P004-002-13LA
P004-002-13LA
    TRIPPLITE
    P004-002-13LA
P004-002-13LA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Power Extension Cord, Left-Angle C13 to C14 PDU Style - 10A, 250V, 18 AWG, 2 ft. (0.61 m), Black Highlights ● Left-angle C13 plug allows easier connection in confined or hard-to-reach spaces ● Recommended for powering computers, printers and other essential peripherals ● Adds 2-ft. (0.61 m) to your existing power connection to provide flexibility in placing devices ● C13-to-C14 PDU-style extension cord is ideal replacement for worn-out or missing cable MODEL NUMBER: P004-002-13LA Applications Computer power extension cord with left-angle C13 plug allows connection of a PC, printer or monitor in tight spaces or awkward angles. ● Connect devices like computers, servers and monitors to a PDU up to 2-ft. (0.61 m) away in your data center ● Extend an existing power connection up to 2-ft. (0.61 m) to more easily place a device or reach a power source near your workstation ● Provide a high-quality replacement for a worn-out or missing power cord ● Power a device located in a hard-to-access area behind a desk or flush against a wall Features C14-to-C13 Power Cable Connects Computers, Printers, Servers and Other EquipmentThis IEC320-C14 to IEC-320-C13 cable is designed for small data center, office workstation and other lower-amp applications. This C14 male to C13 female cord can be used to power a computer, server or monitor; attach a server or drive to a UPS system or PDU; or extend an existing connection up to 2-ft. (0.61 m). The 2-ft. (0.61 m) length helps reduce cable clutter and minimize the risk of tripping. Package Includes ● Left-Angle C13 Plug Makes Connecting in Tight Spaces EasierThe C13 to C14 left-angle cable is easier to install in confined spaces, such as the back of a rack enclosure cabinet. When plugged in, the left-angled C13 plug guides the computer power supply cable parallel to your peripheral, allowing you to push the device up against a wall or hide it behind a desk to maximize space. Specifications OVERVIEW UPC Code 037332156426 Device Compatibility Computer; Monitor/HDTV; Printer; Server; UPS; PDU Country/Region Global INPUT Maximum Input Amps 10 Voltage Compatibility (VAC) 100-250 1/3 P004-002-13LA C14 Male to C13 Female Power Cable, 2-ft. (0.61 m), Black 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Plug Color Black Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 7.8mm Number of Conductors 3 Wire Gauge (AWG) 18 Wire Gauge (OD - mm²) 0.82 Cable Length (ft.) 2 Cable Length (m) 0.61 Shipping Dimensions (hwd / in.) 1.00 x 4.90 x 9.10 Shipping Dimensions (hwd / cm) 2.54 x 12.45 x 23.11 Shipping Weight (lbs.) 0.20 Shipping Weight (kg) 0.09 ENVIRONMENTAL Operating Temperature Range -4 F TO 140 F (-20 C TO 60 C) Storage Temperature Range -4 F TO 140 F (-20 C TO 60 C) Operating Humidity Range 10 TO 65% RH Storage Humidity Range 10 TO 65% RH CONNECTIONS Side A - Connector 1 IEC-320-C14 Side B - Connector 1 IEC-320-C13 - LEFT ANGLE FEATURES & SPECIFICATIONS High Voltage Yes Locking Plug No Antibacterial No Angled Plug Yes Coiled Power Cord No STANDARDS & COMPLIANCE Product Certifications CSA (Canada); cUL Listed; UL Listed 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P004-002-13LA 价格&库存
很抱歉,暂时无法提供与“P004-002-13LA”相匹配的价格&库存,您可以联系我们找货
