applications that require a higher-rated, heavier-gauge cable. This C14
male to C13 female cord can be used to connect a computer, server, monitor or drive to a UPS system or
PDU or replace or upgrade the standard power cord provided by the device's manufacturer. The 6-ft. (1.83
m) length allows you flexibility in placing equipment with respect to the power outlet.
Left-Angle C14 Plug Makes Connecting in Tight Spaces EasierThe C13 to C14 left-angle cable is
easier to install in confined spaces, such as the back of a rack enclosure cabinet. When plugged in, the
left-angled C14 plug guides the computer power supply cable parallel to your peripheral, allowing you to
push the device up against a wall or hide it behind a desk to maximize space.
Specifications
OVERVIEW
UPC Code
037332179920
Device Compatibility
Computer; Monitor/HDTV; Printer; Server; Router; Network Switch; UPS; PDU
Country/Region
Global
INPUT
Maximum Input Amps
15
Voltage Compatibility (VAC)
100-250
1/3
Package Includes
P005-006-14LA C13 to LeftAngle C14 Power Cable, 6-ft.
(1.83 m), Black
Cleveland, OH 44122
United States
PHYSICAL
Plug Color
Black
Cable Jacket Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
FT2
Power Cord Jacket Type
SJT
Cable Outer Diameter (OD)
9.2mm
Number of Conductors
3
Wire Gauge (AWG)
14
Wire Gauge (OD - mm²)
2.08
Cable Length (ft.)
6
Cable Length (m)
1.83
Shipping Dimensions (hwd / in.)
10.00 x 7.00 x 0.10
Shipping Dimensions (hwd / cm)
25.40 x 17.78 x 0.25
Shipping Weight (lbs.)
0.66
Shipping Weight (kg)
0.30
ENVIRONMENTAL
Operating Temperature Range
-4 TO 140 F (- 20° TO 60°C)
Storage Temperature Range
Operating Humidity Range
20-80% RH
Storage Humidity Range
20-80% RH
CONNECTIONS
Side A - Connector 1
IEC-320-C14 - LEFT ANGLE
Side B - Connector 1
IEC-320-C13
FEATURES & SPECIFICATIONS
High Voltage
Yes
Locking Plug
No
Antibacterial
No
Angled Plug
Yes
Coiled Power Cord
No
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); cUL Listed; UL Listed
2/3
Cleveland, OH 44122
United States
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“P005-006-14LA”相匹配的价格&库存,您可以联系我们找货
